Topic: [fb2k v2] Random Pools (foo_random_pools) (Read 189120 times) previous topic - next topic
Re: [fb2k v2] Random Pools (foo_random_pools)
Reply #350
To avoid that, I use "2" for the setting "Add when the playback position is X items or less from the end".
I don't know if it's a known bug, or if it can be circumvented ?
This is neither a known bug nor can it be circumvented. It's a just timing problem. Setting the value as you described is the best what you can do.
Reply #351
Hello @fbuser, I just noticed that, with FB v2 beta 34, the "Check for updated components" did not report as new your 3 components: Random Pool 2.0.0., SQLTree 4.0.0 and SQLite Utilities 3.0.2. (this did not prevent me from installing all them manually).
Said that, I also noted that FB v2 beta 34 can detect other updates, thereof I think there is a problem with your components versioning reporting.
Regards, Andrea
Reply #352
**** Performance problem with new version 2.0.0 ****
Hello @fbuser , my PC is an old 32bit running Win 10.
Stated this, the previous version was able to generate a 50 tracks random playlist in few seconds (I have a large library).
The new V2.0.0 takes 20 times (or so) longer!!!!
To be noted that I have updated the 3 components Random Pool 2.0.0., SQLTree 4.0.0 and SQLite Utilities 3.0.2, and not just the Random Pool.
Can you help me troubleshooting the problem? I really would  like to get back to a decent performance.
Kind regards, Andrea
Reply #353
Regards, Andrea
Seems to work now. Had been also a problem for my components.
Component update: Checking for: foo_uie_sql_tree / SQL Tree / 4.0.0
Component update: Found a match - 4.0.0 vs 4.0.0
Component update: Checking for: foo_sqlite / SQLite Utilities / 3.0.2
Component update: Found a match - 3.0.2 vs 3.0.2
Reply #355
This in combination with this
is actually the problem.
This might not be possible, but just let me know, which settings you are using for this
Reply #356
I've updated plugin today, v2.0.1, and it crashes foobar2000. Windows 11 64 bit, v2.0 works.
TAPE LOADING ERROR
Reply #357
Could you please post the crash report here?
Reply #358
I had the same problem. I was not able to even start foobar without using safe mode and removing the component.
I have multiple crash logs I can upload - let me know if this one works.
Reply #359
Thanks, this is sufficient. But I have a few questions:
  • Did you upgrade from random pools version 2.0.0 or did you newly install version 2.0.1?
  • If it was a new installation, did you use the configuration from a fb2k version < 2?
  • If you used the configuration from a fb2k version < 2, what are the versions of fb2k and random pools you take the configuration from?
Reply #360
I upgraded from 2.0.0. When foobar relaunched after installing 2.0.1, it immediately crashed.
Reply #361
Thanks for the info. I should have asked also for this scenario: Did you use a configuration from a fb2k version < 2 when you installed random pools version 2.0.0?
Reply #362
I upgraded from foobar 1.6 where I also had Random Pools installed, so probably yes.
Reply #363
Ok, that explains the cause of the crash. It should be fixed now with the lastet version.
Reply #364
Sorry for late reply, it was the same for me - I've migrated config from 1.6 when installing beta 2.0, 32 to 64 bit. randompools weren't available then, so I waited final version of 2.0, installed 2.0 of randompools, it worked, and then upgraded to 2.0.1, had crash.
TAPE LOADING ERROR
Reply #365
Hmm, this is a different scenario as that vom @Reith and it's a bit suprising.
In case you still have problems also with 2.0.2, could you please post your config.sqlite from your profile folder, so that I can analyze it?
Reply #366
Hello,
I am having problems with the new version, starting from V2.0.
Before that version, my PC was taking 15-20 seconds to create a 50 tracks random playlist, while now, using the today last versions of all the components, it is taking 180 to 240 seconds!
[foo_random_pools] 22:25:23.188: Get new pool database connection, db pool size: 0, available connections: 0 ...
[foo_random_pools] 22:25:23.188: Open database C:\Users\AdmAT\AppData\Roaming\foobar2000-v2\configuration\foo_sqlite.user.db ...
[foo_random_pools] 22:25:23.193: Open database C:\Users\AdmAT\AppData\Roaming\foobar2000-v2\configuration\foo_sqlite.user.db: 0:00.004594
[foo_sqlite] 22:25:23.203: Create MetaDB_Module ...
[foo_sqlite] 22:25:23.204: Create MetaDB_Module: 0:00.000126
[foo_random_pools] 22:25:23.204: Attach database C:\Users\AdmAT\AppData\Roaming\foobar2000-v2\configuration\foo_sqlite.materialize.db as materialize ...
[foo_random_pools] 22:25:23.207: Attach database C:\Users\AdmAT\AppData\Roaming\foobar2000-v2\configuration\foo_sqlite.materialize.db as materialize: 0:00.003770
[foo_random_pools] 22:25:23.207: Get new pool database connection, db pool size: 0, available connections: 0: 0:00.019558
[foo_random_pools] 22:25:23.231: Adding pools from pool set Random Tracks SQL ...
[foo_random_pools] 22:25:23.234: Add pool '050 random tracks' from pool set Random Tracks SQL ...
[foo_random_pools] 22:27:38.751: Add pool '050 random tracks' from pool set Random Tracks SQL: 2:15.517329
[foo_random_pools] 22:27:38.762: Adding pools from pool set Random Tracks SQL: 2:15.530664
Anyone out there can help me understanding what's going wrong?
Regards, Andrea
Reply #367
Please, post your settings. Besides this as you are obviously using a SQL query, ensure that you are using a materialized media library table, not the virtual table directly. This should be always faster on your system.
Reply #368
Hello @fbuser, I checked my PC and the file "foo_sqlite.materialize.db" is there and has size of 450MB approximatively, while the "metadb.sqlite" file is about 1GB in size.
Regarding my configuration and queries, I am only using the queries you kindly made for me months ago. As well as the "marialization" of the dBase was made following your instructions.
Since then I didn't change anything, also because I don't know anything of SQL.
The queries and materialization instruction you provided me in: Reply #318 – 2022-08-19 21:56:15 and Reply #331 – 2022-08-23 19:21:06 of this thread.
What really happened, it was that along with the release of the final Foobar V2, you also released the new set of 3 components, Random Pool 2.0.0., SQLTree 4.0.0 and SQLite Utilities 3.0.2, and since then I am having this performance issue.
Kindly understand that, due to my ignorance of SQL, I cannot understand if the problem is within the new Foobar V2 or what else.
Said that, I am very happy to do whatever needed to let you understand what's wrong. Please, just tell me step by step what I shall have to do and/to provide you.
Thanks and regards, Andrea
Reply #369
Ok, can you please open the SQLite console, enter the following statement and let me know the result?
WITH
Albums AS (
  SELECT album||'|'||coalesce("album artist",artist) Album
  FROM MMediaLibrary
  GROUP BY 1
  ORDER BY random()
  LIMIT 10
SELECT path, subsong FROM
MMediaLibrary
WHERE album||'|'||coalesce("album artist",artist) IN (SELECT album FROM Albums)
ORDER BY album||'|'||coalesce("album artist",artist),coalesce(discnumber,1),tracknumber;
Reply #370
Hello @fbuser , thanks a lot for your support that allowed me to fix the problem.
I noted that the SQL query you provided me in Reply #318 – 2022-08-19 was making use of MediaLibrary instead of MMediaLibrary.
I then put MMediaLibrary also in those set of "random tracks" queries and now I can have a 50 random tracks playlist created in 10 seconds! Perfect so! About 3 times faster than the old good 2022 performance.
Now, solved my "current performance problem", still remaining the big question: why it was anyway working decently in the past with MediaLibrary and not anymore today?
All the best and thanks a lot again for your help, Andrea
Reply #371
It was actually in #324. In #318 was the initial solution without SQL.
Indeed, especially as the performance for that query on my 6 year old standard notebook is 2.3 seconds for MediaLibrary and 1.7 seconds for MMediaLibrary.
So the performance degretion for you is most likely caused by your slow system in the first place in combination with the internal changes including the changes for SQLite itself. But even on your system this should normally not cause such a huge performance difference between both statement versions.
Reply #372
I'm real close to getting what I want, finally, and I can hardly stand it lol. I want a playlist of one song per artist, that song being the oldest played from that artist, played randomly. So my playlist would be sorted by %ARTIST% - %Last_Played%, then play (or put in a playlist) the first song from each artist.
Is this the plugin that will do it?
Reply #373
I want a playlist of one song per artist, that song being the oldest played from that artist.
So far I have this for a pool definition...
Group = %artist%
# of groups to add = 1000
# of tracks to add = 1
limit after sorting = yes
sort = %last_played%
sort/limit each group = yes
title format = yes
media library = yes
filter = E:\Music\Brian Music\Albums
One small issue is lots of duplicates, which I can remove with the FB "remove duplicates" menu option. Would there be a SQL Query I could use instead to remove the duplicates? Thank you!
Reply #374
I fixed the dupes by adding another %artist% filter at the end.
One more thing to tackle, if an artist has only one song it will add to the playlist even if recently played. I could use the skip track plugin to not play recent songs, but is there another way using this plugin?
Thank you!
