Topic: WSH Panel Mod script discussion/help (Read 1423622 times) previous topic - next topic
Reply #3575
theophile has stopped developing wsh panel mod for years but his work still alive ...
theophile??? is that T.P Wang
surprising....
not really. it's only 2 years since he stopped but plenty of people are using columns UI which is over 5 years old. some of ssenna's components haven't been updated since 2009/2010 either. yet they all still work fine.
Reply #3576
oh yes, and sorry i failed to mention it. it's said that he hasn't been developing windows app for a long time. maybe we should thank jensen & dreamxis that they decided to create a beautiful foobar profile with ssenna's elplaylist and pss and theo made their work(named Eiko) more complicated. it was in 2006, nearly 10 years from now...
i really admire ssenna's works... and am worried if one day his/her components won't be compatible with foobar2000, that ll be  great loss. nobody at the forum can get contact with him/her?
A rose will bloom, it then will fade.
Reply #3577
I was tried to contact ssena earlier, when foo_ui_biography.dll stopped to receive full biography from last.fm , but i never get an answer..
Don't know if he loose interest for this components?
But this will happen sooner or later, that some components die, if we don't have support team..
This plugins are essential for foobar i think, and more than one developer should work on this...
Reply #3578
[...] But this will happen sooner or later, that some components die, if we don't have support team..
I've made plenty of noise on IRC about some of these components lack of maintenance and how they should have 'official' versions in future versions of foobar2000. Not just WSH but also things like Facets, TagBox, and others. Some should be genuine candidates for inclusion as stock items.
EDIT: Mainly so they do not die from lack of developer interest over time.
Reply #3579
anybody could develop/update WSH panel mod if they wanted to. it has a public domain license and the source code is available. unfortunately it seems the only people interested in the component don't have the c++ skills necessary to do that.
Reply #3580
My folder marc2003 look like this, it's not a problem ? I have older scripts because i don't want update for example "now playing", but i don't now if it's a problem or not
no, it shouldn't be a problem. that's why i rename files when there are major changes so all scripts should work side by side. i'd try and get rid what is using common6 though - that is seriously old. but i suppose if it's not using anything online then it'll be fine.
you can save a whopping 8kb by deleting that file named art. that has been obsolete for quite some time now.
I use common6 for "Now Playing" (artists images) because i don't want to change the layout of the frame and I do not know how to upload keeping available layout
Reply #3581
I've noticed that when using VU Meter component jscript by Br3tt that I have a large amount of memory "leakage" ... When I start foobar it will use about 25 mb of memory ... but then its memory usage will grow over time to 30 mb .. 40 mb .. 70 mb ..100 mb.
I wasn't sure at first the cause of the problem and started eliminating panels in order to identify the source of the problem.  Eventually, I stripped all of my foobar panels down to only two:
  - Br3tt's wsh_playlist_2013_v0_0_8
  - Br3tt's VU Meter component 1.01
With the playlist panel only installed, I do not see the large growth in memory usage over time.  But immediately after installing the VU meter component (without any mods), I get the memory usage growth.  So it seems that the VU meter code is causing the memory usage growth.
I do not see any obvious changes to improve the code (but my skills are very limited) ... Is there a change in the code that can reclaim the "lost" memory?
Reply #3582
I have the "sox" folder in marc2003, it is better that I moves in foobar2000 (appdata)? Or I change the script and adds
var sox_exe = fb.ProfilePath + "marc2003\\sox\\sox.exe";
var ffmpeg_exe = fb.ProfilePath + "marc2003\\sox\\ffmpeg.exe";
Or I have to do differently?
Because I do not know if other scripts use that path or not ...
Reply #3583
you can edit those values and put sox/ffmpeg wherever you like.
Reply #3584
Okay only those 2 lines need edit ? And I edited as it should ?
Why i haven't Bio ? After it's all i have no problem ^^
Pastie of script : http://pastie.org/private/g2laf7wjyqrsesrv1k3uw
Reply #3585
yes it's only those 2 lines. if it was any more, i would have told you. i don't expect you to be psychic.  the simplest check is to play a supported file. if the panel is blank then something is wrong. if you see a spectrogram image then it's working.
bios are online so i suspect that is the problem. i'm not supporting scripts that old now. my latest now playing script works if you want to try that. if not, then remove it/use something else.
Reply #3586
I try the new script and same problem :
Reply #3587
can you see if any of these scripts work in another panel?
allmusic review
last.fm similar artists
last.fm & wikipedia biography
musicbrainz
news-reviews-blogs
i just want to see if any internet scripts are working on your machine. also, have a look in the foobar console for errors (view menu>Console).
Reply #3588
allmusic review
musicbrainz
news-reviews-blogs
allmusic review blank (no text, samples 8) EDIT: After works fine
last.fm similar artists works fine (samples8)
last.fm & wikipedia biography i have pictures but no bio (samples 8 & oldest)
musicbrainz works fine (samples8)
news-reviews-blogs works fine (samples8)
Pastie of console, maybe you can see any problems, if there are more than the ones I talk to you :
http://pastie.org/private/3jkpwcuxwzna4byob5xqqa
Reply #3589
can you open your wsh_data folder in explorer and use the search box in the top right to look for
bio*.txt
are there any results and do they contain any text if you open them in notepad? also, what language are you using? i notice from your console you might be french based on your music folder name??? have you set the panel to use the french last.fm site? it should still work but you may get no results for less popular artists. obviously you can check this by looking at the artist page on the website.
Reply #3590
bio*.txt
That is, when in fact I do not have the choice of language in the script, some .txt are empty, but if I take the example of Lady Gaga that contains text in French, I still have nothing
Reply #3591
you do. from the filename i can see in your screenshot, you've selected the french site (www.lastfm.fr) from the available options.
anyway, it seems the download part is working so i can't really explain why it's not being displayed. perhaps the script doesn't like your default font? i can't think of anything else.
Reply #3592
My Font is Calibri, someone use this font and :
Reply #3593
having looked at that image again, perhaps the text area is too narrow? my script requires the text area be at least 100 pixels wide.
Reply #3594
//setup text area for last.fm bio
var t = new text(20, 150, 100, 100);
Don't work ^^
Reply #3595
the values set at the start don't stick - they are updated dynamically inside the on_size function for when the panel is resized. i think the default is something like the panel width divided by 3. if the panel is too narrow then you'll have the problem.
Reply #3596
I tried on another screen, it works well :
I can not seem to "expand" the black frame height
And then I'd like to change the frame size, but I do not have the arrow that allows me to change the window size
Is it that I could have the text in French on the old "script"?
Reply #3597
i give up. use foo_uie_biography instead.
Reply #3598
I've edit too late^^
