Topic: [crashware] foo_uie_lyrics2 (Read 416673 times) previous topic - next topic
Reply #500
Have no clue. It really does work just like any other panel.
If you can you might want to upload an image how your foobar looks.
Do a copy paste of the preferences > Components page and insert into a reply in a /codebox/.
I am out of suggestions
good luck
terry
Reply #501
good luck
terry
Here is how my foobar looks. I didn't change too much.
How I open my lyric plugin.
http://i39.tinypic.com/op2s78.jpg
The lyric plugin works fine.
http://i39.tinypic.com/dms5k5.jpg
I can't get the two windows to "stick" together, so when I minimize, the lyric window stays open, and I don't know how to minimize it.
http://i42.tinypic.com/2lbjgaw.jpg
My preferences > components page (I hope this is what you meant, let me know if I'm mistaken)
http://i40.tinypic.com/a29d84.jpg
Reply #503
Read http://wiki.hydrogenaudio.org/index.php?ti...ut_Editing_Mode
I do not think you have ever actually added lyric panel as a defined permanent panel in your foobar.
This explains your trouble.
terry
You should be able to figure it out from above instructions.
This as exactly what I needed. I didn't know how to define permanent panels.
Thank you so much for your help!
Reply #504
If it's possible to add a new lyric source, i adapted one of the database files to gather info from Terra Letras.
EDIT: Just reporting that after 100 tracks played it didn't crashed. Besides that first crash reported previously, wich i'm guessing was caused by the special characters on the filename/ track title.
Reply #505
New version with TRACK_CALL_TEXT Macros for future crash identification and corrected behavior when the "Save Filename Pattern" starts whit character "\"
Download the last version from here:
http://code.google.com/p/foo-display-lyrics/downloads/list
Please use this new version, because it adds crash tracking features.
@BrutuZ: If the component doesn't crash for 1 or 2 weeks, I'll try to add support for that site.
Reply #506
Hi !
Obviously, I'm the only one havin' a bug
I use Foobar 0.9.6.2. When I paste the dll in component folder, Foobar says this :
"Failed to load DLL: foo_uie_lyrics2.dll
Reason: La procédure spécifiée est introuvable.  "
Don't ask me what "La procédure spécifiée est introuvable" means, I'm french and I don't know what that means ^^
But foobar seems to find something that doesn't exist, at least in my actual configuration. Do we need some dll or other components that will help the lyrics plugin work ?
Reply #507
you need foobar v1 (or above).
Reply #508
It works, thanks ! I was too lazy to redefine my keyboard shortcuts and others, but it's done \o/
AND THIS PLUGIN IS GREAT !! It supports lrc files :3
But I have some problems, probably because I'm a total loser : why can't I edit in a external player the lyrics ?
And what should I use to create my own LRC ? Don't wanna install MiniLyrics for this, but if I have to ...
LOVE THIS PLUGIN !!!!
Reply #509
You can edit if the lyrics had been loaded locally. If it's set to save downloaded lyrics, just press "Reload Lyrics" and it will load the local version and enable the "Open in external editor" option
Reply #510
Just wanted to report that I had no crashes so far.
Latest version works like it should.
Thx Jano.
Question:
Is it possible to add a background image with let's say %foobar_path%
in portable mode and if so how?
Reply #511
The online service--leoslyrics.com seems not work, the console is always saying: "Timeout on host: api.leoslyrics.com".
And there is another console message "foo_uie_lyrics2: ReadInternetText: HttpQueryInfo(STATUS_TEXT) failed: not OK."
If this message is for searching the lyrics of the stream? The component needn't search the stream infomation of the song located in HDD, maybe there need a judge.
Reply #512
I have a "small" issue.
When I download a lyric (with online search function), the plugin just creates a empty text file with nothing in it. But if I check the URL from "about currect lyrics" and open it, the lyrics are there and fine.
It does the same even if I change the saving mode from file to tag, well not the same since it doesn't make the text file, but it still doesn't show any lyrics
Foobar v1.0.1 & Latest version of plugin, with Win7 64bit
E: Got it working, Proxy was blocking the connection or something, so the lyrics couldn't be moved into the file.
Reply #513
So far it worked without a crash.
Thank you for your hard work !
Reply #515
About the first message, i have leoslyrics selected and don't have this message, might've been a temporary problem with the service (like server maintenance) or some problem with your connection. (probably first cause)
About the second message, as i stated before i also receive it, every time actually, but it doesn't seem to actually affect anything since the plugin download the lyrics fine (as long as they are found on the servers though)
Reply #516
Thank your reply, BrutuZ..
I haven't download any lyrics from leo's lyrics, no matter select it or not. I guess the plug-in can't access this service.
Actually, it doesn't affect the downloading, I think it'll be efficient if the plug-in don't search the internet infomation when the songs located in HDD.
Reply #517
Yeah, but I'm trying to fix the bugs, not add, modify features or behavior. Maybe on august I'll have some time to work on features.
Timed Out Case: I was receiving the same message, until I put the Timeout value to 5000 ms in settings page. Then I received 0 result for any song I searched. When I entered to http://www.leoslyrics.com webpage and search for any term, one error was generated (Example Here), so I think the service is not available right now
Reply #518
I accidentally saw the change log, Michael87 had tried to fix this bug in 0.4.4, obviously the bug still exists.
0.4.4
- fixed bug "synced lyrics is sometimes saved to "unsynced lyrics" tag"
- fixed crash on "ReadInternetText: InternetReadFile failed" -> reported via foobar2000 crash dump upload (thx!)
- fixed crash on lyric refreshing -> reported via foobar2000 crash dump upload (thx!)
-added new commands "next lyrics, save, save to tag" to main menu forkeyboard shortcut possibility (in "View" -> "Lyric Show 2")
- possible fix for "ReadInternetText: HttpSendRequest failed" errors
Reply #519
Exactly 400 tracks played after the last update, and no crashes so far. I believe it's safe to say the problem has been solved.
Just wish it wouldn't load local lyric files from the wrong tracks. I have it to save all lytic in a subfolder called Lyrics inside the .mp3 folder, and search for %filename% within this folder with fuzziness search at 0%, but it often loads a file with a similar, but not equal filename. Guess it's loading files based on partial match, wich i believe it shouldn't based on my settings.
Reply #520
Thanx
great plugin
Reply #521
well almost a week exactly since i started using .13 then .14.
343 plays on my primary box (22:43:49 playtime)
also have 147 plays on my secondary (9:59:00 playtime).
absolutely zero crashes!
no need for additional features in my book; works great and is stable.
meets my needs completely.
Huge thanks Jano for squashing those last couple bugs!
Reply #522
I'm happy also  all I wanted  was a stable plug-in  , many thanks for  your effort ...
Reply #523
Unfortunately, I had a crash.
I was using the latest version of lyrisc plugin (0.4.6.14) and foobar v1.0.1, and for a long time having no problems with it.
And suddenly, while I was changing song to a previous one, foobar stopped, and a window with question about sending a report showed up.
Log: http://pastebin.com/dJrDqSxs
Reply #524
Working on It...
