Topic: AAC, Mp4 And M4a File Properties (Read 7765 times) previous topic - next topic
Hello All:
Do any of you know any app that can read AAC, Mp4 and M4a file properties accurately?
WXP can't, and neither can EncSpot Pro, dBpowerAMP, Media Info, Mr. Questionman, Audio Identifier, and anything else I have tried.
I want to get the bit rate, sample size, sample rate, encoder settings, etc.
I am using both Nero 9 and EAC with NeroAacenc.exe to rip files, and I can't get any readings from the ripped files with either the .aac, .mp4 or .m4a extensions.
Any advice or URLs you could provide would be greatly appreciated.
Thanks in advance for your consideration.
Marc
Windows 7 natively handles AAC and mp4,bitrate cover art appear properly. For advanced informations dbpoweramp does its job great =D
MediaInfo doesnt?
The text or tree view both give out a lot of info:
http://mediainfo.sourceforge.net/en/ScreenShots/GUI_Main
The command line version is good too...
Here is a sample of the command line output for a .mp4 file encodec with neroaacenc:
Format                          : MPEG-4
Format profile                  : 3GPP Media Release 6 Basic
Codec ID                        : 3gp6
File size                        : 1.32 MiB
Duration                        : 3mn 53s
Overall bit rate                : 47.4 Kbps
Encoded date                    : UTC 2009-12-01 19:15:51
Tagged date                      : UTC 2009-12-01 19:16:02
Writing application              : Nero AAC codec / 1.3.3.0
cdec                            : ndaudio 1.3.3.0 / -q 0.16
Audio
Format                          : AAC
Format/Info                      : Advanced Audio Codec
Format version                  : Version 4
Format profile                  : LC
Format settings, SBR            : Yes
Format settings, PS              : No
Codec ID                        : 40
Duration                        : 3mn 53s
Bit rate mode                    : Variable
Bit rate                        : 48.0 Kbps
Maximum bit rate                : 55.4 Kbps
Channel(s)                      : 2 channels
Channel positions                : L R
Sampling rate                    : 44.1 KHz
Resolution                      : 16 bits
Stream size                      : 1.29 MiB (98%)
