Topic: need hint for button icons (Read 4507 times) previous topic - next topic
hi-
i d like to put an icon to a created button . The Button is there, but i only can see it when i move mouse over, cos there is no icon.
When i go to CUSTOMIZE BUTTONS under the current configuration, i can see the button to be assigned, but when i use CHANGE ICON, a file window opens, asking where the icon is.
Now what format does the icon have if i should make my own, or where can i point to for button icons anyway?
thanks
tonne
.ico
Icon format. 16x16 I believe
The file window should have indicated to you at the bottom of it what it is looking for...
elevatorladylevitateme
it asks "icon files" - but i dont know how to make one.
I guess just a pict 16x16 and then rename it with .ico suffix wont do the job.
should i give up?
thanks again
Google for "Icon Sushi" or any other program to convert bmp/png/psd to ico
ConvertICO  is a Free Online Converter - fast (you don't need to register or to install software) and easy to use (you need only 3 clicks to convert the PNG or ICO file) - able to convert PNG to ICO
http://www.convertico.com/
I've used this site to convert 16x16 PNG images (w/ transparent background when necessary) to icons for use as foobar buttons, it works very well.
bingo - working!
there is always a first time....
thanks a lot, i´ll iconificate the world from now !
greeeeetz
tonne
