Topic: List of AAC encoders (Read 39840 times) previous topic - next topic
  • IgorC
It will be useful to gather information about good AAC encoders for listening tests and future selection of an optimal encoder.
Obviously, the lists are not complete yet.
Competitive AAC encoders:
1. Apple
2. Nero
3. Coding Technologies (now  Dolby)
4. Fraunhofer. Sorenson Squeeze and Magix application(?). Have they the updated and full functionality version of Fraunhofer encoder?
[Possibly] Obsolete or noncompetitive AAC encoders:
1. FAAC http://www.audiocoding.com/
2. Psytel
3. MPEG4ip Cisco. http://www.mpeg4ip.net/
4. 3GPP reference encoder. It was tested in Gabriel's 48 kbits HE-AAC test
AAC encoders with unknown quality
1. RealAudio 10. RealPlayer v12 (2009)
2. AVS audio converter
3. Lead AAC encoder
4. Divx (same as Mainconcept)
5. Microsoft Expression Encoder 2 SP 1
If anyone knows about any good AAC encoder post here.
  • Last Edit: 08 December, 2009, 04:08:37 AM by Synthetic Soul
Back in the day there was something called Liquid Audio (IIRC). They had an early AAC encoder which was slow and cumbersome. It wasn't free either. I searched for it and ended up with something called AVS Audio Converter. I have no idea whatsoever about quality or speed, nada. But it might be worth checking out.
//From the barren lands of the Northsmen
I was going to mention Liquid Audio.  I remember that from really back in the day.  My PC actually came with a copy of their software that allowed for unlimited CD ripping.  The only thing is that the application would consume over 40% of my 256MHz processor (Pentium II mmx) and 50% of my 256MB of RAM.  Not something I like especially considering that the software that came with my Rio 600 consumed far less.
Sony has an AAC encoder that they put in their PS3, I believe it is also in their Media Go software.  I am not sure if the encoder was developed by Sony.  The PS3 version wraps the AAC audio in a 3gp container.  Something to think about.  I could always encode a 30 second test file (I would have to burn an audio CD from the source lossless file) using my PS3 and upload it if you wanted to examine the encoder.  There is also something called the LEAD AAC encoder.  Lastly, I believe that there is an ffmpeg AAC encoder floating around somewhere.
I don't know if any of these encoders are actually good but they are something else to look at.  The AAC encoder used by the PS3 has not been tested but I know that many, many, many, many people use it for their audio ripping needs (not that user community size is a measure of quality).
  • Sylph
Audio Transcoder used FAAC and now uses Nero.
P. S. Does Sorenson offer audio encoding?
  • Last Edit: 07 December, 2009, 03:37:22 AM by Sylph
  • Larson
There is also DivX AAC Encoder (beta 1 from august).
  • Sylph
MAGIX has an MP3 Maker application which uses Fraunhofer's AAC.
  • Last Edit: 07 December, 2009, 05:08:57 AM by Sylph
Microsoft Expression Encoder 2 SP 1 and higher support H.264 and LC-AAC encoding. Don't know what encoder is behind that, though.
  • Sylph
There's also MainConcept AAC in Sound Forge, e.g.
  • UVSM
What AAC Encoder was used in Nokia Multimedia Player 6??? (There was LTP Profile only and CBR only)
  • Dynamic
Do you mean to write LC profile? I don't think Long Term Prediction (LTP) has been implemented in encoders or decoders to date.
  • IgorC
Thanks to Everybody for answers. There's a lot of work to verify quality of encoders. But I think some of them can be discard at early stage.
Ok. It will be deleted from list of AAC encoders.
Divx and Mainconcept have the same AAC encoder.
AAC encoders which were mentioned in this topic will be added to list of main post.
IIRC some person called Kostya worked on it. The main target was higher than FAAC quality. Didn't find more information.
Apple iPhone® SDK is based on Fraunhofer code. That means Fraunhofer AAC encoder is potentially very competetive.
  • Last Edit: 07 December, 2009, 07:41:24 PM by IgorC
  • Sylph
This is a preparation for some kind of all-AAC listening test?
I thought so too, given that MainConcept is the subsidiary of DivX, Inc., but the DivX Labs page (http://labs.divx.com/node/11682) seems to imply that's it's something new, as if there were two versions - I doubt Sony would implement a beta into their precious software.
  • Last Edit: 08 December, 2009, 04:58:32 AM by Sylph
  • Sylph
As for your question about the full functionality of MAGIX MP3 Maker, it offers bitrates up to 256 kbps stereo even though FhG can go up to 512. Same goes for AVS application: 256 is the maximum setting.
I don't know about Sorenson.
  • Last Edit: 08 December, 2009, 04:54:48 AM by Sylph
  • kurtnoise
which is not free iirc...the only free way is to use the libraries from win7 but the AAC encoder is very limited (LC only - 128/160/192kbps as target bitrates).
  • capma
Screenshot from latest Sorensen Squeeze 6.
  • IgorC
Did you tried? How is it comparable to other AAC encoders?
  • IgorC
Is Coding Technologies AAC encoder is only option in Sorensen Squeeze 6?
The initial  idea is create a list of AAC encoders. Then at least it will be personal test from my part or a public test is an option too.
  • Last Edit: 08 December, 2009, 11:59:48 AM by IgorC
  • capma
Yes, its only options for AAC encoding.
  • Sylph
No. I have MAGIX, so if you need it for testing purposes, I could convert a file for you.
So Dolby's (CT's) AAC is now present in: Winamp Pro, Easy CD-DA Extractor and Sorenson Squeeze.
Fraunhofer, as far as I know, only in MP3 Maker. It's probably the codec that's the most intriguing for AAC people on HA since it's nowhere to be found and the Gesellschaft doesn't give it away for testing. Only if you're a research scientist in some university or institute.
OK. This should be interesting. I'd love it if there were a newer public test for Apple, Nero, Dolby, Fraunhofer, Real and possibly AVS if it's confirmed it's a separate type.
  • Sylph
This is the settings window in MAGIX:
  • agillis
The VortexBox project is using ffmpg to convert the files to AAC and the mp4v2 project code to set the tags correctly. It seem to work very will and the quality is excellent.
  • IgorC
I downloaded the last demo version of MAGIX MP3 15 (ver 10.00) maker from official site. Quality isn't bad but only CBR and no miracle at low/middle bitrates.
  • Last Edit: 10 December, 2009, 11:26:01 PM by IgorC
  • Mr VacBob
It was being developed further by Alex Converse/peloverde, but he stopped to work on the ffmpeg-native SBR decoder. I don't know how it progressed before that, but you can find the source in ffmpeg svn somewhere.
  • Last Edit: 11 December, 2009, 12:40:49 AM by Mr VacBob
  • Sylph
If it were a miracle, a lot of people would be using it. You shouldn't have expected a miracle.
  • C.R.Helmrich
  • Developer
Could you elaborate, please? Which bitrates do you mean by low/middle?
Thanks,
Chris
