Topic: foobar2000 DeskBand Controls (Read 474352 times) previous topic - next topic
Re: foobar2000 DeskBand Controls
Reply #800
does anyone know a workaround for 24H2? I mean, I saw previous message. But how can we control play/pause now? Any popup windows or smth?
Reply #803
^ I only have Win10. :D  If you set the flowin window to View > Flowin > [name] > 'Always on top', and set a Preferences > Keyboard Shortcut to View > Flowin > [name] > 'Bring to top' (and tick 'Global' to make the shortcut work everywhere) - does hitting the shortcut work to bring it on top of the taskbar?
The problem is it will never stay on top when you interact with the taskbar, thanks to Windows and the way they work (assuming Win11 is like Win10 in this regard) ... I have a bad idea to solve that but see if the keyboard shortcut is a good enough workaround for you, if it works...
Reply #804
nah.. doesn't work. only when foobar is using. I just don't know where to set it, the first place was right above the clocks, but then I remembered about notifications, so it overlaps.
Reply #805
upd: forgot to set as global. Yes, it works fine.
