Topic: AIF to MP3 with sample rate conversion on Linux Command Line (Read 7206 times) previous topic - next topic
Okay,
On a linux box I want to go directly from AIF files to MP3 files with down conversion of sample rate and conversion to mono.
My normal LAME setting is:
lame -b 40 -m m --resample 22.05 -S infile outfile
With SOX I usually use:
sox infile.aif outfile.wav
I'd like to merge the two into one command line function for programatic reasons.
Something like:
sox  'infile.aif' - | lame -b 40 -m m --resample 22.05 -S - 'outfile.mp3'
But when I do, I get errors. With the '-' on the SOX side, I get "sox FAIL formats: can't determine type of `-' ". If I leave out the dash, I get "sox FAIL sox: Not enough input filenames specified"
I'm fairly new to SOX and LAME, so I'm sure I must be missing something simple. ?? or am I??
While I'm just a Windows user, I don't think you're using sox correctly.
Try something like this:
sox -t aiff 'infile.aif' -t wav - | ...
Try LAME compiled with libsndfile. It should read AIFF files (and it doesn't support pipes).
Hey GreyNol,
You are TOP MAN. I have been scratching my head for a day or two with SOX and couldn't get the format right. You solved my problem!! MANY THANKS INDEED. The double -t option worked. Again thanks.
LOL being 'just' a Windows user - you should be promoted to Unix User!!
Azhar
