Topic: Error building FAAC (DRM) (Read 5289 times) previous topic - next topic
Im trying to compile FAAC for DRM use, but i keep getting the same error. I've removed the "//" in the #Define DRM line in coder.h. As a result, all references of DRM (ifdef DRM) are enabled in all source files, except for fft.c. So i included a #define DRM directly in fft.c, but now i get several compilation errors saying cfg is not a member of fft_tables.
Is this some kind of a bug? Does anyone knows how do to solve it?
PS: im using  ms virtual studio 2008
i've tried in dev c++ and it was no use too.
Which version of faac are you trying to compile? 1.28 appears to come with the appropriate defines and includes VS project files for the DRM versions. I've not tried compiling them myself, but if you're trying to use an earlier version, I'd give 1.28 a try.
i'm already using version 1.28 =\
DRM-1024 works fine, but DRM 960 does not work at all
Ah, OK, then I can't offer any assistance not having tried to compile it with those switches.
Well done.  Always more satisfying!
