Topic: foo_autoupdate (Read 35079 times) previous topic - next topic
foo_autoupdate
Now there finally is a [a href='index.php?showtopic=78708']proper full-fledged component manager[/a] getting done, I'm not ashamed to show what I tried to do.
It's another thingy which checks for component updates in configured intervals or when invoked manually.
Of course, you have to ask:
Why the hell doesn't it really update anything in the end?
Well, I thought about all that in the distribution part (scripts for extracting relevant files from ZIP and other archives to correct locations and updating other bundled files) as well as the installation part (system-wide service to allow automatic updating for users with no local administrator privileges), but then I realized another thing. "Hotlinking" the component files from around the internet bypasses their authors, their release notes, their ads, and I'm not going to do that. I could rehost the relevant files myself, but that doesn't solve all those problems. So I ended up with it just as a notifier and that's probably it. Also see the first sentence
I played with other unimportant details though, here is some short list:
* Uses the official component repository and the xrea.jp wiki page as a source (updated each 2 hours)
* Works over HTTP, using JSON based extensible protocol
* Compressed transport (bandwidth costs, CPU time is cheap)
* Secure connection using challenge/response authentication and RSA signature
* Certain updates can be hidden (useful for beta versions etc.)
* Shows status (outdated, up to date, bundled, etc.) for all installed components
* Disabled when current user doesn't have write permissions to the installation folder, not even when elevated
* Collects various interesting and uninteresting statistics (when enabled; see here)
* Allows 3rd party components to add their statistics using public API.
* Can show additional information about components in HTML.
* Server can send additional message to all users when needed.
* High-DPI compatible!
* ...I don't remember anymore
You can download the component here.
foo_autoupdate
Well,'tis a nice idea. I hate having to go to Troubleshooting in Foobar2000 every time I want to see if there's an update available.
foo_autoupdate
Thank you
I like this component.
I tried it and it claims Biography view 0.4.0.2 as the latest version, although i already installed 0.4.0.3.
I guess its caused by an older file hosted on the japanese components page?
Is it possible to check the installed versions and only list higher versions for update?
foo_autoupdate
This is interesting
I wonder how it will end: with merging two components together or extending each individuality through time
Anyway it's good to have them both, like two Text Tools components
False positives:
Discogs Tagger: Mine: 1.23; Suggested: 1.22
Random pools: Mine: 0.0.1; Suggested: same
Seekbox: 0.0.1; Suggested: same
Biography view: like Tedgo said
[edit] very interesting statistics ,who would think that all that info can be collected in a glimpse
maybe foo_autoupdate should be excluded from popularity list
foo_autoupdate
OK, I've added some better check to the server whether a version is newer or not. Though it's not so easy for all the version format people generate
If it doesn't help, that's what the "Don't show this update anymore function does" - it hides only this particular [foo_component_name, version_suggested] pair.
foo_autoupdate
very nice work. thanks.
i'm liking the stats pages as well.
foo_autoupdate
very impressive for a first launch
i'm following this carefully
many thanks
foo_autoupdate
when are statistics updated?
only on first run?
[edit] OK, it seems that's on every update, so if there are some hardware changes or else component picks them on startup
foo_autoupdate
Very impressive indeed, especially the stats part !
foo_autoupdate
Yeah, it's obvious it will be #1 on its own list
But maybe this obviosity is the reason why I don't find the component distracting there. "Core" is obvious too, but I left it there as well to be able to see its detailed version statistics.
only on first run?
Yes, but that's also why the current calculation might be a bit skewed, all stats sum all input data, not just the latest for one IP or something. I thought that this wouldn't be very evident in the long run, with many submissions. If I was going to change it, it would be rather to sum up the data once a while instead of each time a page is viewed, because the aggregate SQL queries tend to be ugly.
foo_autoupdate
Really nice work there Yirkha  It seems a lot more polished than my attempt, especially for a beta component!
foo_autoupdate
nice, thanks
foo_autoupdate
Both components update managers look nice. Maybe you guys could collaborate and merge the code, creating a better component. In the end Peter might be willing to merge the code into fb2k itself and replace the Troubleshooter. It would certainly increase user satisfaction and might reduce crashes a lot.
foo_autoupdate
Wow, really great component. I prefer downloading the components myself than having a batch moving files without knowing what happens, I like the statistics, and I also like the HTML page that has the same feeling than the other help pages, so this one is perfect for me.
I can't believe it's just a "0 beta".
foo_autoupdate
So, what's the verdict on this component's development?  Will this component continue to be developed alongside fraganator's for the time being, or is it just a proof of concept?
foo_autoupdate
I'm using foobar2000 trough wine, everything works fine except that it doesn't open the browser to see the webpage with the differents links, could you add the link in the window so that we can go to the link manually ?
Sorry for the bad english, I'm french .
foo_autoupdate
well, latest per IP seems interesting too, like real live view, and also maybe component could unique itself per foobar instance
just a thought, as you've probably thinked all out
foo_autoupdate
In the end, he might just create something himself, much tightly integrated to the core, essentially a new component interface with more focus on component management.
Also note that the Troubleshooter is not reporting "updates", it's merely a manually maintained list of problematic component versions based on the feedback from the crash log tracker. If the old version does not crash, it won't help you. The added link is only a good will from Peter to go and search for the updated version.
Good question. I'm not going to pull it, but I'm not going to improve it either.
First because there is nothing I would like to add at the moment - during the time I was evaluating its usefulness and whether to release it, I had a lot of time to remake some parts a few times as I got new ideas and play with many minor details, thinking there is no excuse for not providing people with the optimal user experience. This is why the component might seem quite polished.
Secondly, I can solve minor problems on the server side instead of releasing bugfixes for all people to install. That happened 6 times already and it's a great feeling.
Well it uses the same way to open the file as e.g. Help > Title formatting help, that doesn't work either, right?
Maybe check if [font= "Courier New"]HKEY_CLASS_ROOT\.html\shell\open\command[/font] points to a right place. Or try some [font= "Courier New"]WINEDEBUG[/font] flags like here to know what exactly happens.
Anyway, you can also find the generated log file as [font= "Courier New"]fb2k-au-<timestamp>.html[/font] in the TEMP directory, wherever it is for wine, and open it manually...
Yeah, I didn't include some unique "installation ID", I have a feeling people don't like opaque tracking IDs and things like that, especially as it would be probably sent even with advanced statistics reporting disabled. And I would also have to release a new version now, which I don't want, see above. Some hash for example from IP and a few HW/SW/fb2k variables will probably be almost as good.
I didn't really think the web part of the statistics through much, I'm happy they are online and available now  There probably could be real-time short term statistics for last week (month?), with no duplicate elimination or other processing, and long term statistics with more relativization. I think the whole data set hides much more interesting data, e.g. you could get popularity graphs for individual components in time, or answering questions like "Do notebook users have more autoplaylists than desktop users?". Maybe I should set up a blog for that sometime...
foo_autoupdate
And I would also have to release a new version now, which I don't want, ...
If you ever change your mind about that, you might think about another name
(foo_updatecheck?, foo_updatestats? ).
Oh well, you also released a useful plugin called foo_jesus, so what's in a name afterall.
foo_autoupdate
hm, core isn't on top - someone is playing or 0.9.6.9 isn't reported (I doubt that, but it's strange that non user runs 0.9.6.9) or what?
foo_autoupdate
Did you know some people rename it to foo_backup?
Yeah, it was a glitch, looks as before now. There are no versions older than 1.0 because the component needs 1.0
foo_autoupdate
Thanks for that useful component.
Sorting by status could be helpful for updating "unknown" plugins.
foo_autoupdate
Very useful and I love looking at the stats. Thanks!
However, the fact that the stats are based on the number of requests and not on the number of users means that users who check for updates more often weight more in the stats, right?
foo_autoupdate
Naturally.
Better than "The stats site is under construction"
foo_autoupdate
Great component, very useful!
Just one little thing: it tells me the 1.0 core is newer than the 1.0.1 beta core.
