Topic: Visualizations + Cover flow? (Read 3514 times) previous topic - next topic
I need some new visualizations, I'm getting bored with the default visualizations
Also, I need a cover flow component that is compatible with fb2k, Chronflow does not seem to be working, I keep getting an error that keeps telling me the component is incompatible with fb2k 1.0
Failed to load DLL: foo_bubble_coverflow.dll
Reason: Wrong version number; this component appears to have been built with an outdated version of the foobar2000 SDK and needs to be recompiled with newer version in order to load; please contact the author of this component to obtain an updated version of this component.
Any help is appreciated
I'm also curious about visualizations - I used to use foo_uie_vis_channel_spectrum.dll, but it's been causing crashes in 1.0. The default spectrum analyzer doesn't show both stereo channels (that I can tell). Thanks.
AH
hi,
i'm currently developing a visualization, but it's not a foobar plugin. But it works fine while using foobar. You can download the version 0.2 from my project-page here, there are some screenshots, too. The page is german, but there's a readme.txt in english within the zip file.
A short preview to the next version 0.3:
[a href="http://www.weltfalt.de/_files/images/soundbild_cupStack.jpg" target="_blank"]
Check out foo_vis_shpeck for your visualisation needs. It's a wrapper for Winamp visualisations, so Milkdrop etc is available.
I'm using foo_chronflow (version 0.3.0) in fb2k 1.0 without a problem (see screenshot), so I'm not sure why it's not working for you.
[attachment=5737:foobar_vis_flow.jpg]
