Topic: HOW TO: synchronise your last.fm playback stats with foobar (Read 391441 times) previous topic - next topic
Reply #350
Haha, you are right. It's minor and doesn't have much to do with this.
It's weird because, I'm guessing, most tracks scrobble, but this track doesn't.. or these. All these FFVI songs don't seem to scrobble beyond one lastfm_playcount. Playing them again just shows:
Playcount sync: Last.fm responded 'OK'
Playcount sync: Playcount not updated. No changes found.
Now I really have nothing more to say, though I feel I basically repeated myself practically.
Reply #351
i suspect that's the last.fm spelling correction at work. check your profile page for recent scrobbles against your tags and you might see what's different. this subject was covered a few page back...
edit: the reason it shows "1" on the first play is because i'm faking it. i add 1 to whatever is returned by last.fm to take into account a scrobble isn't counted until playback stops.
Reply #352
So marc... quick question.
How hard would it be for me to edit the current version of the script to write regular tags instead of custom_db? Is it just a matter of changing the %custom_db% fields in the script to my desired fields?
Reply #353
Thanks.. looks nice!
Where do i place that $ifequal(%LASTFM_LOVED_DB%,1,♥,) command?
Edit, FooText is able to output the scriptcommand.. but how do i integrate it inside the Playlist-panel like you did, shown in this image?
I cannot add it as a Custom Column, like i did with "%LASTFM_PLAYCOUNT_DB%".. that one works fine
Reply #354
if you're running XP you need to install asian font support to get the ♥ symbol. other than that, it should work anywhere as it's just normal title formatting.
Reply #355
Still wondering if this would work... I mean I guess I could try, but I'd rather not screw with my current script unless this is possible. The only reason I'd try this is because the last version of your script that supported actual tag writing is pretty old at this point.
Reply #356
i've made the necessary modifications here. remember the library import still requires customdb - it's not possible to do that with file tagging.
http://pastie.org/1020191
Reply #358
i just realised i forgot to remove an extra line i put in for testing. remove line 91.
Reply #359
As last.fm autocorrects some artist names, it is not possible to "love" tracks of this artists directly from foobar2000 - in fact you "love" either track, not track that will be scrobbled.
And here is my question: is it possible to autocorrect this artists' names using some info requested from last.fm. It would be great to see plugin that will be able to do it.
Or maybe it would be better to autocorrect artist name "on the fly" before loving the track?
🇺🇦 Glory to Ukraine!
Reply #360
I believe Last.fm are working on a new version of the API to allow this very feature. (The "update metadata from Last.fm corrections" one.)
Reply #361
So, then I'll ask marc2003 for including this feature into the next playcount sync versions.
Reply #362
the love track feature is provided by foo_softplaylists. nothing i can do about that.
Reply #363
So, the only way to go is creating special plugin, something like tagger, right?  it would be nice to see this plugin...
Reply #364
If I'm remembering (and understanding) the blog post properly, the correction data would be sent back over the API protocol at the time of submission, so it would probably be best incorporated in foo_audioscrobbler (or something similar).
Reply #365
I'm sorry but I'm new to foobar (as in I just downloaded it a few hours ago), but I wanted to try out this plugin. I don't what the instructions meant by "add a WSH panel to your layout."
Could someone help me out with this?
Reply #367
Yeah. I feel like I'm doing this completely wrong.
My foobar looks like this now:
Reply #368
i'm not really sure how you managed that. goto the view menu>layout>quick setup and pick something from the "main layout" on the left hand side. there really isn't much else i can say apart from read that first link again.
Reply #369
I went to View > Layout > Create Scratchbox then right click > Add New UI Element > WSH Panel Mod. I imported the playcount sync script, then hit apply and okay. Edit > Apply Layout and then that's it.
I'm using the Album List + Properties Layout.
What could I be doing wrong?
Reply #370
Nevermind. I got it working.
Reply #371
I followed all the instructions, everything installed correctly, and both test.sql and customdb_sqlite.db are populated, but the playcount list remains empty, as does the loved column.
Console output:
Opening track for playback: "Z:\Music\Full Albums\65daysofstatic\[65 Days Of Static] - One Time For All Time\01 - Drove Through Ghosts To Get Here.flac"
Playcount sync: Contacting Last.fm....
This track is loved and has plays already, but the columns are still empty. Just to try I tested with a mp3 version of the track but the issue persists.
Reply #372
right click any track in the playlist and look under "Legacy Commands (unsorted)". do you see 4 customdb entries like this?
Customdb Love 1
Customdb Love 0
Customdb Delete Playcount
Customdb Refresh
if not, then you didn't put foo_customdb.dll.cfg in the correct place. check the readme again.... (and make sure foobar is closed while you do it)
if the context menu is correct, what happens when you open a library search window and type in
%LASTFM_PLAYCOUNT_DB% PRESENT
also it might be worth looking under preferences>tools>custom database>database tab. how many entries are there?
Reply #373
Sorted, I presume that the cfg was overwritten when I closed and reopened F2K with the old version. Works perfectly, cheers!
Reply #374
i'll update the readme so hopefully it won't happen again.
