Topic: foobar2000 DeskBand Controls (Read 445891 times) previous topic - next topic
Re: foobar2000 DeskBand Controls
Reply #675
Hi!
Thanks for this addon - great job!
One question: why does the panel close on pause?
I have to open the main foobar window to continue.
When it closes at a stop - it is more or less logical. But on pause obvious that I would like to continue from the same place.
Right click the panel, select "settings". So the "Deskband Controls Settings" window shows up.
On the left, select "foobar2000 plugin",
on the right bottom you will see an option called "Hide if not playing".
Change that from "Yes" to "No" fixes this problem.
Reply #676
Oh! I would never have thought to get in there myself :). Thank you so much!
Reply #677
I'm also getting that .net error message. It happens consistently when I switch back from another Windows user account. That's the first time I've ever encountered this error message but now it happens every time.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.InvalidOperationException: Collection was modified; enumeration operation may not execute.
   at System.ThrowHelper.ThrowInvalidOperationException(ExceptionResource resource)
   at System.Collections.Generic.List`1.Enumerator.MoveNextRare()
   at dcmFoobar2000.Code.Controller.DestroyControls()
   at dcmFoobar2000.Code.Controller.RegisterControls()
   at dcmFoobar2000.Code.Controller.ApplyConfiguration()
   at dcmFoobar2000.Code.MessageForm.FireEvent[T](EventHandler`1 eventHandler, T eventArgs)
   at dcmFoobar2000.Code.MessageForm.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.8.4075.0 built by: NET48REL1LAST
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
Deskband
    Assembly Version: 3.6.1.0
    Win32 Version: 3.6.1
    CodeBase: file:///C:/Program%20Files/DeskbandControls/Deskband.DLL
    Win32 Version: 4.8.4042.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    Win32 Version: 4.8.4001.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    Win32 Version: 4.8.3752.0 built by: NET48REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Deskband.Core
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files/DeskbandControls/Deskband.Core.DLL
Ninject
    Assembly Version: 3.3.4.0
    Win32 Version: 3.3.4.0
    CodeBase: file:///C:/Program%20Files/DeskbandControls/Ninject.DLL
System.Configuration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
dcmFoobar2000
    CodeBase: file:///C:/Program%20Files/DeskbandControls/dcmFoobar2000.DLL
Anonymously Hosted DynamicMethods Assembly
    Assembly Version: 0.0.0.0
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/mscorlib/v4.0_4.0.0.0__b77a5c561934e089/mscorlib.dll
Accessibility
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
Newtonsoft.Json
    Assembly Version: 10.0.0.0
    Win32 Version: 10.0.3.21018
    CodeBase: file:///C:/Program%20Files/DeskbandControls/Newtonsoft.Json.DLL
System.Numerics
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
System.Runtime.Serialization
    Win32 Version: 4.8.3825.0 built by: NET48REL1LAST_B
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
System.Data
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Reply #678
Happy New Year guys!
Here is a teaser of next version main feature. Your thoughts are welcome.
Reply #679
Version 3.7.0
  + Added peakmeter. 8)
  - "Deskband Mode" options now merged into one named "Display Mode".
  - Added mouse wheel "None" mode.
  - Possible crash fix when changing DPI and recreating controls.
  - Added formatting support to Stopped Text.
  - Updated foobar2000 SDK to the latest version.
  - Updated all projects to .NET Framework 4.8 and VS2019.
Reply #680
Hi.  I really love your component and couldn't live without it.  But I'm having a problem with installing the new version.  It successfully installed in Foobar, but I get an error from windows that the taskbar toolbar is expecting version 6.1 but finding 7.0.  I can turn the toolbar on and off, but I can't delete it to see if a fresh install would work.  Fortunately I had saved version 6.1 so I'm up and running again.  Buy I would really like to try the new version.  Any ideas?
Reply #681
Any ideas?
 Hi! Try to uninstall old version manually by running uninstall.cmd from Program Files/Deskband Controls folder. Right-click it and select "Run as administrator". You may have to launch task manager after that using Ctrl+Shift+Esc and run explorer.exe to get back to desktop.
Reply #682
That worked.  Thank you very much.  I love the peak meter!
Reply #683
Great addon! Is it possible to, Peak Meter separate horizontal and vertical floating window?
Reply #684
Version 3.7.0
Hi and thanks for the update!
Unfortunately, after successfull installation of the update,
the album-art is now showing at the bottom at my taskbar, while it was at the top before.
My taskbar is on the right side of the desktop, the album art was straight under the windows7 logo.
now the artwork is above the systray.
How to get it up again?
It seems I cannot move it. I tried eveything from this helpful post, but it does not work this time.
Also, after fiddling with the options, I get this:
Informationen über das Aufrufen von JIT-Debuggen
anstelle dieses Dialogfelds finden Sie am Ende dieser Meldung.
************** Ausnahmetext **************
System.InvalidOperationException: Error loading Ninject component ICache
No such component has been registered in the kernel's component container.
Suggestions:
  1) If you have created a custom subclass for KernelBase, ensure that you have properly
     implemented the AddComponents() method.
  2) Ensure that you have not removed the component from the container via a call to RemoveAll().
  3) Ensure you have not accidentally created more than one kernel.
   bei Ninject.Components.ComponentContainer.Get(Type component)
   bei Ninject.Components.ComponentContainer.Get[T]()
   bei Ninject.KernelBase.CreateContext(IRequest request, IBinding binding)
   bei Ninject.KernelBase.<>c__DisplayClass40_0.<Resolve>b__6(IBinding binding)
   bei System.Linq.Enumerable.WhereSelectListIterator`2.MoveNext()
   bei System.Linq.Enumerable.<CastIterator>d__97`1.MoveNext()
   bei System.Linq.Enumerable.WhereSelectEnumerableIterator`2.MoveNext()
   bei System.Linq.Buffer`1..ctor(IEnumerable`1 source)
   bei System.Linq.OrderedEnumerable`1.<GetEnumerator>d__1.MoveNext()
   bei Deskband.UI.ModuleContainer.UpdateModules(IEnumerable`1 moduleSizeInfo, Boolean drawBorders, LayoutMode layoutMode)
   bei Deskband.App.ApplyConfiguration()
   bei Deskband.App.<>c__DisplayClass12_0.<Run>b__12(Object s, EventArgs e)
   bei Deskband.Settings.SettingsForm.BtnApply_Click(Object sender, EventArgs e)
   bei System.Windows.Forms.Control.OnClick(EventArgs e)
   bei System.Windows.Forms.Button.OnClick(EventArgs e)
   bei System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
   bei System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   bei System.Windows.Forms.Control.WndProc(Message& m)
   bei System.Windows.Forms.ButtonBase.WndProc(Message& m)
   bei System.Windows.Forms.Button.WndProc(Message& m)
   bei System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Geladene Assemblys **************
mscorlib
    Assembly-Version: 4.0.0.0.
    Win32-Version: 4.7.3416.0 built by: NET472REL1LAST_B.
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll.
Deskband
    Assembly-Version: 3.7.0.0.
    Win32-Version: 3.7.0.
    CodeBase: file:///C:/Program%20Files/DeskbandControls/Deskband.DLL.
    Win32-Version: 4.7.3324.0 built by: NET472REL1LAST_C.
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll.
System
    Win32-Version: 4.7.3451.0 built by: NET472REL1LAST_C.
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll.
System.Drawing
    Win32-Version: 4.7.3221.0 built by: NET472REL1LAST_C.
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll.
Deskband.Core
    Assembly-Version: 1.0.0.0.
    Win32-Version: 1.0.0.0.
    CodeBase: file:///C:/Program%20Files/DeskbandControls/Deskband.Core.DLL.
Ninject
    Assembly-Version: 3.3.4.0.
    Win32-Version: 3.3.4.0.
    CodeBase: file:///C:/Program%20Files/DeskbandControls/Ninject.DLL.
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll.
System.Core
    Win32-Version: 4.7.3429.0 built by: NET472REL1LAST_C.
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll.
System.Xml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll.
dcmFoobar2000
    CodeBase: file:///C:/Program%20Files/DeskbandControls/dcmFoobar2000.DLL.
    Assembly-Version: 0.0.0.0.
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/mscorlib/v4.0_4.0.0.0__b77a5c561934e089/mscorlib.dll.
Accessibility
    Win32-Version: 4.7.3062.0 built by: NET472REL1.
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll.
Newtonsoft.Json
    Assembly-Version: 12.0.0.0.
    Win32-Version: 12.0.3.23909.
    CodeBase: file:///C:/Program%20Files/DeskbandControls/Newtonsoft.Json.DLL.
System.Numerics
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll.
    Win32-Version: 4.7.3440.0 built by: NET472REL1LAST_B.
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll.
System.Data
    Win32-Version: 4.7.3260.0 built by: NET472REL1LAST_C.
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll.
System.Windows.Forms.resources
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_de_b77a5c561934e089/System.Windows.Forms.resources.dll.
System.Design
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Design/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Design.dll.
System.resources
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.resources/v4.0_4.0.0.0_de_b77a5c561934e089/System.resources.dll.
System.Drawing.Design
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing.Design/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.Design.dll.
Microsoft.VisualBasic
    Assembly-Version: 10.0.0.0.
    Win32-Version: 14.7.3062.0 built by: NET472REL1.
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll.
Microsoft.VisualBasic.resources
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic.resources/v4.0_10.0.0.0_de_b03f5f7f11d50a3a/Microsoft.VisualBasic.resources.dll.
mscorlib.resources
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_de_b77a5c561934e089/mscorlib.resources.dll.
************** JIT-Debuggen **************
Um das JIT-Debuggen (Just-In-Time) zu aktivieren, muss in der
Konfigurationsdatei der Anwendung oder des Computers
(machine.config) der jitDebugging-Wert im Abschnitt system.windows.forms festgelegt werden.
Die Anwendung muss mit aktiviertem Debuggen kompiliert werden.
Zum Beispiel:
<configuration>
</configuration>
Wenn das JIT-Debuggen aktiviert ist, werden alle nicht behandelten
Ausnahmen an den JIT-Debugger gesendet, der auf dem
Computer registriert ist, und nicht in diesem Dialogfeld behandelt.
Reply #685
Hi!
Set "Deskband Mode" option to "Floating Deskband". Click OK. Right-click taskbar, and from toolbar submenu click Deskband Controls to remove it. Right-click it again and make sure that "Lock the taskbar" is not checked (you shoud see drag handles next to the start button). Than right-click it again, and from toolbar submenu click Deskband Controls to show it. You should be able to drag it to the top now.
Reply #686
 Hi! I do not understand what you are trying to say, please explain in more details.
Reply #687
For example, the peak meter is in a vertical or horizontal position in the upper left or right corner of the screen, but the deskband remains attached to the taskbar. In other words, make the floating window only for Peak Meter.
Reply #688
Thank you very much!
 I was sure, I had this done before, but now, after a 2nd try, it worked!
Reply #689
Hi.  I just came across something odd with the latest version.  If the active playlist is different from the playing playlist Foobar crashes when I either stop (from Deskband or within Foobar itself) or close Foobar.  I copied the text below from the error report which is why I think the problem may be with Deskband.  I don't have this situation very often so I can live with it, but I thought you should know.
Crash location:
Module: foo_deskband_controls
Offset: 3F02h
Reply #690
Version 3.7.1
Various bugfixes. Please update.
Reply #691
Hi. Recently I updated my display to large 4K one with scaling set to 300% in Windows 10. Component scales pretty well but the buttons are blurry and hand on seekbar is sometimes too small. Other times Settings window is too small. Text also scrolls slower and when I increase the speed it doesn't scroll as smooth as before. (Scroll Step is set to 1.)
Any way to fix that? Or can I do something to fix that?
Reply #692
 Hi! You could try to change button icons to the hi-res versions. As for the other issues I have no solution for now.
Reply #693
Version 3.7.1
after updating, I got this (screenshot).
Before I was asked (by the components DOS window prompt installer) to overwrite some DLL or something, which I answered with Yes.
f2k is playing music now, the deskband-"window" is shown where I want it to be shown, but no cover art is shown. Only stub image, which I have configured.
Reply #694
fuffi - something is wrong with your installation. after update and foobar2000 restart it should prompt for UAC confirmation and update required files. it looks like this process is not working on your system, so you have to do it manually using uninstall.cmd. Installation is tested on many PCs and clean versions of Win7 and Win10, so you must have something in your system changed that is affecting installation.
Reply #695
Thanks (for the quick reply), simply restarting f2k did the job (thank god it was so simple).
(after f2k restart, your install screen popped up again, doing some work and after that, I pressed the any key to continue, it worked again....)
You coded a great install-routine :-)
Reply #697
Deskband Controls 3.7.1, windows 10, foobar 1.5.1.
After updating to version 3.7.1 and switching visibility option of peak meter to No, there is a vast empty space in deskband controls. I left Drawing Borders set to Yes, so it's clearly visible, what area deskband occupies. Setting Peak Meter width to 0 doesn't help.
See attached images.
How to reclaim this space? It's really like 250pxs of wasted space.
Reply #698
Hi nosmo!
Navigate to settings - foobar2000 plugin node and there is a setting for the deskband width.
Reply #699
Hi nosmo!
Thanks, that helped, would be better if done automatically - whenever user turns on/off peak meter visibility the size should be adjusted ;-)
Anyway thx for good work, i'm using Deskband Controls for years..
