Topic: WSH Panel Mod script discussion/help (Read 1425030 times) previous topic - next topic
0 Members and 8 Guests are viewing this topic.
Reply #2750
@falstaff, i noticed a little display glitch in your duitunes top panel. it happens for tracks with over an hour remaining....
Reply #2751
@foomark, i'm past caring what people do with these scripts. i've lost count of the times people have modified them so they don't even work properly and then post them on DA.
Got it, thank you, i'll report him!
@falstaff: your wsh album view panel is fantastic!! I'd pay to have a version that follow the selected item in library
Reply #2753
^a quick question for you: are there any changes worth mentioning between the WSH playlist in your new theme and 0.0.8?
Reply #2754
no significative changes, you can keep 0.0.8 for now. My next challenge, a playlist viewer with the same smooth scrolling as my Album View panel, will give more like to it
Reply #2755
Hey guys hopefully someone can help me with this, Marc? Haha.
I'm trying to give my friend my foobar layout. I've given it to another friend and it's worked fine, I've also copied it from my home computer to my work one and it works fine.
It's a portable install, so I'm just saving the foobar folder as a zip and sending it to my friend.
When he opens it though, all of his scripts crash.
This is what it should look like:
This is what he gets:
Not sure why it's only happening to him but not me and my other friend.
I just did a quick search of the thread and found that the error is the same as the one mentioned by ninjasilver. I've told my friend to do 2 slashes // in front of "//this.doc = new ActiveXObject("htmlfile");" hopefully that does the trick.
Reply #2756
Unexpected error code 0x800700b6
i have no idea. if my scripts are at fault, i usually get meaningful errors. that might indicate a problem with the component itself or maybe even their windows install. but i'm just guessing....
i can also see it's code on line 1297 causing the problem but it isn't anything meaningful on my current version so i'm guessing it's slightly earlier?? as a workaround, it might be possible to comment it out if it's not required by the panels in the layout. you can either check what code is actually on line 1297 and report it. or you could just download the latest common7.js and save it inside the marc2003 folder. restart foobar and then error line number would change to what i've got here.
https://dl.dropboxusercontent.com/u/2280132...2003/common7.js
Reply #2757
Yep, commenting out the line worked, as it did for ninjasilver. I should've searched this thread more thoroughly.
Thanks heaps marc, you always reply so quickly.
Reply #2758
i searched but didn't find anything. at least you got it sorted.
BTW, my current version doesn't include that line by default so it won't crash for all scripts like it did before. it's just last.fm album info and news-reviews-blogs that require that function and it's all only created when required.
Reply #2759
samples updated: simple volume, simple seekbar, nyan cat seekbar, themed seekbar, spectrogram seekbar. added mouse wheel support.
scripts inside the panel need updating manually so a full download is required.
https://dl.dropboxusercontent.com/u/22801321/wsh/samples.zip
files changed:
marc2003\common7.js
samples\nyan cat seekbar.txt
samples\simple seekbar.txt
samples\simple volume.txt
samples\spectrogram seekbar.txt
samples\themed seekbar.txt
Reply #2760
Marc, will you consider to add 'google and yahoo' image server for thumbs? I test this 2 sources for me, and works almost like last.fm. Images are the same quality. I didn't recieve any image that not artist. I think that this is ok as alternative source, if something happen with last.fm..
Maybe i'm not doing this properly, so i would like that you do this ,as it should..
Sorry if i'm bothering you with this..
Reply #2761
i disagree. images on the left were from your code snippet. i don't think they'd look very good made to fill my panel. yes, last.fm is a bit slow but there options for smaller images which is much faster if people are prepared to compromise.
well i found plenty. i suppose you can modify the search term by adding artist/band/musician etc. but i'm just not interested. you can of course do what you like.
Reply #2762
Ok Marc, thanks a lot. Yes, i add posibility to enter custom search terms in properties. My problem is only in html, i must to point script to go in ''a>href'' tag,  and inside that is a path for full image size. but that string looks like this: hlj:fjoddfnaDBOVHFRS34[path]HFfjosofiodppdff. And it is not static. Don't now how to tell script to read only that part in the middle, and to download image from there?
I have only low image from: ''img>src''. Must to do something with that..
Reply #2763
2marc2003
I switched to windows 8.1, I previously worked on windows 7.
I copied the folder c:\program files (86)\foobar2000 and c:\users\my name\appdata\rouming\foobar2000 to the new location.
With new OS player works fine, except that the window with the script "now playing" stopped to load images from the website last.fm.
In the same configuration on windows 7, these images are loaded fine.
What is the reason?
Reply #2764
the OS is irrelevant so that shouldn't be the issue.
but there have been changes at last.fm recently meaning any script not updated since 20th october won't work. right click panel>Update script if you need to.
also, you should check the automatic download setting is on. this setting should be remembered if you transferred your old config but it's worth double checking. i assume it's still displaying all your previously saved images ok? that's because they should have been inside your foobar2000 profile folder.
Reply #2765
marc2003
automatic download setting is on - of course.
I start foobar2000 on win 8.1  (your scripn at 12.11.2013 - last), images not download.
Then copy  foobar2000 and profile folders to win 7, now I start foobar2000 on win 7 (configuration from  win 8.1  ), images download fine.
i assume it's still displaying all your previously saved images ok?  - Yes, old playeyd on win 7 songs  displayed fine, when I play its on win 8.1.
This is wsh_lastfm/3052340555 folder from win 7.1 (displayed)
artist.getInfo_mod.json
{"response": {"status": {"version": "4.2", "code": 0, "message": "Success"}, "start": 0, "total": 2, "biographies": [{"text": "Linda is a russian singer performing trip-hop with ethnic influences. She was born on April 29, 1975 in Kentau, Kazakhstan. Her real name is Svetlana Geyman. Linda's family has later moved to Togliatti, then to Moscow, Russia.   1993: Linda releases her breakthrough debut album \"Песни Тибетских Лам\" (\"Pesni Tibetskih Lam\" - \"Songs of Tibetan Lamas\"), followed by a remix album \"Dances of Tibetan Lamas\". She surpasses her debut with her next album (her biggest selling to date) - \"Ворона\" (\"Vorona\" - \"Crow\"). The album achieves unprecedented popularity in Russia and every single from \"Vorona\" reaches number 1 in Russian charts.  During the \"Vorona\" era, Linda maintains a mysterious and exotic public image . She tells the media about her mystic experiences, music and her attitude to food (\"if I could, I wouldn't eat at all\"). Linda achieves commercial success with her producer Maxim Fadeev, who will later record his own album, resembling his work with Linda.  1999: Linda's third album, \"Плацента\" (\"Placenta\"), is released. The album is darker and more personal, as Linda describes in an interview. However, she is subsequently dropped by her record label and producer due to financial issues.  2001: Linda signs to a new label, BMG and releases her fourth album \"Зрение\" (\"Zreniye\" - \"Vision\" or \"Sight\"). The overall sound becomes more electronic, guitar-driven and with nonsense lyrics. Due to low sales, Linda gets dropped by her label again.  2003: Linda signs a record deal with Universal. The promo single \"Цепи и Кольца\" (\"Chains and Rings\") is subsequently released, along with an English version. The single achieves moderate success, but does not match \"Vorona\"'s sales.  October, 2004: her fifth album \"АтакА\" (\"AtakA\" - \"Attack\") is released. The album is recorded with the some of the best producers and showcases another change in Linda's sound. \"AtakA\" goes on to sell 100,000 copies in the first 2 weeks in Moscow alone.   Fall of 2005: Linda promots \"AtakA\" in London. There are rumors about Linda's plans to collaborate with Moby and Björk, but they are never confirmed.  December 2005: Linda starts working with a new producer from Greece, who is offered to pick one artist from Universal to work with. After listening to all artists' demos he chooses Linda. 2 tracks are thus recorded for the new album.  March 2006: Linda's new single \"Я Украду\" (\"Ya Ukradu\" - \"I Will Steal\") becomes her biggest airplay hit since \"Беги\" (\"Begi\") from \"AtakA\" in 2004.   October 2006: Linda's sixth album \"АлеАда\" (\"AleAda\") is released.   Linda later parted with her old style and collaborated with Stefanos Korkolis. She can be found on the web using the name Linda Geyman. Their band is called Bloody Faeries.", "site": "last.fm", "url": "http://www.last.fm/music/%D0%9B%D0%B8%D0%BD%D0%B4%D0%B0/+wiki", "license": {"type": "cc-by-sa", "attribution": "Last.fm", "attribution-url": "http://www.last.fm/music/%D0%9B%D0%B8%D0%BD%D0%B4%D0%B0/+wiki", "url": "http://creativecommons.org/licenses/by-sa/3.0/", "version": "3.0"}}, {"text": ".. ..................One Linda (Линда) was born on April 29th, 1975 ...", "site": "myspace", "url": "http://www.myspace.com/zrenie", "license": {"type": "unknown", "attribution": "myspace", "attribution-url": "http://www.myspace.com/zrenie", "url": "n/a", "version": "n/a"}, "truncated": true}]}}
and this is new folder 961077930 (created in win 8.1)
{"response": {"status": {"version": "4.2", "code": 0, "message": "Success"}, "start": 0, "total": 11, "biographies": [{"text": "Dire Straits emerged during the post-punk era of the late ...", "site": "aol", "url": "http://music.aol.com/artist/dire-straits/biography", "license": {"type": "unknown", "attribution": "aol", "attribution-url": "http://music.aol.com/artist/dire-straits/biography", "url": "n/a", "version": "n/a"}, "truncated": true}, {"text": "Dire Straits emerged during the post-punk era of the late ...", "site": "mtvmusic", "url": "http://www.mtvmusic.com/dire_straits", "license": {"type": "unknown", "attribution": "mtvmusic", "attribution-url": "http://www.mtvmusic.com/dire_straits", "url": "n/a", "version": "n/a"}, "truncated": true}, {"text": "Dire Straits were a british rock band from Newcastle, United Kingdom,  formed in 1977 by Mark Knopfler (guitar and vocals), his brother David Knopfler (guitar), John Illsley (bass), and Pick Withers (drums), and subsequently managed by Ed Bicknell. Dire Straits emerged during the post-punk era of the late '70s, and while their sound was minimalistic and stripped down, they owed little to punk. If anything, the band was a direct outgrowth of the roots revivalism of pub rock, but where pub rock celebrated good times, Dire Straits were melancholy. Led by guitarist/vocalist Mark Knopfler, the group built their sound upon the laid-back blues-rock of J.J. Cale, but they also had jazz and country inflections, occasionally dipping into the epic song structures of progressive rock. The band's music was offset by Knopfler's lyrics, which approximated the winding, stream-of-conscious narratives of Bob Dylan. As their career progressed, Dire Straits became more refined and their new maturity happened to coincide with the rise of MTV and the compact disc. These two musical revolutions from the mid-'80s helped make Dire Straits' fifth studio album, Brothers in Arms, an international blockbuster. The band - along with Eric Clapton, Phil Collins, and Steve Winwood - became one of the leaders of a group of self-consciously mature veteran rock & rollers in the late '80s that designed their music to appeal to aging baby boomers. Despite the band's international success, they couldn't sustain their stardom, waiting a full six years to deliver a follow-up to Brothers in Arms, by which time their audience had shrunk significantly.  Knopfler (born August 12, 1949) was always the main force behind Dire Straits. The son of an architect, Knopfler studied English literature at Leeds University and worked briefly as a rock critic for the Yorkshire Evening Post while at college. He began teaching English after his graduation, leading a pub rock band called \"Brewer's Droop\" at night. By 1977, Mark was playing with his brother David (guitar) and his roommate John Illsley (bass). During the summer of 1977, the trio cut a demo with drummer Pick Withers. A London DJ named Charlie Gillett heard the demo and began playing \"Sultans of Swing\" on his BBC show Honky Tonkin'. Following a tour opening for Talking Heads, the band began recording their debut for Vertigo Records with producer Muff Winwood in early 1978. By the summer, they had signed with Warner in America, releasing their eponymous debut in the fall. Thanks to the Top Ten hit \"Sultans of Swing\", Dire Straits was a major success in both Britain and America, with the single and album climbing into the Top Ten on both sides of the Atlantic.  The LP \"Dire Straits\" established Dire Straits as a major force on album-oriented radio in America, and their second album, \"Communiqué\" (1979), consolidated their audience, selling three million copies worldwide. As the group was recording its third album, David Knopfler left the band to pursue a solo career; he was replaced by former Darling member Hal Lindes. Like its predecessor, \"Making Movies\" was a sizable hit in America and Britain, even though the band was criticized for musically treading water. Nevertheless, the record went gold on the strength of the radio and MTV hits \"Romeo and Juliet\" and \"Skateaway\". Dire Straits followed the album two years later with \"Love Over Gold\", an album filled with long, experimental passages, plus the single \"Private Investigations\", which became a number two hit in the United Kingdom. The album went gold in America and spent four weeks at number one in Britain. Shortly after the release of \"Love Over Gold\", former Rockpile drummer Terry Williams replaced Withers.  During 1982, Knopfler began exploring musical avenues outside of Dire Straits, scoring the Bill Forsyth film \"Local Hero\" and playing on Van Morrison's \"Beautiful Vision\". Apart from releasing the \"Twisting by the Pool\" EP early in 1983, Dire Straits were quiet for the majority of 1983 and 1984, as Knopfler produced Bob Dylan's \"Infidels\", as well as Aztec Camera and Willy DeVille; he also wrote \"Private Dancer\" for Tina Turner's comeback album of the same name.   In the spring of 1984, the band released the double album \"Alchemy: Dire Straits Live\" and by the end of the year, they had begun recording their fifth studio album with their new keyboardist, Guy Fletcher.   Released in the summer of 1985, \"Brothers in Arms\" was Dire Straits' breakthrough album, making the band international stars. Supported by the groundbreaking computer-animated video for \"Money for Nothing\", a song which mocked music videos, the album became a blockbuster, spending nine weeks at the top of the American charts and selling over nine million copies; in England, the album became the biggest-selling album of the '80s. \"Walk of Life\" and \"So Far Away\" kept \"Brothers in Arms\" in the charts through 1986, and Dire Straits played over 200 dates in support of the album.   Once the tour was completed, Dire Straits went on hiatus for several years, as Knopfler produced records by Randy Newman and Joan Armatrading, scored films, toured with Eric Clapton, and recorded a duet album with Chet Atkins: \"Neck and Neck\" (1990). In 1989, he formed the country-rock group Notting Hillbillies, whose sole album, \"Missing...Presumed Having a Good Time\", became a British hit upon its spring 1990 release. During the extended time off, John Illsley recorded his second album; the first appeared in 1984.  In 1990, Knopfler reconvened Dire Straits, which now featured Illsley, Clark, Fletcher, and various session musicians. The band released \"On Every Street\" in autumn 1991 to great anticipation. However, the album failed to meet expectations - it only went platinum in America but went to number one in the UK charts and most of Europe - it failed to generate a hit single in the UK.  The tour embarked on was massive but may have been a bit of a disappointment, with many tickets going unsold in both the U.S. and Europe. Once the tour was completed, the live album \"On the Night\" was released in the spring of 1993 and the band again went on hiatus.   Dire Straits released one last album in 1995, Live at the BBC, as a contractual album release to Vertigo Records.  That same year, Knopfler disbanded the group.  In 1996, Knopfler launched his solo career.", "site": "last.fm", "url": "http://www.last.fm/music/Dire+Straits/+wiki", "license": {"type": "cc-by-sa", "attribution": "Last.fm", "attribution-url": "http://www.last.fm/music/Dire+Straits/+wiki", "url": "http://creativecommons.org/licenses/by-sa/3.0/", "version": "3.0"}}, {"text": "..Dire Straits was a British rock band, formed in 1977 ...", "site": "myspace", "url": "http://www.myspace.com/sultansofdirestraits", "license": {"type": "unknown", "attribution": "myspace", "attribution-url": "http://www.myspace.com/sultansofdirestraits", "url": "n/a", "version": "n/a"}, "truncated": true}, {"text": "The U.K.'s Dire Straits became one of the world's most ...", "site": "7digital", "url": "http://us.7digital.com/artists/dire-straits/", "license": {"type": "unknown", "attribution": "7digital", "attribution-url": "http://us.7digital.com/artists/dire-straits/", "url": "n/a", "version": "n/a"}, "truncated": true}, {"text": "Dire Straits were a British rock band, formed in 1977 by Mark Knopfler (lead vocals and lead guitar), his younger brother David Knopfler (rhythm guitar and backing vocals), John Illsley (bass guitar and backing vocals), and Pick Withers (drums and percussion). Dire Straits' sound drew from a variety of musical influences, including jazz, folk, blues, and came closest to beat music within the context of rock and roll. Despite the prominence of punk rock during the band's early years, the band's stripped-down sound contrasted with punk, demonstrating a more \"rootsy\" influence that emerged out of pub rock. Many of Dire Straits' compositions were melancholic. Dire Straits' biggest selling album, Brothers in Arms, has sold over 30 million copies. \nThey also became one of the world's most commercially successful bands, with worldwide album sales of over 120 million. Dire Straits won numerous music awards during their career, including four Grammy Awards, three Brit Awards--winning Best British Group twice, and two MTV Video Music Awards. The band's most popular songs include \"Sultans of Swing\", \"Lady Writer\", \"Romeo and Juliet\", \"Tunnel of Love\", \"Telegraph Road\", \"Private Investigations\", \"Money for Nothing\", \"Walk of Life\", \"So Far Away\", \"Your Latest Trick\" and \"Brothers in Arms\". \nDire Straits' career spanned a combined total of 15 years. The band originally split up in 1988, but reformed in 1991. Dire Straits disbanded for good in 1995 when Mark Knopfler launched his career full-time as a solo artist. There were several changes in personnel over both periods, leaving Mark Knopfler and John Illsley as the only two original bandmates who had remained throughout the band's career. \n\nContents\n\n1 History\n1.1 1977-1979: Early years and first two albums, \n1.2 1980-1984: Increased musical complexity and early success, \n1.3 1985-1986: The Brothers in Arms era and international success, \n1.4 1987-1990: First break-up, \n1.5 1991-1995: Resurrection, final albums and final dissolution, \n1.6 1996-present, \n, \n2 Band members, \n3 Discography\n3.1 Studio albums, \n, \n4 Awards\n4.1 Award nominations, \n, \n5 References, \n6 External links, \n\nHistory:\n\n1977-1979: Early years and first two albums:\n\nBrothers Mark and David Knopfler, and friends John Illsley, and Pick Withers formed the band in 1977. In 1977, Dire Straits (a name given to the band by a musician flatmate of drummer Pick Withers), recorded a five-song demo tape which included their future hit single, \"Sultans of Swing\", as well as \"Water of Love\", \"Down to the Waterline\", \"Wild West End\" and David Knopfler's \"Sacred Loving\". They took the tape to DJ Charlie Gillett, who had a radio show called \"Honky Tonk\" on BBC Radio London. The band simply wanted advice, but Gillett liked the music so much that he played \"Sultans of Swing\" on his show. Two months later, Dire Straits signed a recording contract with Phonogram Records. In October 1977, the band recorded demo tapes of \"Southbound Again\", \"In the Gallery\" and \"Six Blade Knife\" for BBC Radio London; in November demo tapes were made of \"Setting Me Up\", \"Eastbound Train\" and \"Real Girl\". \nThe group's first album, Dire Straits, was recorded at Basing Street studios in West London in February 1978, at a cost of £12,500. Produced by Muff Winwood, the album had little promotion when initially released in the United Kingdom on Vertigo Records, then a division of Phonogram, and was not well received. However, the album came to the attention of A&R representative Karin Berg, working at Warner Bros. Records in New York City. She felt that it was the kind of music audiences were hungry for, but only one person in her department agreed at first. Many of the songs on the album reflected Mark Knopfler's experiences in Newcastle, Leeds and London. \"Down to the Waterline\" recalled images of life in Newcastle; \"In the Gallery\" is a tribute to Leeds sculptor/artist Harry Phillips (father of Steve Phillips); \"Wild West End\" and \"Lions\" were drawn from Knopfler's early days in the capital. \nThat same year, Dire Straits began a tour as opening band for the Talking Heads after the re-released \"Sultans of Swing\" finally started to climb the UK charts. This led to a United States recording contract with Warner Bros. Records; before the end of 1978, Dire Straits had released their self-titled debut worldwide. They received more attention in the United States, but also arrived at the top of the charts in Canada, Australia and New Zealand. Dire Straits eventually went top 10 in every European country. \nThe following year, Dire Straits embarked on their first North American tour. They played 51 sold-out concerts over a 38-day period. \"Sultans of Swing\" scaled the charts to number four in the United States and number eight in the United Kingdom. The song was one of Dire Straits' biggest hits and became a fixture in the band's live performances. Bob Dylan, who had seen the band play in Los Angeles, was so impressed that he invited Mark Knopfler and drummer Pick Withers to play on his next album, Slow Train Coming. \nRecording sessions for the group's second album, Communiqué, took place in December 1978 at Compass Point Studios in Nassau, Bahamas. Released in June 1979, Communiqué was produced by Jerry Wexler and Barry Beckett and went to #1 on the German album charts, with the debut album Dire Straits simultaneously at #3. In the United Kingdom the album peaked at #5 in the album charts. Featuring the single \"Lady Writer\", the second album continued in a similar vein as the first and displayed the expanding scope of Knopfler's lyricism on the opening track, \"Once Upon a Time in the West\". In the coming year, however, this approach began to change, along with the group's lineup. \n\n1980-1984: Increased musical complexity and early success:\n\nIn 1980, Dire Straits were nominated for two Grammy Awards for Best New Artist and Best Rock Vocal Performance by a Duo or Group for \"Sultans Of Swing\". In July 1980 the band started recording tracks for their third album. Produced by Jimmy Iovine with Mark Knopfler also sharing credit, Making Movies was released in October 1980. During the recording sessions, tension between Mark and David Knopfler took its toll on the band, and David Knopfler left over creative differences with his brother to pursue a solo career; he was uncredited on the album. The sessions continued with Sid McGinnis on rhythm guitar and keyboardist Roy Bittan from Bruce Springsteen's E Street Band. After the recording sessions were completed, keyboardist Alan Clark and Californian guitarist Hal Lindes joined Dire Straits as full-time members for tours of Europe and North America. \nMaking Movies received mostly positive reviews and featured longer songs with more complex arrangements, a style which would continue for the rest of the band's career. The album featured many of Mark Knopfler's most personal compositions. The most successful chart single was \"Romeo and Juliet\" (number 8 in the UK singles chart), a song about a failed love affair, with Knopfler's trademark in keeping personal songs under fictitious names. Although never released as a hit single, \"Solid Rock\" was featured in all Dire Straits' live shows from this point on for the remainder of their career, while the album's lengthy opening track, \"Tunnel of Love\", with its intro \"The Carousel Waltz\" by Richard Rodgers and Oscar Hammerstein II, was featured in the film An Officer and a Gentleman. Although \"Tunnel of Love\" only reached the position of #54 in the UK Singles Chart when released as a single in 1981, it remains one of Dire Straits' most famous and popular songs and immediately became a favourite at concerts. Making Movies stayed in the UK Albums Chart for 5 years, peaking at number 4. \nDire Straits' fourth studio album Love Over Gold, an album of songs filled with lengthy, experimental passages that featured Alan Clark's piano and keyboard work, was well received when it was released in September 1982, going gold in America and spending four weeks at number one in the United Kingdom. The title was inspired by graffiti seen from the window of Knopfler's old council flat in London. The phrase was taken from the sleeve of an album by Captain Beefheart. Love Over Gold was the first Dire Straits album produced solely by Mark Knopfler, and its main chart hit, \"Private Investigations\", gave Dire Straits their first top 5 hit single in the United Kingdom, where it reached the number 2 position despite its almost seven-minute length, and became another of the band's most popular live songs. \n\nIn other parts of the world, \"Industrial Disease\", a song that looks at the decline of the British manufacturing industry in the early 1980s, focusing on strikes, depression and dysfunctionality, was the main single from the album, particularly in Canada, where it became a top 10 hit. As well as the title track and \"It Never Rains\", Love Over Gold featured the 14-minute-long epic \"Telegraph Road\". Also written by Knopfler for inclusion on the album was \"Private Dancer\", a song which eventually went to Tina Turner for her comeback album of the same name. Love Over Gold reportedly sold two million copies during the first six weeks after its release. Shortly after the release of Love Over Gold, drummer Pick Withers left the band. His replacement was Terry Williams, formerly of Rockpile and a range of other Welsh bands including Man. \nIn 1983, a four-song EP titled ExtendedancEPlay was released while Love Over Gold was still in the album charts. It featured the hit single \"Twisting By the Pool\" which reached the Top 20 in the UK and Canada. Dire Straits also embarked on a world tour. The double album Alchemy Live, a recording of two live concerts of the group at London's Hammersmith Odeon in July 1983, was released in March 1984. Reportedly released without studio overdubs, it reached the Top 3 in the UK Albums Chart. The concert was also issued on VHS and was remastered and released on DVD and Blu-ray in 2010 - the only performance on the new format to date. \nDuring 1983 and 1984 Mark Knopfler was also involved in other projects outside of the band. He wrote the music scores for the films Local Hero and Cal, which were also released as albums. Also, during this time Knopfler produced Bob Dylan's Infidels album which featured Alan Clark on keyboards, as well as Aztec Camera and Willy DeVille. Also in 1984, John Illsley released his first solo album, Never Told a Soul, to which Mark Knopfler, Alan Clark and Terry Williams contributed. \n\n1985-1986: The Brothers in Arms era and international success:\nDire Straits returned to the recording studios at the end of 1984, and began recording tracks at Air Studios Montserrat for their upcoming fifth studio album, Brothers in Arms, produced by Knopfler with Neil Dorfsman. There were further personnel changes, with the addition of a second keyboardist, Guy Fletcher, who had previously worked as a session musician with Roxy Music and on the Cal soundtrack. Guitarist Hal Lindes left the band during the recording sessions. His replacement was New York guitarist Jack Sonni, and Andy Kanavan also joined briefly on drums; although neither was credited as an official band member for the new album release. \n\n\"Money for Nothing\"\n\nSorry, your browser either has JavaScript disabled or does not have any supported player., \nYou can download the clip or download a player to play the clip in your browser.\n\n\" Money for Nothing\" was notable for its controversial lyrics, groundbreaking music video, and a cameo appearance by Sting singing the song's falsetto introduction and backing chorus, \"I want my MTV.\"\n\nProblems playing this file? See media help. \n According to a Sound on Sound magazine interview with Neil Dorfsman, a month after the recording sessions began, drummer Terry Williams was temporarily replaced by jazz session drummer, Omar Hakim, who recorded all the drums for the album tracks during a two day stay before leaving for other commitments. Both Hakim and Williams are credited on the album, although Williams' only contribution is the improvised crescendo at the beginning of \"Money for Nothing\". The remainder of the album features Hakim on drums, but Williams would be back in the band for the music videos and the subsequent world tour. \nReleased in May 1985, Brothers In Arms entered the UK Albums Chart at number 1 and spent a total of 228 weeks in the charts. It went on to become the best-selling album of 1985 in the UK.Brothers in Arms was similarly successful in the US, peaking at No. 1 on Billboard 200 for nine weeks, going multi-platinum, selling nine million copies. The album spent thirty-four weeks at number 1 on the Australian ARIA Chart, making it the longest-running number one album in Australia. The album featured a more lavish production and overall sound than Dire Straits' earlier work, and spawned several big chart singles: \n\"Money for Nothing\", which reached number 1 on the US Billboard Hot 100, and number 4 in the UK Singles Chart, \"So Far Away\" (#20 UK, #19 US), \"Brothers In Arms\" (#16 UK), \"Walk of Life\" (#2 UK, #7 US), and \"Your Latest Trick\" (#26 UK). \"Money for Nothing\" was the first video to be played on MTV in Britain and featured guest vocals by Sting, who is credited with co-writing the song with Mark Knopfler, although in fact, it was just the inclusion of the melody line from \"Don't Stand So Close To Me\" that triggered the copyright credit, no actual lyrics were written by Sting. It also won a Grammy Award for Best Rock Performance by a Duo or Group with Vocal at the 28th Grammy Awards in February 1986. \nBrothers in Arms was among the first albums recorded on digital equipment due to Knopfler pushing for improved sound quality. The album's title track is reported to be the world's first CD single. It was issued in the UK as a promotional item distinguished with a logo for the tour, Live in '85, while a second to commemorate the Australian leg of the tour marked Live in '86. Containing just four tracks, it had a very limited run. \"Walk of Life\" meanwhile was nearly excluded from the album when co-producer Neil Dorfsman voted against its inclusion, but the band members out-voted him. The result was Dire Straits' most commercially successful hit single in the UK, peaking at number two. \"Money for Nothing\", \"Walk of Life\", and \"Brothers in Arms\" immediately became live concert favourites. \n\nThe album is listed in the Guinness Book of World Records as the first compact disc to sell a million copies, and has been credited with helping to popularise the CD format. The Brothers in Arms CD featured the full version of the \"Money for Nothing\" cut, rather than the version that appears on the LP. In fact, the CD includes extended versions of all tracks featured on the first side of the original LP, with the exception of \"Walk of Life\". \nThe 1985-86 world tour which followed the album's release was phenomenally successful. Saxophonist Chris White joined the band, and the tour began on 25 April 1985 in Split, Yugoslavia (now Croatia). While playing a 13-night residency at Wembley Arena, the band moved down the road to Wembley Stadium on the afternoon of 13 July 1985, to appear in a Live Aid slot, in which their set included \"Money For Nothing\" with Sting as guest vocalist. The tour ended at the Entertainment Centre in Sydney, Australia, where Dire Straits still holds the record for consecutive appearances at 21 nights. The band also made an impromptu attempt at the famous Australian folk song \"Waltzing Matilda\". In a two-year span, Dire Straits played 247 shows in over 100 different cities. \nAdditionally in 1985, a group set out from London to Khartoum to raise money for famine relief led by John Abbey, was called The Walk of Life. Dire Straits donated the Brothers in Arms Gold disc to the participants in recognition of what they were doing. \nThe band's 10 July 1985 concert at Wembley Arena, in which they were accompanied by Nils Lofgren for \"Solid Rock\" and Hank Marvin joined the band at the end to play \"Going Home\" (the theme from \"Local Hero\"), was televised in the United Kingdom on The Tube on Channel 4 in January 1986. (Although never officially released, bootleg recordings of the performance entitled Wembley does the Walk (2005) have been circulated.) \nIn 1986 Brothers In Arms won two Grammy Awards, and also won Best British Album at the 1987 Brit Awards.Q magazine placed the album at number 51 in its list of the 100 Greatest British Albums Ever in 2000. The album also ranked number 351 on Rolling Stone magazine's list of the \"500 Greatest Albums of All Time\" in 2003.Brothers in Arms is also ranked number 3 in the best albums of 1985 and number 31 in the best albums of the 1980s, and as of April 2012, the album was ranked the seventh best-selling album in UK chart history, and is the 107th best-selling album in the United States. In August 1986, MTV Europe was launched with Dire Straits \"Money for Nothing\". \n\n1987-1990: First break-up:\nAfter the Brothers in Arms tour ended Mark Knopfler took a break from Dire Straits and during 1987 he concentrated on solo projects and film soundtracks. Dire Straits regrouped in 1988 for the Nelson Mandela 70th Birthday Tribute concert staged on 11 June 1988 at Wembley Stadium, in which they were the headline act. They were joined for their set by Eric Clapton who performed his hit \"Wonderful Tonight\" with the group and played rhythm guitar on the other songs performed by the band, while guitarist Jack Sonni was absent. Soon afterwards, Williams left the band. \nMark Knopfler announced the official dissolution of Dire Straits in September 1988. He told Rob Tannenbaum in Rolling Stone: \"A lot of press reports were saying we were the biggest band in the world. There's not an accent then on the music, there's an accent on popularity. I needed a rest\". The tremendous success of the Brothers in Arms album and the tour that went with it left the band members under a significant amount of stress, and Knopfler announced that he wanted to work on more personal projects. A greatest hits album, Money for Nothing, was released in October 1988 and reached the number one position in the United Kingdom. Also in 1988, John Illsley released his second solo album, Glass which featured Mark Knopfler, Alan Clark, Guy Fletcher and Chris White. \nIn 1989, over a meal at a Notting Hill wine bar, Knopfler formed The Notting Hillbillies, a country-focused band whose lineup featured Guy Fletcher, Brendan Croker, and Steve Phillips and manager Ed Bicknell on drums. The Notting Hillbillies' one album, Missing...Presumed Having a Good Time with its minor hit single \"Your Own Sweet Way\", was released in 1990. The Notting Hillbillies toured for the remainder of the year, and also appeared on Saturday Night Live. Knopfler would further emphasize his country music influences on his 1990 collaboration with guitarist Chet Atkins, Neck and Neck. \nIn 1990, Dire Straits performed alongside Elton John and Eric Clapton at Knebworth Festival, playing three songs: \"Solid Rock\", \"Money for Nothing\" and a song which Knopfler prefaced as an experimental song, unsure if they should record it on a following record. The song, titled, \"I Think I Love You Too Much\", a blues rock piece with solos by both Knopfler and Clapton; this song also appeared on the 1990 album, \"Hell To Pay\" as a gift to Canadian blues/jazz artist, Jeff Healey from Knopfler. This was prior to the time that Knopfler, Illsley and manager Ed Bicknell decided to reform the band the following year. \n\n1991-1995: Resurrection, final albums and final dissolution:\nIn early 1991, Knopfler and Illsley resurrected Dire Straits, bringing back with them former keyboardists Alan Clark, and Guy Fletcher. Retaining Bicknell as their manager, Dire Straits was trimmed down and comprised only four members once again. The band began recording tracks for a new album, integrating new session players who included steel guitarist Paul Franklin, and percussionist Danny Cummings. Saxophonist Chris White returned, and guitarist Phil Palmer filled the vacancy left by Sonni. During the recording sessions, American drummer Jeff Porcaro performed in place of Williams. Afterwards, he was invited to join the band full-time but declined because of a prior commitment to Toto. \nDire Straits released their final studio album On Every Street, in September 1991, which, although a highly anticipated release, met with more moderate success and mixed reviews, as well as a significantly reduced audience, despite Dire Straits' previous international success. Some reviewers including the All Music Guide dubbed On Every Street as an 'underwhelming' follow-up to Brothers in Arms. However, it still managed to sell 8 million copies, reaching number one in the United Kingdom and number 12 in the United States. \nThe album failed to produce a major hit single in the United Kingdom. The first single release was the opening track \"Calling Elvis\", which had a video based on the 1960s television show Thunderbirds. It charted at no 21 in the UK but dropped out of the charts within four weeks. The follow-up single, \"Heavy Fuel\", failed to reach the Top 50 in the UK singles chart, however in the United States the track reached number one on the Billboard Mainstream Rock Tracks chart, their second song to do so (after \"Money for Nothing\"). Similarly, the album's title track was also relatively unsuccessful, failing to reach the UK Top 40. The final single released from the album and from the band in the United Kingdom was \"The Bug\", which contains backing vocals by Vince Gill, who was also invited to join the band full-time and declined. \nSession drummer Chris Whitten joined Dire Straits as a sideman when the band embarked on an extensive two-year, 300-show tour, playing in front of some 7.1 million ticket-buying fans. While musically more elaborate than the previous 1985-1986 world tour, the band's gruelling final tour was not as successful. It proved to be too much for Dire Straits, and by this time Mark Knopfler had had enough of such massive operations. This led to the group's second and final break-up. Bill Flanagan described the sequence of events in Gentleman's Quarterly: \"The subsequent world tour lasted nearly two years, made mountains of money and drove Dire Straits into the ground. When the tour was over, both Knopfler's marriage and his band were gone\". The last stop on the tour and the final touring concert of the group took place on 9 October 1992 in Zaragoza, Spain. \nAfter the end of the tour, Mark Knopfler expressed a wish to give up touring on a big scale, and took some time out from the music business. A live album On the Night was released in May 1993, which documented the tour, again to very mixed reviews. Nevertheless, it reached the UK Top 5, a rare achievement for a live album. The four track Encores EP was also released and rose to number one in the French singles chart. \nDire Straits' final album, Live at the BBC, was a collection of live recordings spanning the years 1978-81, which mostly featured the original lineup of the band. Released in June 1995, their third and final live album was a contractual release to Vertigo Records (now a division of Mercury Records). At this time, Mark Knopfler quietly disbanded Dire Straits and prepared to work on his first fully-fledged solo album (still signed to Mercury Records). \n\n1996-present:\nHaving disbanded Dire Straits, Mark Knopfler started his career as a solo artist, releasing his first solo album Golden Heart in March 1996 after nearly 20 years of collaborations. \nBrothers in Arms was certified nine times platinum in the U.S. in August 1996. During that year, the entire Dire Straits catalogue was remastered by Bob Ludwig and re-released on CD on Mercury Records, in most of the world outside the United States. The remasters were released in September 2000 in the United States, on Warner Bros. \nKnopfler, John Illsley, Alan Clark and Guy Fletcher reunited for one last time on 19 June 1999, with Ed Bicknell on drums, playing five songs including a performance of Chuck Berry's \"Nadine\" for Illsley's wedding. \nIn 2002, Mark Knopfler was joined by John Illsley, Guy Fletcher, Danny Cummings and Chris White for four charity concerts. Brendan Croker joined Knopfler during the first half, playing mainly material composed with The Notting Hillbillies. Illsley came on for a Dire Straits session, toward the end of which, at a Shepherd's Bush concert, Jimmy Nail came on to provide backing vocals for Knopfler's solo composition, \"Why Aye Man\". \nThe most recent compilation, The Best of Dire Straits & Mark Knopfler: Private Investigations, was released in November 2005 and reached the UK Top 20. Featuring material from the majority of Dire Straits' studio albums as well as Mark Knopfler's solo and soundtrack material, it was released in two editions, a single CD with grey cover and a double CD in blue cover. The only previously unreleased track on the album, All The Roadrunning, is a duet with singer Emmylou Harris. The album was well received. Also in 2005 Brothers in Arms was re-released in a limited 20th anniversary edition, which was a success, winning a Grammy Award for Best Surround Sound Album at the 48th Grammy Awards ceremony. \nSince the break-up of Dire Straits Mark Knopfler has shown no interest in reforming the band and is quoted as saying \"Oh, I don't know whether to start getting all that stuff back together again\", and telling reporters that \"I would only do that for a charity. I'm glad I've experienced it all - I had a lot of fun with it - but I like things the way they are.\" However, keyboardist Guy Fletcher has been associated with almost every piece of Knopfler's solo material to date, and Danny Cummings has frequently contributed, notably to three of Knopfler's most recent solo album releases All the Roadrunning (with Emmylou Harris), Kill to Get Crimson and Get Lucky. \nIn 2007, Knopfler said he did not miss the global fame that came his way at the height of the band's success, explaining that \"It just got too big\". In October 2008, John Illsley told the BBC that he wanted Knopfler to agree to reform Dire Straits for a comeback tour. Knopfler declined, saying that in the past he was often reluctant to reform the group and insisting that he \"isn't even a fan of Dire Straits' early hits\". In the same interview, Illsley also suggested that Knopfler is enjoying his continued success as a solo artist, saying that \"He's doing incredibly well as a solo artist, so hats off to him. He's having a perfectly good time doing what he's doing\". \nIn December 2009, the band was commemorated with a Heritage Award from PRS for Music. A plaque was placed on a block of flats in Deptford, London, the location where Dire Straits played their first gig. \nIn 2011, Alan Clark, Chris White, and Phil Palmer, with Tom Petty, and the Heartbreakers' drummer Steve Ferrone, put together a band called \"The Straits\", to perform at a charity show at the Albert Hall, and the band has continued to perform since. \n\nBand members:\nMain article: [url=http://en.wikipedia.org/wiki/List_of_Dire_Straits_band_members"]http://en.wikipedia.org/wiki/List_of_Dire_...d_members"[/url], "site": "wikipedia", "url": "http://en.wikipedia.org/wiki/Dire_Straits", "license": {"type": "cc-by-sa", "attribution": "wikipedia", "attribution-url": "http://en.wikipedia.org/wiki/Dire_Straits", "url": "http://creativecommons.org/licenses/by-sa/3.0/", "version": "3.0"}}, {"text": "1977 - 1995", "site": "facebook", "url": "http://www.facebook.com/pages/Dire-Straits/135608713145370", "license": {"type": "unknown", "attribution": "facebook", "attribution-url": "http://www.facebook.com/pages/Dire-Straits/135608713145370", "url": "n/a", "version": "n/a"}, "truncated": true}, {"text": "Biography by Stephen Thomas Erlewine Dire Straits emerged during the ...", "site": "amazon", "url": "http://www.amazon.com/Dire-Straits/e/B000ARA0V2/", "license": {"type": "unknown", "attribution": "amazon", "attribution-url": "http://www.amazon.com/Dire-Straits/e/B000ARA0V2/", "url": "n/a", "version": "n/a"}, "truncated": true}, {"text": "Dire Straits emerged during the post-punk era of the late ...", "site": "mog", "url": "http://mog.com/artists/bio/mn8489/dire%20straits", "license": {"type": "all-rights-reserved", "attribution": "mog", "attribution-url": "http://mog.com/artists/bio/mn8489/dire%20straits", "url": "n/a", "version": "n/a"}, "truncated": true}, {"text": "Dire Straits emerged during the post-punk era of the late ...", "site": "rdio", "url": "http://www.rdio.com/artist/Dire_Straits/", "license": {"type": "all-rights-reserved", "attribution": "", "attribution-url": "", "url": "n/a", "version": "n/a"}, "truncated": true}, {"text": "Dire Straits emerged during the post-punk era of the late ...", "site": "itunes", "url": "https://itunes.apple.com/us/artist/dire-straits/id648427", "license": {"type": "unknown", "attribution": "", "attribution-url": "", "url": "n/a", "version": "n/a"}, "truncated": true}]}}
Reply #2766
there wasn't any point in posting the content of those json files. they're from my last.fm/wikipedia bio script - nothing to do with images.
can you browse to your foobar profile\marc2003 folder, click file>open command prompt. paste in this...
cscript download.vbs http://userserve-ak.last.fm/serve/_/12048127/Dire+Straits+expresso+love.jpg "Dire Straits_12048127.jpg"
see if it works - the image should be saved in that folder.
Reply #2767
I did all you  want. Result:
C:\Users\pIv>ver
Microsoft Windows [Version 6.3.9600]
C:\Users\pIv>cd c:\Users\pIv\AppData\Roaming\foobar2000\marc2003\
c:\Users\pIv\AppData\Roaming\foobar2000\marc2003>dir
 Том в устройстве C имеет метку WINDOWS 8
 Серийный номер тома: BAF4-4C55
 Содержимое папки c:\Users\pIv\AppData\Roaming\foobar2000\marc2003
13.11.2013  08:39    <DIR>          .
13.11.2013  08:39    <DIR>          ..
12.11.2013  08:19          303 024 common7.js
19.10.2013  22:19              707 download.vbs
13.11.2013  08:39    <DIR>          images
              2 файлов        303 731 байт
              3 папок  21 670 334 464 байт свободно
c:\Users\pIv\AppData\Roaming\foobar2000\marc2003>cscript download.vbs [url=http://userserve-ak.last.fm/serve/_/12048127/Dire+Straits+expresso+love.jpg]http://userserve-ak.last.fm/serve/_/120481...presso+love.jpg[/url] "Dire Straits_12048127.jpg"
Сервер сценариев Windows (Microsoft R) версия 5.8
Copyright © Корпорация Майкрософт 1996-2006, все права защищены.
13.11.2013  12:21    <DIR>          .
13.11.2013  12:21    <DIR>          ..
[b]13.11.2013  12:21          168 291 Dire Straits_12048127.jpg[/b]
              3 файлов        472 022 байт
              3 папок  21 669 863 424 байт свободно
But when I start foobar  Dire Straits_12048127.jpg don't load to c:\Users\pIv\AppData\Roaming\foobar2000\wsh_lastfm\961077930\ folder!
Reply #2768
strange. the purpose of that last test was checking connectivity to last.fm and also making sure .vbs files run ok on your system. obviously that's fine.
i suppose the last thing to check is to see if the original request to fetch links from last.fm is ok. save this file in your marc2003 folder: https://dl.dropboxusercontent.com/u/2280132...temp/common7.js
restart foobar if it's running. this time it should output a list of image links in the foobar console. if that works, then i am stumped.
Reply #2769
I replace common7.js with new one. Result:
Win 8:
WSH Panel Mod (Now Playing by marc2003): Parsing file "C:\Users\pIv\AppData\Roaming\foobar2000\marc2003\common7.js"
WSH Panel Mod (Now Playing by marc2003): initialized in 71 ms
Opening track for playback: "C:\Users\pIv\Music\Foreign\Dire Straits\The Very Best Of DIRE STRAITS\04. Brothers In Arms.mpc"
Now Playing: HTTP error: 0
Win 7:
WSH Panel Mod (Now Playing by marc2003): Parsing file "C:\Users\GO\AppData\Roaming\foobar2000\marc2003\common7.js"
WSH Panel Mod (Now Playing by marc2003): initialized in 334 ms
User Interface initialized in: 0:01.631172
Opening track for playback: "C:\Users\GO\Music\Foreign\Dire Straits\The Very Best Of DIRE STRAITS\04. Brothers In Arms.mpc"
Now Playing: [url=http://userserve-ak.last.fm/serve/_/12048127.jpg]http://userserve-ak.last.fm/serve/_/12048127.jpg[/url]
Now Playing: [url=http://userserve-ak.last.fm/serve/_/135149.jpg]http://userserve-ak.last.fm/serve/_/135149.jpg[/url]
Now Playing: [url=http://userserve-ak.last.fm/serve/_/38129505.png]http://userserve-ak.last.fm/serve/_/38129505.png[/url]
Now Playing: [url=http://userserve-ak.last.fm/serve/_/7624741.jpg]http://userserve-ak.last.fm/serve/_/7624741.jpg[/url]
Reply #2770
you can try clearing temporary files in Internet Explorer. also check it's not blocked by any security software. try browsing the last.fm site as well.
Reply #2771
My win 8.1 is clear, I don't install any antivirus and firewall software.
But foo_uie_biography work fine. This plugin load artist and album images into c:\Users\my name\AppData\Roaming\foobar2000\lastfm\album and
c:\Users\my name\AppData\Roaming\foobar2000\lastfm\artist. No any secure software blocked it.
Reply #2772
My win 8.1 is clear
but did you actually go into the IE options and clear the temporary files or not? anyway, the answer doesn't really matter to me because that's my last suggestion. i can't think of anything else.
and what foo_uie_biography does is about as relevant as what i had for breakfast.
Reply #2773
marc2003
Of course, I clear all temporary files of IE, and also folder c:\users\piv\appdata\local\temp\. The result is the same.
In my opinion, this error occurs only on win 8.1, but not in win 7 or win 8. I check this error  too  with foobar 1.29  and foobar 1.30.
Reply #2774
marc2003
did your win 7 is also 64 bit?
try to install foobar in portable mode..
