Topic: [MORE TOS8 CLUELESSNESS] From: WASAPI Output Plugin 'Maiko' (V (Read 1787 times) previous topic - next topic
  • radi6404
I am trying the plugin out right now and it sounds way better than directsound.
  • Last Edit: 22 January, 2010, 09:08:52 AM by radi6404
  • rpp3po
You should read the TOS before spreading such bullshit. Since Vista DirectSound output at 100% volume is bitperfect. 1s are 1s and 0s are 0s. There is no "better" and "worse", it is identical (as long as you don't enable quality degrading options in you driver's control panel that could be disregarded in the case of ASIO).
A shared mode WASAPI plugin may have other advantages, though. For example, the application can be sure wether its output is left untouched by sample rate conversion, since it has to comply to the bitrate requested by WASAPI.
  • Last Edit: 22 January, 2010, 09:46:29 AM by rpp3po
  • radi6404
I am not looking for bitperfect sound, I am looking for sounded sound, I have way too cheap equipment (400 € speakers and amp) where bitperfect sound would be good, so stop insulting and attacking me personally, next time you insult me I won´t hesitate to insult you back or even report you. I am using Windows 7 and I read the Terms of Service (especially #8), but a lot of people can't afford good soundhardware and have to use 400 € shit instead of 1000€ quality in order to disable all sounding and use bitperfect sound.
  • Last Edit: 22 January, 2010, 10:26:47 AM by radi6404
  • lvqcl
So you "must provide objective support" for your statement. Where is it?
