Topic: problem with going through ISA proxy server (Read 1786 times) previous topic - next topic
  • phat
We have ISA proxy server at work. My foobar 1.0 can't get through it.
I checked the checkbox "using proxy server" on "networking" preferences page, I filled the field below, username:password@proxy.***.ru:3128, but when audioscrobbler plugin is trying to submit played tracks it is written in console that
"Proxy Authentication Required ( The ISA Server requires authorization to fulfill the request. Access to the Web Proxy filter is denied.  ) (407)"
The same thing happens with everything foobar wants to do in the Internet: opening playlist, connecting to freedb, etc.
I can't understand what I am doing wrong. I have Last.fm client, it has no problem with getting through the proxy. I typed in proper fields the same data (address, port, username, password), and it worked perfect.
Help me, please.
  • kode54
  • Administrator
The "official" last.fm client probably supports the authentication method required by your proxy server. Possibly some proprietary Microsoft method that's only supported by using Microsoft's libraries, or through some shoddy reverse engineered implementation.
  • phat
Does this mean that foobar doesn't support this method and there's nothing i can do about it?
  • Yirkha
  • Moderator
Yes.
  • sauleen
Yes.
Foobar is still getting the same error with ISA proxys?
