Topic: What Ogg Vorbis encoder would you like to see in a listening test? (Read 5865 times) previous topic - next topic
  • ezlez
I'm going to conduct a multi-format listening test very soon, and I need only one encoder per format. I'm deciding between oggdropXPd 1.9.0 vs. oggenc2.85 (Either libVorbis v1.2.3 aoTuVb5.7), and I wanted on what your thoughts are, since I don't have much experience with Ogg Vorbis. All the encoders are coming from Rarewares.org.
  • lvqcl
  • Developer
That doesn't matter.
  • stigc
Hi ezlez. When og with what software? What bitrate?
I vote for libvorbis 1.2.3
Because it is newer and for me it sounds better than aotuvb5.7 at ~150 kbps.
Which bitrate you have choosen for test?
  • Last Edit: 23 February, 2010, 07:07:03 AM by Steve Forte Rio
  • lvqcl
  • Developer
libvorbis 1.2.3 uses aoTuV b2 tweaks. So w.r.t. audio quality it is much older than aoTuV b5.7.
  • Xanikseo
As long as you use aoTuV b5.7 it's fine. So yh oggdropXPd 1.9.0 using aoTuV b5.7
  • timcupery
as lvqcl said, oggdropXPd vs. oggenc doesn't matter, that's simply an issue of frontend.
what does matter is which encoder. and it sounds like aoTuV b5.7 is the newer encoder (and more recently optimized, and thus likely but not guaranteed to be better)
God kills a kitten every time you encode with CBR 320
  • john33
  • Developer
Just my 2 cents -  as already said, the question relates to frontends and not to encoding library. Since the results should be identical, it should be a matter of personal choice and have zero influence over the test result.
John
  • dsimcha
Have you ever ABX'd this?  Either one should usually be completely transparent at such a high bitrate.  AoTuv Beta 5.7 is widely considered to be mostly transparent (except on a few killer samples) at -q3 or -q4, which correspond to nominal bitrates of 112 and 128 kbps respectively.  Even -q2 (nominal bitrate 96 kbps) seldom produces severe artifacts that are noticable in casual listening.  I can ABX LAME at ~128 kbps on a lot more samples than I can ABX Vorbis at ~96 kbps.
  • Last Edit: 25 March, 2010, 01:32:13 PM by dsimcha
  • NullC
  • Developer
If someone wants to do some adventurous testing. Try out FFvorbis which is the vorbis encoder internal to ffmpeg.  It generally produces horrific results[1].  It is suddenly interesting because a lot of people will be using ffmpeg to transcode into webm  and some people seem to have a hard time believing that the ffmpeg encoder sounds worse than libvorbis or aoTuV.  Some independent results might go a long way towards saving the world from billions of files encoded with that encoder.
[1] No blind testing is really required, for example: http://myrandomnode.dyndns.org:8080/~gmaxwell/fffail/new01/  and http://myrandomnode.dyndns.org:8080/~gmaxwell/fffail/new02/
  • AshenTech
the ffmpeg guys lost my respect a while back due to how they treated the creator of mediacoder, Love some of the results of their products, but at least their groups mouth peices are a bunch of arseholes, dosnt surprise me at all that ffmpeg's encoder sucks, their theora encoder was HORRIBLE(if you can even get it to actually work.....)
