Topic: WSH Panel Mod script discussion/help (Read 1425712 times) previous topic - next topic
0 Members and 8 Guests are viewing this topic.
Reply #4201
it *might* rock if we could see it. it's currently private...
Reply #4203
no album art in the group headers... i guess that slows it down??
Reply #4204
WOW!!! Smoother than a fresh jar of Skippy
BTW any release date on JSBrowser ??
Reply #4205
not added yet but it shouldn't, the main thing that was blocking me to use a such scroll engine is now fixed and is faster to populate and to evaluate than ever, all the rest to do is peanut compared to this point ...
Reply #4207
nice.
will it include the new edit menu undo/redo function i included in WSH panel mod 1.5.10? you basically call plman.UndoBackup(playlistIndex) before adding/removing/re-ordering playlists with other plman methods. i can post more details if you need it. if you do this, you can create ctrl+z (undo) and ctrl+y (redo) keyboard shortcuts.
Reply #4208
nice.
why not
Reply #4211
Is it possible to add shortcut to get back to last activated playlist (like a back button)
Reply #4213
since I couldn't edit my previously post, had to reply...
Anyone knows what might be causing this?
Windows 7 x64
Foobar2000 v1.3.8
Reply #4214
@ZarkBit
as discribed in its homepage : JSPlaylist @deviantart
[Requirements]
* foobar2000 v1.1 or better >> www.foobar2000.org
* WSH panel Mod v1.5.6 or better >> code.google.com/p/foo-wsh-pane…
* Windows fonts : WingDings 1, 2 & 3
[/Requirements]
[Options]
* Font guifx v2 transports >> blog.guifx.com/2009/04/02/guif…
[/Options]
HTH
Reply #4215
thx, didn't notice that. Solved.
Reply #4216
well the old last.fm website has gone. common7/8 script users will find last.fm bio and thumbs no longer work no longer update. of course they will continue to display all previously cached data.
other stuff like similar artists, charts, playcount sync all use the API so should continue to work as they did before.
Reply #4217
Hi Marc,
A small question.
Is it possible that last.fm bio and thumbs script rewrite for theaudiodb.com?
best regards
Reply #4219
but.... theaudiodb sucks.
Reply #4220
i've updated the user recommendations part of my last.fm script so it's more suitable for narrow panels. it also supports the new last.fm website format for artist bios.
https://github.com/19379/wsh_marc2003/releases
Reply #4221
Why you don't want to update Thumbs, just change one line:
for (i = 0; i < data.length; i++) {
                        if (data[i].src.indexOf("http://img2-ak.lst.fm/i/u/60x60/") == 0) urls.push(data[i].src.replace("60x60", size == "low" ? "252x252" : size == "medium" ? "500x500" : size == "high" ? "_" : "_"));
Reply #4222
Local last.fm sites don't work in the new Biography script.
mire777, I'm gonna check it. ( ͡° ͜ʖ ͡°)
Reply #4224
marc2003, just changed those lines and it works fine. Thank you.
mire777, yep, the code works, but it downloads images "as is" - without file extensions.
Or we can add ".jpg" and then all images will be .jpg files. :]
p.run_cmd(this.vbs + " " + url + " " + file + ".jpg", false);
