Topic: Any plugins that give a reverb-y/cave-y/virtual surround-like effects? (Read 3517 times) previous topic - next topic
Hi. I would like to know if there are any plugins that deliver sort of a virtual surround/reverb-y/cavey type effect? I own a broken old Sony portable discman called the D-555. It was top of the line back in the early 90's and had a feature called "Surround sound". It wasn't really true surround sound, but when activated, it would provide this unique reverb-y/echo-y/cave-like sound effect that I really enjoyed, and worked well with some songs I listened to.
Is there anything like that for F00bar? I'm currently using the DFX program via winamp dsp plugin, because it has ambience and 3D Surround Sound sliders, but quite frankly it's not that good.
Possibly this?: freeverb
If not, what sound card do you have?  I'm pretty sure just about every set of sound card drivers has a feature similar to this.
Thanks for the reply. Yeah I have a soundblaster Audigy 2Z PCMCIA card for my notebook. It *does* have the concert hall feature, which sort of delivers that kind of echo-y effect, but when I activate it it causes stuttering and kinda slows my laptop down.
I will take a look at your link though, thanks
as you used foo_dsp_winamp, you can load vst bridge (http://www.winamp.com/plugin/vst-winamp-bridge/146317) in it and use many VSTs from the VST overproduction out there
also I guess izotope ozone fits your description, which is not free and is available as VST or winamp DSP
DFX is build on SRS sandbox AFAIK, useful if you have some low life equipment, in which case buying plugins may seem silly
anyhow I would go for VST
