Topic: Recursive creation of M3U files (Read 2716 times) previous topic - next topic
I'm new to foobar2000 (but not new to audio conversion software). I've been living in the Linux world for a couple of years, but have set up a Windows 7 machine for Windows Media Center (and the integrated Netflix streaming).
I'm also in the process of converting all my CDs (1600 of them) to FLAC.
I'm storing my FLACs in an "Artist\Year - Album\Track# Title" hierarchy, and I'm looking for a way to create an M3U playlist file in each album subfolder (in a recursive batch manner), with a filename of "Artist - Album.m3u". Can foobar2000 be leveraged to do this? Or does anyone know of some other utility that works in Windows 7?
Thanks for any info.
I think there are scripts for that on net, although it can be done with foobar also, i.e. with "text tools > advanced" enter:
echo %filename_ext% >> "$ansi($directory_path(%path%)\%album artist% - %album%.m3u)"
as track pattern, then copy result in batch file and run it.
Just be careful about 255 character limitation for path
[edit] I'm not sure if limitation is for filename, or path, but this is safe:
$ifgreater($len($directory_path(%path%)\%album artist% - %album%.m3u),255,,
Thanks, this works great
<3 f00
It is if you don't explicitly use the \\.\ path prefix. foobar2000 uses this prefix when addressing local files, and thus bypasses the limitation.
