Topic: Problem samples for MP3 (Read 7979 times) previous topic - next topic
Ringing on all acoustic tracks sometimes up to V0 (angels is the worse). Preecho on jane doe upto V1. Distorted vocal [rita] @ 2 secs and big one @ 6 secs
wavpack 4.8 -b256hx6c
Thanks for your samples, shadowking.
I'm most afraid of distortions in vocals, so I tried rita.
At -V5 I could easily ABX the problem.
As I usually encode using -V0 or -V1.5 (together with --lowpass 16.7) I encoded with these settings.
Results were fine to me.
Did you encounter the rita problems with higher settings?
What were the problems for -V0? (I tried angels using -V0 - can you give a hint for the critical spot
in case there were problems with angel at -V0).
lame3995o -Q1.7
opus --bitrate 140
Thanks for testing.
With rita, i tested V1 -Y last week . I initially got confused but after longer pauses i could abx.
With angels the 1st "twang"  is the most distorted. Its a 'ghosting' or tremolo of the note . With the volume slightly raised i hear it in normal listening @ V0.
I tried again using -V1.5 --lowpass 16.7, but didn't succeed.
Probably I didn't try hard enough or my hearing isn't good enough, and with angel I unfortunately didn't hear something that sounded like a 'twang' to me.
Anyway I also experienced issues with mp3 other than the well-known pre-echo ones even at a HQ setting like -V0 or similar.
Luckily so far these issues have always been subtle to me when using HQ settings, and I'm glad this doesn't change with your samples.
lame3995o -Q1.7
opus --bitrate 140
With -V0 being pretty strong with 3.98 I have always wondered whether there is quality improvement when going up to --abr 285 -h (or similar) or -b 320 for those problems where -V0 isn't perfect.
If you have the time, shadowking, would you mind trying extremely high quality settings like those I mentioned on your sample?
lame3995o -Q1.7
opus --bitrate 140
I noticed some nice progress with lame 3100 alpha2 on 01-Rita...
The vocal dropout is much more subtle . I would say V4 is not annoying and V3 needed concentration to abx and would go unnoticed in normal listening.
Just to be sure I went back to 3.99 / 3.98 and V4 was much more obvious.
Thanks for the info.
There's been experience before that 3.100a2 yields certain improvement over 3.99, and any further experience (be it good or bad) is very welcome.
lame3995o -Q1.7
opus --bitrate 140
