Topic: WSH Panel Mod script discussion/help (Read 865547 times) previous topic - next topic
  • marc2003
Reply #75
It is buggy.
but yours is pretty buggy as well.
#EOF gets printed over the text a lot (it's position on a previous artist isn't updated when switching to a new artist)
it can't save text files with special characters in (see this post on how to fix - http://www.hydrogenaudio.org/forums/index....t&p=682074)
text sometimes disappears completely when scrolling.
text doesn't always update when changing tracks with different artists (random)
sometimes can't scroll back to top
edit: try this one (it doesn't support dragging though, only mouse scrolling)
api_key = "";
DT_CENTER = 0x00000001;
DT_VCENTER = 0x00000004;
DT_WORDBREAK = 0x00000010;
DT_CALCRECT = 0x00000400;
DT_NOPREFIX = 0x00000800;
DT_END_ELLIPSIS = 0x00008000;
ColorTypeCUI = {
text: 0,
selection_text: 1,
inactive_selection_text: 2,
background: 3,
selection_background: 4,
inactive_selection_background: 5,
active_item_frame: 6
FontTypeCUI = {
items: 0,
labels: 1
ColorTypeDUI = {
text: 0,
background: 1,
highlight: 2,
selection: 3
FontTypeDUI = {
defaults: 0,
tabs: 1,
lists: 2,
playlists: 3,
statusbar: 4,
console: 5
function RGB(r,g,b) {
return (0xff000000|(r<<16)|(g<<8)|(b));
function get_font() {
if (g_instancetype == 0) {
g_font = window.GetFontCUI(FontTypeCUI.items);
} else if (g_instancetype == 1) {
g_font = window.GetFontDUI(FontTypeDUI.defaults);
function get_colors() {
g_textcolor = window.GetColorCUI(ColorTypeCUI.text);
g_textcolor_hl = window.GetColorCUI(ColorTypeCUI.text);
g_backcolor = window.GetColorCUI(ColorTypeCUI.background);
g_textcolor = window.GetColorDUI(ColorTypeDUI.text);
g_textcolor_hl = window.GetColorDUI(ColorTypeDUI.highlight);
g_backcolor = window.GetColorDUI(ColorTypeDUI.background);
function on_playlist_switch() {
on_item_focus_change();
function on_colors_changed() {
get_colors();
window.Repaint();
function on_font_changed() {
get_font();
window.Repaint();
function on_item_focus_change() {
if (g_metadb) window.UnwatchMetadb();
g_metadb = fb.IsPlaying ? fb.GetNowPlaying() : fb.GetFocusItem();
if (g_metadb) {
try { on_metadb_changed(); } catch(e) {}
window.WatchMetadb(g_metadb);
g_instancetype = window.InstanceType;
get_font();
get_colors();
function lastfm(url, user_agent, func, debug) {
xmlhttp = new ActiveXObject("Microsoft.XMLHTTP");
xmlhttp.open("GET", url + "&s=" + Math.random(), true);
xmlhttp.setRequestHeader('User-Agent',user_agent);
xmlhttp.send();
xmlhttp.onreadystatechange = function() {
if (xmlhttp.readyState == 4) {
if (xmlhttp.status == 200) {
if(debug) fb.trace(xmlhttp.responsetext);
func();
} else {
g_metadb = fb.GetFocusItem();
var artist = g_text = '';
folder = fb.ProfilePath + "wsh_lastfm";
fso = new ActiveXObject("Scripting.FileSystemObject");
WshShell = new ActiveXObject("WScript.Shell");
if(!fso.FolderExists(folder)) fso.CreateFolder(folder);
String.prototype.count=function(s1) {
return (this.length - this.replace(new RegExp(s1,"g"), '').length) / s1.length;
function get_bio() {
   url = "http://ws.audioscrobbler.com/2.0/?method=artist.getinfo&api_key=" + api_key + "&artist=" + encodeURIComponent(artist);
   lastfm(url, "foo_wsh_lastfm_bio", function() {save_file();},0);
function save_file() {
   xmlDoc = xmlhttp.responseXML;
   try {
       g_text = xmlDoc.getElementsByTagName("content")[0].childNodes[0].nodeValue;
       g_text = g_text.replace(/<\/?[^>]+(>|$)/g, "");
       doc = new ActiveXObject("htmlfile");
       doc.open();
       div = doc.createElement("div");
       div.innerHTML = g_text.replace(/\n/g, "<br>");
       g_text = div.innerHTML;
       g_text = g_text.replace(/<BR>/g,"\n");
       g_text = g_text.replace(/&amp;/g,"&");
   } catch(e) {
       g_text = "This artist does not have a biography page on Last.fm.";
   try {
       ts = fso.OpenTextFile(filename, 2, true, -1);
       ts.WriteLine(g_text);
       ts.close();
   } catch(e) {
       g_text = "Error saving biography for this artist.";
   calc();
function on_size() {
   ww = window.Width;
   wh = window.Height;
   calc();
function on_paint(gr) {
   gr.FillSolidRect(0, 0, ww, wh, g_backcolor);
   if(g_metadb) {
       gr.GdiDrawText(g_text, g_font, g_textcolor, 6, offset + 36, ww-16, wh-offset,DT_WORDBREAK | DT_CALCRECT | DT_NOPREFIX);
       gr.FillSolidRect(0, 0, ww, 38, g_backcolor);
       gr.GdiDrawText(artist, gdi.Font("Segoe UI", 16, 1), g_textcolor_hl, 6, 5, ww-77, 24,DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
       gr.DrawLine(5, 29, ww-10, 29, 1, RGB(137,140,149));
function on_playback_new_track() {
function on_metadb_changed() {
   if(!g_metadb || artist == fb.TitleFormat("%artist%").EvalWithMetadb(g_metadb)) return;
   artist = fb.TitleFormat("%artist%").EvalWithMetadb(g_metadb)
   filename = folder + "\\" + fb.TitleFormat("$crc32(%artist%).txt").EvalWithMetadb(g_metadb);
   if(fso.fileExists(filename)) {
       try {
           ts = fso.OpenTextFile(filename,1, false, -1);
           g_text = ts.ReadAll();
           ts.close();
       } catch(e) {
           g_text = "Error opening file!";
       calc();
   } else {
       get_bio();
function calc() {
   temp_bmp = gdi.CreateImage(1, 1);
   temp_gr = temp_bmp.GetGraphics();
   arr = temp_gr.GdiDrawText(g_text, g_font, g_textcolor, 0, 0, ww, wh,DT_CENTER| DT_WORDBREAK | DT_VCENTER | DT_CALCRECT | DT_NOPREFIX).toArray();
   textheight = arr[3] - arr[1] + (wh/2) + (g_text.count("\n") * 3);
   temp_bmp.ReleaseGraphics(temp_gr);
   temp_bmp.Dispose();
   temp_gr = null;
   temp_bmp = null;
   offset = 0;
   window.Repaint();
function on_mouse_rbtn_up(x, y) {
   var MF_SEPARATOR = 0x00000800;
   var MF_STRING = 0x00000000;
   var _menu = window.CreatePopupMenu();
   var idx;
   _menu.AppendMenuItem(MF_STRING, 1, "Force update");
   _menu.AppendMenuItem(MF_SEPARATOR, 0, 0);
   _menu.AppendMenuItem(MF_STRING, 2, "Configure...");
   idx = _menu.TrackPopupMenu(x, y);
   if(idx == 1) get_bio();
   if(idx == 2) window.ShowConfigure();
   _menu.Dispose();
   return true;
function on_mouse_wheel(delta) {
   step = g_font.height * 5;
   offset += (delta * step);
   if(offset > 0 || textheight < wh) {
       offset = 0;
   } else {
       temp = -textheight + wh;
       if(offset < temp) offset = Math.round(temp / step) * step;
   window.Repaint();
  • Last Edit: 24 January, 2010, 01:46:01 PM by marc2003
  • saivert
Reply #76
Excellent code marc2003! You have simplified a lot. Good idea getting rid of all the "var" stuff. Really not needed with JS being a loosely typed language.
I didn't want to edit too much on the previous code I borrowed from you. I know it still needed a lot of work.
But why not use the preprocessor features and import flags.txt and handlers.txt. I think a standard install of WSH Panels mod should have a scripts directory in foobar2000 folder with those standard includes. This would slim down the scripts even further and makes things really clean.
// ==PREPROCESSOR==
// @import "%fb2k_path%scripts\flags.txt"
// @import "%fb2k_path%scripts\helpers.txt"
// ==/PREPROCESSOR==
  • Last Edit: 24 January, 2010, 08:12:04 PM by saivert
http://foobar2000.saivert.com - foobar2000 component repository
Reply #77
Oh, I really like this one.  The non-scrolling artist header is a cool idea.
  • T.P Wang
Reply #78
But JS has "scope", without "var" it's declared in global scope, and will confuse you if you are constructing a closure and use that variable in and it's hard to locate bugs if all variables are in global scope, eg:
function func1() {
   i = 1;
   fb.trace('"i" in func1() is :', i);  // i = 1
function test2() {
   // Call func1() here, and see what happens
   i = 2;
   func1();
   fb.trace('"i" in func2() is :', i);  //  i = 1 !!!
test2();
  • saivert
Reply #79
doesn't hurt to use var everywhere. but the script mostly avoided "var" on the global variables (outside closures).
  • marc2003
Reply #80
i do already. and stuff like the sample colour/font changing stuff goes into an external file as well. then i have an external last.fm script to store my credentials and xmlhttp function - so i can share it between multiple panels.
i just merged it all into a single script above because i couldn't be bothered to explain myself.
Reply #81
Last.fm records the number of times I play a track by a specific artist in order to come up with the "top artists" stats.  Is this information available to the API?  If so, how would I access this in WSH Panel Mod?  Thanks.
Edit: I've got it.
  • Last Edit: 25 January, 2010, 02:13:01 AM by Hitchhiker427
Reply #82
In case anyone's interested, I modified marc2003's bio script to create a Windows 7 style bio panel and lyrics panel.  Screenshots:
The code for the bio panel:
var username = "";
var api_key = "";
var image_path = fb.FoobarPath + "images\\";
ColorTypeCUI = {
   text: 0,
   selection_text: 1,
   background: 3,
FontTypeCUI = {
   items: 0,
   labels: 1
ColorTypeDUI = {
   text: 0,
   background: 1,
   highlight: 2,
   selection: 3
FontTypeDUI = {
   defaults: 0,
   tabs: 1,
   lists: 2,
   playlists: 3,
   statusbar: 4,
   console: 5
   get_colors();
   window.Repaint();
   get_font();
   window.Repaint();
   if (g_metadb) {
get_font();
get_colors();
   xmlhttp.send();
               func();
           else {
var artist = g_text = playcount = '';
var g_img = gdi.Image(image_path + "header.png");
get_playcount();
   url = "http://ws.audioscrobbler.com/2.0/?method=artist.getinfo&api_key=" + api_key + "&username=" + username + "&artist=" + encodeURIComponent(artist);
function get_playcount() {
   lastfm(url, "foo_wsh_lastfm_bio", function() {extract_playcount();},0);
   try {
       playcount = xmlDoc.getElementsByTagName("userplaycount")[0].childNodes[0].nodeValue;
       doc.open();
   catch(e) {
       playcount = "0";
   try {
       ts.close();
   catch(e) {
   calc();
function extract_playcount() {
   try {
   catch(e) {
       playcount = "0";
   window.Repaint();
   ww = window.Width;
   wh = window.Height;
   calc();
   if(g_metadb) {
       gr.GdiDrawText(g_text, g_font, g_textcolor, 21, offset + 60, ww-42, wh-offset,DT_WORDBREAK | DT_CALCRECT | DT_NOPREFIX);
       gr.FillSolidRect(0, 0, ww, 55, g_backcolor);
       gr.DrawImage(g_img, 0, 0, 830, 55, 0, 0, 830, 55);
       gr.FillGradRect(830, 0, ww - 820, 55, 0, RGB(252,252,252), RGB(255,255,255));
       gr.GdiDrawText(artist, gdi.Font("Segoe UI", 18, 0), RGB(0, 120, 50), 21, 4, ww-77, 24,DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
       gr.GdiDrawText("Artist Playcount:", gdi.Font("Segoe UI", 13, 0), RGB(90, 103, 121), 21, 29, ww-16, 24,DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
       gr.GdiDrawText(playcount, gdi.Font("Segoe UI", 13, 0), RGB(42, 102, 212), 120, 29, ww-16, 24,DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
       gr.DrawLine(21, 54, ww-21, 54, 1, RGB(214,229,245));
       gr.FillGradRect(6, 54,15, 1, 0, RGB(255,255,255), RGB(214,229,255));
       gr.FillGradRect(ww-21, 54,10, 1, 0, RGB(214,229,255),RGB(255,255,255));
   get_playcount();
   artist = fb.TitleFormat("%artist%").EvalWithMetadb(g_metadb);
       try {
           ts.close();
       catch(e) {
       calc();
   else {
       get_bio();
       get_playcount();
function calc() {
   temp_bmp.Dispose();
   temp_gr = null;
   temp_bmp = null;
   offset = 0;
   window.Repaint();
   var idx;
   _menu.AppendMenuItem(MF_STRING, 2, "View on Last.fm");
   _menu.AppendMenuItem(MF_STRING, 3, "Configure...");
   if(idx == 2) WshShell.run("http://www.last.fm/music/" + encodeURIComponent(artist));
   if(idx == 3) window.ShowConfigure();
   _menu.Dispose();
   return true;
       offset = 0;
   else {
   window.Repaint();
The code for the lyrics panel:
var lyrics_tag = "%lyrics%";
if (g_metadb) {
var artist = '';
var title = '';
var lyrics = '';
ww = window.Width;
wh = window.Height;
calc();
gr.FillSolidRect(0, 0, ww, wh, RGB(255,255,255));
if(g_metadb) {
gr.GdiDrawText(lyrics, gdi.Font("Segoe UI", 13, 2), RGB(0, 0, 0), 0, offset + 65, ww-16, wh-offset,DT_CENTER|DT_WORDBREAK | DT_CALCRECT | DT_NOPREFIX);
gr.FillSolidRect(0, 0, ww, 55, RGB(255,255,255));
gr.GdiDrawText(title, gdi.Font("Segoe UI", 18, 0), RGB(0, 120, 50), 0, 4, ww-16, 24,DT_CENTER|DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
gr.GdiDrawText(artist, gdi.Font("Segoe UI", 13, 0), RGB(90, 103, 121), 0, 29, ww-16, 24,DT_CENTER|DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
title = fb.TitleFormat("%title%").EvalWithMetadb(g_metadb);
lyrics = fb.TitleFormat(lyrics_tag).EvalWithMetadb(g_metadb);
if (lyrics == "?") lyrics = "No Lyrics Available";
window.Repaint();
function calc() {
arr = temp_gr.GdiDrawText(lyrics, gdi.Font("Segoe UI", 13, 2), RGB(0, 0, 0), 0, 0, ww, wh,DT_CENTER| DT_WORDBREAK | DT_VCENTER | DT_CALCRECT | DT_NOPREFIX).toArray();
textheight = arr[3] - arr[1] + (wh/2) + (lyrics.count("\n") * 3);
temp_bmp.Dispose();
temp_gr = null;
temp_bmp = null;
offset = 0;
window.Repaint();
var idx;
_menu.AppendMenuItem(MF_STRING, 1, "Refresh");
_menu.AppendMenuItem(MF_STRING, 2, "Edit Lyrics");
if(idx == 1) window.Repaint();
if(idx == 2) fb.RunContextCommandWithMetadb("edit",g_metadb);
_menu.Dispose();
return true;
step = gdi.Font("Segoe UI", 13, 2).height * 5;
offset = 0;
else {
window.Repaint();
The required header image (needs to be named "header.png"):
Finally, in order to get the "edit lyrics" command working, you need this component:
http://www.hydrogenaudio.org/forums/index....showtopic=36598
In order to preserve the Windows 7 styling, these scripts don't really play nice with the CUI/DUI default colors.  Hopefully someone finds these useful.
  • marc2003
Reply #83
that needs some serious reworking. you're making 3 requests to last.fm for the same file all at once.
edit: and it just caused my foobar to crash when starting.....
  • Last Edit: 25 January, 2010, 03:24:47 AM by marc2003
Reply #84
Ok, this should make fewer calls to Last.fm.  Hopefully it also fixes any crashes:
var username = "";
var api_key = "";
   if (g_metadb) {
   get_bio();
g_font = gdi.Font("Segoe UI", 12, 0);
g_textcolor = RGB(0,0,0);
g_backcolor = RGB(255,255,255);
   lastfm(url, "foo_wsh_lastfm_bio", function() {save_file();extract_playcount();},0);
   xmlhttp.send();
               func();
           else {
   try {
       doc.open();
   catch(e) {
       playcount = "0";
   try {
       ts.close();
   catch(e) {
   calc();
   try {
   catch(e) {
       playcount = "0";
   window.Repaint();
   ww = window.Width;
   wh = window.Height;
   calc();
   if(g_metadb) {
       try {
           ts.close();
       catch(e) {
       calc();
   else {
       get_bio();
function calc() {
   temp_bmp.Dispose();
   temp_gr = null;
   temp_bmp = null;
   offset = 0;
   window.Repaint();
   var idx;
   _menu.Dispose();
   return true;
       offset = 0;
   else {
   window.Repaint();
  • Last Edit: 25 January, 2010, 03:53:14 AM by Hitchhiker427
  • marc2003
Reply #85
you should be making one call. it's the same file. why are you fetching it twice?
and you might as well scrap the idea of caching files being as though you're fetching the file on every new track.
Reply #86
Ok, so I'm (obviously) new at this.  What I was trying to do was always download the xml file on each new track to obtain the artist playcount.  However, I wanted to use the cached artist bio if available (as your code does).  Yes, I understand that much of the usefulness of the cached data is lost in this implementation, but displaying the bio info itself should still be quick (cached data) and only the playcount itself will always have a slight delay.  So, it should have worked like this:
if no bio is cached, it makes 1 request for the xml file and extracts the bio and playcount.
if a bio is cached, it makes 1 request for the xml file and extracts the playcount only.
I made some stupid mistakes in the previous versions, however, I've reworked the code again (last time for the night), and I think this does what I want it to:
var username = "";
var api_key = "";
   if (g_metadb) {
var artist = g_text = playcount = url = '';
   xmlhttp.send();
               func();
           else {
   try {
       doc.open();
   catch(e) {
       playcount = "0";
   try {
       ts.close();
   catch(e) {
   calc();
   try {
   catch(e) {
       playcount = "0";
   window.Repaint();
   ww = window.Width;
   wh = window.Height;
   calc();
   if(g_metadb) {
   playcount = '';
       get_playcount();
       try {
           ts.close();
       catch(e) {
       calc();
   else {
       get_bio();
function calc() {
   temp_bmp.Dispose();
   temp_gr = null;
   temp_bmp = null;
   offset = 0;
   window.Repaint();
   var idx;
   _menu.Dispose();
   return true;
       offset = 0;
   else {
   window.Repaint();
  • marc2003
Reply #87
@carmenm, how did you parse the feeds to get image urls? i'm stuck doing this.
  • carmenm
Reply #88
Can you wait 1 or 2 days? i am on the  verge of releasing the manager that will do all that for you.
If you cant tell me and i ll put a code here.
  • Last Edit: 25 January, 2010, 05:54:25 AM by carmenm
  • marc2003
Reply #89
i'm only interested in downloading 1 image per artist - the one in the artist.getinfo
  <image size="small">http://userserve-ak.last.fm/serve/34/34848663.png</image>
  <image size="medium">http://userserve-ak.last.fm/serve/64/34848663.png</image>
  <image size="large">http://userserve-ak.last.fm/serve/126/34848663.png</image>
  <image size="extralarge">http://userserve-ak.last.fm/serve/252/34848663.png</image>
  <image size="mega">http://userserve-ak.last.fm/serve/_/34848663/Jem++PNG+6.png</image>
i just want to know how to get the url for the "mega" bit and that is all. i tried that activex thing you posted and that works fine if i put in the url manually so i'm happy using that.
  • carmenm
Reply #90
Yes that s exactly what my manager does, i wont spoil all the fun  I am kidding.
With that line you get all artist tags
var artistsArray = xmlDoc.getElementsByTagName("artist");
then with this one you get the mega picture
var artistpicture = (artistsArray[i].childNodes[7].childNodes[0])?artistsArray[i].childNodes[7].childNodes[0].nodeValue:"";
  • Last Edit: 25 January, 2010, 06:08:23 AM by carmenm
  • marc2003
Reply #91
thanks.
  • carmenm
Reply #92
I finally released my suite.
Enjoy
  • saivert
Reply #93
where is the updated Bios panel without multi last .fm requests. I just want a simple codebase to work from.
no fluff or useless crap. Don't understand why you guys have to go overboard with your scripts. Keep it simple stupid. Less is more, etc... etc..
  • Last Edit: 25 January, 2010, 01:11:38 PM by saivert
  • marc2003
Reply #94
updated biography panel which caches the whole xml repsonse which means you can save/display all data. rather than parse the response, it now parses the cached file if it exists during on_metadb_changed. uses external js files so check those as well.
http://cid-649d3bfeaf541fbb.skydrive.live....astfm%20bio.zip
(it doesn't display any new data but i've put in samples of how to do it)
  • Last Edit: 25 January, 2010, 02:17:00 PM by marc2003
  • Scidd0w
Reply #95
marc2003;
Thank you for the above script. I can't seem to get it working though.
Any idea whats going wrong?
popup:
Scripting Engine Initialization Failed (GUID: F22DD133-CB46-41DF-874E-93B34B56CD82, CODE: 0x80020101)
Check the console for more detailed information (Always caused by unexcepted script error).
console output:
WSH Panel Mod (GUID: DA503407-4725-42B8-B2D7-A823F69425D5): initliased in 0.0000371 s
WSH Panel Mod (GUID: F22DD133-CB46-41DF-874E-93B34B56CD82): Parsing file "C:\Program Files (x86)\foobar2000\scripts\marc2003\fonts_colours_flags.js"
WSH Panel Mod (GUID: F22DD133-CB46-41DF-874E-93B34B56CD82): Parsing file "C:\Program Files (x86)\foobar2000\scripts\marc2003\lastfm.js"
Error: WSH Panel Mod (GUID: F22DD133-CB46-41DF-874E-93B34B56CD82): Microsoft JScript runtime error:
Automation server can't create object
Ln: 8, Col: 1
<source text only available in compile time>
  • marc2003
Reply #96
file>preferences>tools>wsh panel mod>uncheck "safe mode". restart foobar.
  • Scidd0w
Reply #97
Great...
Works now!
  • icedtea
Reply #98
Can some kind soul convert the playback section of this theme (buttons, progress, volume etc) to a script for someone like me who doesn't know even a little but of jscript
http://fanco86.deviantart.com/art/MonoLite-122756120
  • Scidd0w
Reply #99
With some bio's it fetches I see &nbsp; codes in there. Is it easy to replace these with normal spaces via your script? What line should I edit where etc?
Are you in the process of writing a new script that fetches the artist images from last.fm? Something in the same manner that the bio plugin does. If so I'm lookig forward to it!  Now that I think of it a configurable amount of images per artist would be a nice to have too (than it will have all I like from the bio plugin without the overhead).
  • Last Edit: 26 January, 2010, 05:17:12 AM by Scidd0w
