Topic: foobar2000 v1.0: discussion (Read 146556 times) previous topic - next topic
  • Yirkha
  • Moderator
Reply #175
That behaviour depends on the notification area icon settings.
Reply #176
Oh, woops. I had no idea that had anything to do with it.
  • Hamallainen
Reply #177
Is there any way to recreate the old "View Now Playing" behavior? Currently, when that command is executed, a popup balloon appears over the foobar icon and displays the current playing track. The old behavior actually changed the focus of the selection to the track that was currently playing.  This was very useful when a lot of playlists were open and you wanted to quickly go to the one that was playing.
I think what you are looking for is ACTIVATE NOW PLAYING which is no longer in 1.0 it seems. I don't know why. I also used it a lot
  • Yirkha
  • Moderator
Reply #178
That has nothing to do with the core, though. If you don't see "Activate Now Playing" anymore, you forgot to (re)install Columns UI.
  • Hamallainen
Reply #179
My bad, thanks for reminding me this.
  • Garson
Reply #180
Tell me please, why at equalizer activation there is an effect of normalisation of loudness?
I use version 1.0. Thanks
  • Yirkha
  • Moderator
Reply #181
There is not.
  • Mastermnd
Reply #182
There is not.
Yes there is. I was just going to post about this, glad someone else noticed it.
Something was done to the peaks processing or something
I have completely disabled ReplayGain, and still get random frequent loudness changes when the EQ is on (no other DSPs active).
This is the sole reason i am considering switching back to the 0.9 series.
I can attach my equalizer preset if anyone needs it.
  • Last Edit: 20 January, 2010, 01:40:07 PM by Mastermnd
  • Case
  • Developer (Donating)
Reply #183
EQ volume pump effect seems to be side effect of using float output on Vista/7 with DirectSound. Windows mixer seems to lower volume for samples that would clip. If you try WASAPI output you should get expected output.
  • Garson
Reply #184
WASAPI output
What is the WASAPI output? The primary sound driver?
  • shakey_snake
  • Moderator
Reply #185
elevatorladylevitateme
  • Dandruff
Reply #186
There's a bug with the notification area icon in foobar2000 1.0: http://www.hydrogenaudio.org/forums/index....showtopic=78027
  • Yirkha
  • Moderator
Reply #187
Yes, that report has been read and the bug fixed.
No need to bump this poor thread with it.
Let's move back to the usual routine - start a new topic for each question or comment instead of piling up everything in one thread with generic title.
