Topic: [Not My Release] EsPlaylist (Read 341491 times) previous topic - next topic
Reply #200
Feature Request:
Two different Specified Playlists - One for just displaying selected items from a EsPlaylist in Library Browsing Mode and one for playing. Then we have a real "Now Playing" playlist that can't be overwritten if the user selects other library entries. If the user chooses to play them, they will be sent to the 2nd Specified Playlist (Now Playing list) and the view switches to that list. If the user then selects other stuff, the view switches back to the first Specified Playlist.
Double click action: Send to specific playlist and play
Specify Playlist Name: Now Playing
Create a "Now Playing" playlist and another for browsing (ie "Library Viewer Selection"), add a playlist switcher to your layout and you're done.
Reply #201
Using 0.1.1.0 Beta 2 of Esplaylist with Br3tt's Tech skin leads to foobar eventually hanging. The process is still alive and the music is still running but the player is inaccessible. Right click menu of the tray icon doesn't work either. It's not a matter of memory or CPU cycles missing.
With 0.1.0.0 there is no issue and works just fine.
Reply #202
Could you try using Process Explorer ?
* If foobar2000 freezes up, then double-click on the foobar2000.exe in ProcessExplorer, go to the tab "Threads" and see whether there is a thread of which start address is "foo_uie_esplaylist + 0x****".
* If esplaylist's thread exists, then double click on it. we might be able to see where the foobar2000 is hanging up.
Reply #203
Will do and post the results.
Edit: It just hanged itself up again and I checked Process Explorer. There is no foo_uie_esplaylist thread in the list.
I have some foobar2000.exe threads, some foo_audioscrobbler, 2 foo_chronflow, 1 WinMM.dll, 1 gdiplus.dll, 1 wdmaud.drv, 2 ntdll.dll and one foo_wave_seekbar threads.
It's still somehow ESplaylist related though because with 0.1.0.0 it doesn't hang :\
Reply #204
0.1.1.0 Beta 2 hangs heavily after installation on two different PCs. No log-reports.
After that (heavy) crash foobar2000 reinstallation and theme reimport was required.
After that occurrence - everything seems to be ok...
Reply #205
I tried loading the fcl from Br3tt again and now it seems to be working. At least for the time being.
Edit: LOL 3 seconds after I posted this it hung up again.
Reply #206
it would be an awesome feature to be able to configure album art padding - right now it's too close to the left side of scrolling area
Reply #207
Hm somehow I don't think this problem is ESplaylist related after all. Seems to be something about Tech 1.3b that is off.
Reply #208
@ssenna,
Would it be possible to add an optional filter toolbar (as in the Album List component) for the "browse library" mode? And maybe to add $crlf() for the grouping titles?
thanks in advance,
Decalicatan Decalicatan
Reply #209
I got a question can you guys help me out?
I'm trying to get a compilation "va" folder/playlist to show as artists - song any way I can do that without adding another column?
Currently i have the columns as just art, now playing, track no, title, length
Reply #210
try this:
[%track artist% - ]%title%
Reply #211
Ah Thanks so much that did the trick!
Reply #212
For albums that consist of multiple disc and have the naming pattern "%album% (Disc %discnumber%)", it would be great to be able to use the function $crlf() inside this window, section "Title":
Then we could use some $if() and $crlf() to properly display "Disc 1", "Disc 2" etc.
For now, you cannot see the disc numbers in most cases:
This would be great because then the text is blue, too, and no separating line - showing it somehow belongs to the album title.
Reply #213
I just realized that files that you move from within foobar2000 via the "File Operations - Move To" command aren't updated in EsPlaylist. The view will only be updated after you restarted foobar2000. Does this happen to anybody else and is it going to be fixed?
Reply #215
Sssena, two bugs to report:
1. When only one album is in a playlist, their appears to be a lot of lag when trying to select the album by clicking the title area... This behavior is not present when there is more than one album.
2. When there are multiple albums in the top layer/album art view, it is impossible to highlight all albums with the select+all action (the albums are all selected, but only one is highlighted).
Thank you, as always, for this wonderful component and your hard work!
Reply #216
@ssenna
Thanks a lot for this component.
I have one feature request that i really miss from elplaylist.
That is the refresh all option in the right click menu.
Because if you edit the album art when album is in the playlist, then there is no way to refresh that album art, or if you add the album art when the album is already playing then there is no way to load that album art.
Reply #217
Would be great if such changes are automatically updated, like foobar2000 DUI playlist does.
Reply #218
Yes that would be even better .
Reply #219
I can't reproduce the problem. What information is not updated in EsPlaylist ?
I can't reproduce this problem. how many tracks in one album ?
This is intended behaviour. If possible, please use "Ctrl + a" instead.
I think third party components have no clean way to know that the album art was just updated.
Maybe, "refresh" menu will be added.
Reply #220
Hm, it's actually very hard for me to reproduce as well, but it does sometimes happen, and only with one album. I'll report back if I can find other factors that are causing this.
Reply #221
v0.1.1.0 beta 4 (2010/06/27)
    * fixed : drag & drop didn't work in some cases.
    * added : Options->Configure->Highlight playing item
    * added : Options->Refresh
THANKS FOR THE REFRESH OPTION
Reply #222
EsPlaylist v0.1.1.0 beta 4.1 (2010/06/28) released.
Changelog:
  • fixed : drag & drop didn't work in some cases.
  • added : Options->Configure->Highlight playing item
  • added : Options->Refresh
  • fixed: undo-point was not generated when drag & drop from a playlist to another one in one EsPlaylist panel.(beta 4.1)
Download EsPlaylist v0.1.1.0 beta 4.1
Reply #223
@ssenna
Thanks for this excellent component!
Do you think it may be possible to add an option to remove automatically the group info column if the grouping of a particular playlist is set to none?
thanks in advance
Reply #224
Amazing component!!
One thing that I have noticed is for my Recently Played playlist that I have since it's usually just one song from an album, I set it so it is the only playlist to use the "No Cover Art" option, but there is still a huge vertical space between the songs in "Flat View".
I realize I could put different columns so the Artist & Album info would be visible along with "No Grouping" , but then I don't need those in my other playlists.
Any help definitely appreciate, Thanks!!!
