Topic: Programming Question (Read 3013 times) previous topic - next topic
i'm not a programmer, but i need a statusbar about playmode (random, imprtend 'Stop after current'). Can me help anybody? Thanks
if you are using column UI and WSH Panel Mode you may try this for playmode
function RGB(r,g,b){ return (0xff000000|(r<<16)|(g<<8)|(b)); }
var PlaybackOrder = {
Default: 0,
RepeatPlaylist: 1,
RepeatTrack: 2,
Random: 3,
ShuffleTracks: 4,
ShuffleAlbums: 5,
ShuffleFolders: 6
DT_CENTER = 0x00000001;
DT_VCENTER = 0x00000004;
DT_SINGLELINE = 0x00000020;
var PlaybackOrderText = new Array(
"Default", // = 0
"Repeat (Playlist)",
"Repeat (Track)",
"Random",
"Shuffle (tracks)",
"Shuffle (albums)",
"Shuffle (folders)") ;
var g_font = gdi.Font("Tahoma", 10, 1);
var g_drag = 0;
var txt = "";
//var bool;
//var  imgl; var imgr; var imgm;
//var ih=24; var iw=104;
var hofset = 4;
var vofset = 2;
window.MinWidth = 20;
on_playback_order_changed(fb.PlaybackOrder);
function on_paint(gr){
gr.SetTextRenderingHint(2);
gr.SetSmoothingMode(2);
gr.FillGradRect(hofset+1, vofset+1, window.Width - 2*hofset - 2, window.Height - 2*vofset - 1, 45, RGB(240,240,226), RGB(192,192,192));
gr.DrawRoundRect(hofset+1, vofset+1, window.Width - 2*hofset, window.Height - 2*vofset, 3, 3, 1, RGB(255,255,255));
gr.DrawRoundRect(hofset, vofset, window.Width - 2*hofset, window.Height - 2*vofset, 3, 3, 1, RGB(128,128,128));
gr.GdiDrawText(txt, g_font, RGB(255,255,255), hofset+3, vofset+2, window.Width - 2*hofset - 2, window.Height - 2*vofset - 1, DT_CENTER | DT_VCENTER | DT_SINGLELINE);
gr.GdiDrawText(txt, g_font, RGB(0,0,0), hofset+2, vofset+1, window.Width - 2*hofset - 2, window.Height - 2*vofset - 1, DT_CENTER | DT_VCENTER | DT_SINGLELINE);
function on_mouse_wheel(delta){
if(delta>0) {if (fb.PlaybackOrder==6) fb.PlaybackOrder=0;
else fb.PlaybackOrder= fb.PlaybackOrder+1;}
else
{if (fb.PlaybackOrder==0) fb.PlaybackOrder=6;
else fb.PlaybackOrder= fb.PlaybackOrder-1;}
function on_mouse_lbtn_up(x,y){
if (fb.PlaybackOrder==0) fb.PlaybackOrder=4;
else fb.PlaybackOrder= 0;
// fb.trace("order="+fb.PlaybackOrder)
g_drag = 0;
function on_playback_order_changed(new_order_index) {
txt = PlaybackOrderText[fb.PlaybackOrder];
window.Repaint();
//EOF
and this for stop after current
var g_drag = 0;
var imgname;
var img;
var g_tooltip = window.CreateTooltip();
function on_init(bool) {
imgname =bool  ?  "sac.png" : "playing.png";
g_tooltip.Text =  bool  ?    "Stop after Current" : "Reset stop";
img = gdi.image(fb.FoobarPath + "Images\\" + imgname);
window.Repaint();
window.MinWidth = 25;
on_init(fb.StopAfterCurrent);
gr.DrawImage(img, 4, 2, 21, 20, 0, 0, 21 , 20);
gr.DrawLine(0, 2, 19, 2, 1, RGB(255,255,255));
gr.DrawLine(0, 2, 0,18, 1, RGB(255,255,255));
gr.DrawLine(1, 20, 12, 20, 1, RGB(128,128,128));
gr.DrawLine(20, 3, 20, 14, 1, RGB(128,128,128));
function on_mouse_move(x, y) {
if (g_drag==0) {
on_init(!fb.StopAfterCurrent);
g_drag = 1;
g_tooltip.Activate();
function on_mouse_leave() {
if (g_drag==1) {
g_drag = 0;
g_tooltip.Deactivate();
fb.StopAfterCurrent = !fb.StopAfterCurrent;
window.Repaint();
// g_drag = 0;
function on_playlist_stop_after_current_changed(state) {on_init(fb.StopAfterCurrent);}
//EOF
note that you will need sac.png and playing.png to be placed in foobar/images directory
thank you for this fast answer. But where i can get the images (sac.png, playing.png)?
Here:
and here ...
Thank You so mutch. I have a last question:
What i do with the script? i have searched and looked and found no help about this...
ok, i found it myself and it works fine! Thank you again.
Close.
Knut
