Topic: send to playlist/temporary entry (Read 1895 times) previous topic - next topic
  • juglesh
Hi, in 8.3 i have a keyboard shurtcut to "send to playlist/temporary entry"  This sends the song to the previous (left tab) playlist, and focuses the playlist.
is there something like this in 9.6.9?  the thing i see is "send to playlist..." which asks you every time which  playlist you want it sent to.
what i do in 8.3 is open a blank pl in a tab, then my 'all' playlist.  i can easy make cd's or pl's by hitting S (to send it to the blank pl) and then W (focus back to the 'all' pl, via Previous Playlist)
thanks
juglesh        B>{)}
www.RadioKDUG.com
  • tpijag
Use Foosion  foo_util
http://foosion.foobar2000.org/components/?...on=0.6.2+beta+6
You can bind key to specific playlist. Don't think it will work exactly as your explained workflow...but it may get you acceptably close.
terry
  • 2E7AH
or Ctrl-C + Ctrl-PgDn (bind to "previous playlist" command) + Ctrl-V
  • trout
foo_utils will give you "send to" shortcuts to a specific playlist
http://www.hydrogenaudio.org/forums/lofive...php/t18276.html
edit : sorry about repeated info
  • Last Edit: 21 November, 2009, 03:15:11 PM by trout
~ Sorry for my bad english.
  • juglesh
yep, utils works, thanks ppl
it will only send or add to a named pl.  so you have to make a 'collector' pl, name it something, bind 'add to playlist: collector' to shortcut.  if you remove 'collector' pl, you will have an error in your shortcut prefs, but it seems like if you recreate it, the shortcut will work again.
so, yeah, that pretty much solves it  thanks
juglesh        B>{)}
www.RadioKDUG.com
