Topic: album list behaviour in v1.0 (Read 2344 times) previous topic - next topic
up to v0.9.6.9 i used to add albums to my current playlist by doubleclicking them in the album list view. now in v1.0 it creates a new playlist entitled with an "?" and adds the album there, although i still have the double-klick action configured to "add to current playlist".
additionally i just noticed the same behaviour when enqeueuing albums manually via contextmenu from windows. it goes to a new playlist instead of that one specified under "shell integration > always send new files to playlist:"
sorry if this was discussed before, couldn't find it...
how can i restore this?
It works correctly here. Please post your components list, whether it works on a new empty playlist, if you are using the stand-alone Album List or some UI embedded one, or other details which might be relevant.
my components:
Core (2010-01-09 12:47:00)
    foobar2000 core 1.0
foo_abx.dll (2009-06-07 13:25:26)
    ABX Comparator 1.3.4
foo_albumlist.dll (2010-01-09 12:44:46)
    Album List 4.4
foo_audioscrobbler.dll (2009-05-07 21:05:30)
    Audioscrobbler 1.4.1
foo_cdda.dll (2010-01-09 12:44:42)
    CD Audio Decoder 3.0
foo_converter.dll (2010-01-09 12:44:32)
    Converter 1.4
foo_dbsearch.dll (2007-01-25 20:58:48)
    Database Search 1.4
foo_discogs.dll (2009-12-29 10:12:47)
    Discogs Tagger 1.22
foo_dsp_crossfader.dll (2009-01-05 19:43:56)
    Gapless Crossfader 0.3.4.1 (SSE)
foo_dsp_std.dll (2010-01-09 12:44:48)
    Standard DSP Array 1.0
foo_dumb.dll (2009-12-28 23:08:00)
    DUMB module decoder 0.9.9.10
foo_fileops.dll (2010-01-09 12:43:32)
    File Operations 2.1.2
foo_freedb2.dll (2010-01-09 12:43:34)
    freedb Tagger 0.6.2
foo_input_dts.dll (2009-12-13 23:01:38)
    DTS decoder 0.2.7
foo_input_monkey.dll (2009-05-01 13:40:52)
    Monkey's Audio Decoder 2.1.4
foo_input_std.dll (2010-01-09 12:44:24)
    Standard Input Array 1.0
foo_input_tta.dll (2008-11-29 13:55:00)
    TTA Audio Decoder (unofficial) 2.4.2
foo_masstag.dll (2009-09-18 10:01:36)
    Masstagger 1.8.4
foo_musicbrainz.dll (2009-04-10 21:27:30)
    MusicBrainz Tagger 0.2
foo_navigator.dll (2007-08-04 12:36:46)
    Navigator 0.63
foo_out_asio.dll (2009-03-22 14:15:46)
    ASIO support 1.2.7
foo_out_ks.dll (2006-08-04 21:54:58)
    Kernel Streaming Output 1.2.2
foo_playcount.dll (2009-04-29 19:09:00)
    Playback Statistics 2.1.9
foo_playlist_bind.dll (2007-06-27 02:57:38)
    Playlist Bind 3.2
foo_pqview.dll (2008-03-11 18:02:54)
    Playback Queue Viewer 0.2
foo_quicktag.dll (2008-05-01 19:39:02)
    Quick Tagger 1.0.1
foo_rg_trn.dll (2007-10-27 21:13:00)
    ReplayGain override 0.1.2
foo_rgscan.dll (2010-01-09 12:44:24)
    ReplayGain Scanner 2.0.9
foo_scheduler.dll (2007-01-09 21:33:00)
    Scheduler 3.53
foo_sendtodevice.dll (2007-09-07 09:34:18)
    Send to Device 1.1.1 [Sep  7 2007 - 10:34:03]
foo_sid.dll (2009-04-16 13:30:28)
    sidplay2 1.14
foo_stopaftercuralbum.dll (2009-06-01 08:50:00)
    foo_stopaftercuralbum 0.2
foo_ui_std.dll (2010-01-09 12:44:52)
    Default User Interface 0.9.5
foo_unpack.dll (2009-08-05 20:53:42)
    RAR reader 1.2
    ZIP/GZIP reader 1.0
foo_utils.dll (2007-10-29 14:03:18)
    Playlist Tools 0.6.2 beta 3
foo_vis_shpeck.dll (2009-05-20 22:43:46)
    Shpeck - Winamp vis plugins wrapper 0.3.5
foo_w7shell.dll (2009-08-30 03:01:32)
    Windows 7 integration 0.2.8.0
i'm using the defaultUI. with a new empty playlist the album list action works correctly but enqeueuing does not.
i think, best solution will be a clean install. i'll report back when i have sorted this out.
thank you for pointing out, that it works correctly for you!
edit: ok, got it. it seems, foo_utils was the problem. after removing it everything is fine now.
The only case I can think of where foo_utils would behave in this way, is if you have set the current playlist to read-only.
thanks foosion, that was the case.
i really can't remember why and when i set this to read only in the first place, makes no sense at all.
*slaps girlfriend*
just kidding
thanks!
