Topic: foo_wave_seekbar (Read 832092 times) previous topic - next topic
Re: foo_wave_seekbar
Reply #2250
Does anyone know where to find somewhere to download the Visual Studio 2012 Update 1?  Or if there is another version that will work?
Reply #2253
I wrapped up the progress I had and rolled a 0.3.0 alpha 1 build of the v2 D3D11 experiment. It installs on x86 and x64 players.
Lost my old account here. Was pretty much still on 1.5.3.
Installed both the 2.0 and 2.1 (both flavors) and tried your pre-release in each...
DxDiag says I got DirectX3D 12, so could be I'm missing something else, but as soon as I make the wavebar visible (either by adding it as panel or as toolbar) it just brings down FB2K hard.
Both 2.0 and 2.1 and for both x86 and x64 versions
Contacting component creator?
Reply #2254
I have a component (Waveform Seekbar) that's only 32bit but the creator has made a bunch of others that are both 32 and 64. I want to see what the best way to contact them??
Wanted to ask them if they will ever update it with a 64 bit version.
Mac Version?
Reply #2257
Hello, I am using waveformseekbar thankfully. Do you have any plans to make a Mac Version?
Reply #2258
I don't remember if macfoo has components but regardless, no, I do not have any plans to touch this component again.
It would be a rough port to make as it uses a fair bit of Win32 and Direct3D.
Stay sane, exile.
Reply #2259
Okay, thank you for your hard work. It's been the main reason for using foobar2000. It's a shame. I think I'll have to use Windows version for the time being
Reply #2261
So... that 3.0 alpha github link is just a teaser to see if it would work? ;D
It seems to work for some, doesn't work for some. That's probably good enough if you're an enthusiast that haven't gone over to an actually maintained and solid one like Case's.
I can't with good conscience release this for all users, it would not be a responsible thing to do with the lack of time I have these days.
Stay sane, exile.
