Topic: Some loud samples (Read 8591 times) previous topic - next topic
Some loud samples
For the thread: http://www.hydrogenaudio.org/forums/index....showtopic=78072
"Merzbow" replay gain -21.04 dB
[attachment=5712:I_Lead_Y...s__live_.flac]
"Garbage" replay gain -13.82 dB
[attachment=5713:Why_Do_Y..._Love_Me.flac]
"AC/DC" replay gain -11.57 dB
[attachment=5714:Let_Me_P...Into_You.flac]
I may remove these quite soon if I need more room.
Some loud samples
I Lead You Towards Glorious Times is live?
I did not know that.
Clearly that had an impact on the sound quality.
Some loud samples
The Garbage excerpt: OMFG, is that really on the CD like that? Even when zooming in on the waveform in my audio editor, I can hardly see any dynamic structure in the waveform. It looks (and sounds) like clipped pink noise.
This is the worst example I have seen so far. What are we doing to our music
Thanks for sharing!
Chris
Some loud samples
A new garbage sample: "Bleed Like Me". The related thread & post: http://www.hydrogenaudio.org/forums/index....st&p=713723
[attachment=5997:Bleed_Like_Me.7z]
The folders and files in the package:
__________________________________________________________________________________________
FOLDER   6000 samples (cymbal crash)\
FILE   6000 samples LAME -V5 decoded to 16-bit int (peaks truncated), adjusted -5dB,  saved to 32-bit float.wav
FILE   6000 samples LAME -V5 decoded to 32-bit float (peaks preserved), adjusted -5dB, saved to 32-bit float.wav
FILE   6000 samples Lossless, adjusted -5dB, saved to 32-bit float.wav
FOLDER   90000 samples (6000 samples looped 15 times) for ABX testing, 16-bit files\
FILE   90000 samples LAME -V5 peaks preserved (looped, dithered, 16-bit).wav
FILE   90000 samples LAME -V5 peaks truncated (looped, dithered, 16-bit).wav
FILE   90000 samples Lossless (looped, dithered, 16-bit).wav
FOLDER   a 7 sec. clip from source track, cymbal crash at 3.5 s\
FILE   LAME -V5 decoded to 16-bit int (peaks truncated), adjusted -5dB, dithered, 16-bit.flac
FILE   LAME -V5 decoded to 32-bit float (peaks preserved), adjusted -5dB, dithered, 16-bit.flac
FILE   Lossless, adjusted -5dB, dithered, 16-bit.flac
Some loud samples
"I Lead You Towards Glorious Times" - now i get it.. that's the NOISE music genre, which is now taking over metal:( - actually..every music genre has been merged into the NOISE GENRE.
WHAT TO SAY? -> WTF OMFG
also.. i'd like to add that in comparison to this: metallica's death magnetic was flawless in terms of audio quality
Some loud samples
So far "I Lead You Towards Glorious Times (live)" has been the loudest commercially released music track that I have seen. It is pretty close to white noise (not all Merzbow tracks are this extreme). The FLAC -8 bitrate of the sample is 1397 kbps.
Here's the screenshot that I posted in the linked thread:
The encoding settings
FLAC: -8
M4A: QT --tvbr 62 --highest
MP4: Nero -q 0.41
MP3: Lame -V5
It is also interesting to see the peak values of the lossy encodings of it. LAME produces a peak value of 2.73. Apparently the VBR encoders don't even try to achieve a more transparent result by radically increasing the bitrate. Perhaps some kind of sanity check kicks in.
