Topic: WMP Tag Plus - MPEG4, Vorbis and FLAC metadata support for WMP (Read 370722 times) previous topic - next topic
  • db1989
  • Global Moderator
Reply #450
FWIW, I interpret that to mean that WMPT+ will re-read the tags, rather than writing anything, but I don’t want to say anything conclusive as I’m not Tim.
  • Tim De Baets
Reply #451
This makes it sound like the audio files are going to be modified.  Are they?
If they do have to change, are the last-modified dates preserved?
Does any other function of WMP Tag Plus modify the files?
WMP Tag Plus will in fact modify the files when it sees that some tags have already been edited. It will keep these edits and re-apply them after the files have been re-added to the library. This will also affect the last-modification date. If you don't want this, then you will have to re-add the files to the library manually.
And yes, WMP Tag Plus also modifies files during normal use. Most tag changes that are made in the library get saved to file.
  • Last Edit: 07 July, 2012, 04:28:23 PM by Tim De Baets
  • mjb2006
Reply #452
Thanks for the quick reply.
I expect that if I were deliberately making changes to tags, this would result in the files changing, by definition. But I also expect that just playing or reading tags from whatever's in the library wouldn't require anything but reading the files, no rewriting of them necessary. To that end, I have WMP configured to not modify files during normal use. In WMP's options:
  • Library tab - everything is unchecked, including 'Retrieve additional information from the Internet' and 'Maintain my star ratings as global ratings in files'.
  • Privacy tab - 'Update music files by retrieving media info from the Internet' is unchecked.
This normally allows me to play anything in the library and otherwise use WMP without having to worry that files are being changed for no reason. Also, whatever changes I make in the library (not through WMP) are reflected in WMP's view of the library, and this includes modified tags.
But if I understand what you're saying, WMP Tag Plus will be routinely rewriting tags. Why does it need to do this? Why can't it just read the files like WMP normally does? (Or am I misunderstanding something?)
  • Last Edit: 08 July, 2012, 02:38:09 AM by mjb2006
  • Tim De Baets
Reply #453
I think that you misunderstood me. Excluding the 'Refresh song tags' case, WMP Tag Plus will only write to file when changes are made in the library. It will definitely not randomly rewrite tags.
By the way, WMP Tag Plus only writes to file when it is instructed to do so by WMP. This means that there shouldn't be any difference in writing behaviour compared to MP3 or WMA.
  • mjb2006
Reply #454
OK, that helps. Sorry for the confusion.
So the best way to get the FLACs currently in my library re-scanned without being rewritten, then, is to remove the FLAC-containing folders from the library (via Explorer) and then re-add them there?
  • Tim De Baets
Reply #455
No problem
You can also re-add the FLAC files by selecting them in WMP, right-clicking, Delete - Delete from library only - OK. Then go to Tools - Advanced and select Restore deleted library items. I personally find that the best way, but re-adding library locations should work equally well.
Reply #456
Are you sure that the option to add ALAC files to the Music section is checked, on the Apple Lossless tab of WMP Tag Plus settings?
Would it be possible for you to upload one of the affected ALAC files, so I can try it myself? You can upload it to a file sharing website like Skydrive or Rapidshare and send me the download link in a private message on this forum. Thanks!
Edit: suur13 and I troubleshooted further through PM and we eventually found the cause of the problem: TaglibHandler replaces Windows 7's built-in MPEG-4 property handler with its own handler. This prevents WMP Tag Plus from recognizing ALAC files and from forcing them into the Music section. Uninstalling TaglibHandler didn't help because that didn't re-register the Windows 7 property handler. The solution was to re-register the Windows 7 property handler manually in the registry.
Hi Tim,
I have been trying to get ALAC files to behave without hiding under the Other Media section, but so far no luck. I may be having the same issue that is described from what you handled with suur13. Can you help with some guidance on how to re-register the handler in this case?
Thanks in advance, and for all of the work you have done so far.
  • Tim De Baets
Reply #457
Are you also running Windows 7 and do you have TaglibHandler installed, or had it installed at one point?
If so, Windows 7's built-in MPEG-4 property handler can be re-registered by copy/pasting the following into Notepad, saving it as a M4APropHandler.reg file, and double-clicking this file to add it to the registry:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\PropertySystem\PropertyHandlers\.m4a]
@="{f81b1b56-7613-4ee4-bc05-1fab5de5c07e}"
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\PropertySystem\PropertyHandlers\.m4a]
You may need to reboot afterwards. Does that help?
Reply #458
Wow, super-fast reply! Sorry, should have included this, but yes I am on Win7 x32. TaglibHandler may have been installed as part of the ALAC encoder included with dbPoweramp? Before changing the registry I checked the keys above. The Microsoft key had a different value in the default line, but the dbPoweramp key in the second line did match. And the Wow6432Node key did not exist at all. Thanks for supplying the registry settings. This fixed the issue once it was run (and rebooted), and the keys both now match.
Finally have WMP12 playing these ALAC files, and sorting them under the Music section!
Thanks again for all your hard work. I'll be sure to send you a token of appreciation via your site!
Reply #459
Tim, i just wanna thank you for all of the new features of WMP Tag Plus, mostly the FLAC album art support!
Reply #460
Hi, I'm a brand-new user of WMP 12 and Tag Editor Plus (moving over from Media Monkey.) Sometimes I want to make a playlist of cover versions of songs by a certain artist, but I can't get WMP to display the Original Artist tag in a column of the library. (I used the Original Artist tag in Media Monkey to identify which songs were covers.)
I can see the Original Artist tag in Tag Editor Plus (under the Advanced tag), so I know it's being read. It doesn't have a little pencil on the icon, so apparently I can't edit it. When I right-click it and click "Add", I get a drop-down menu of uncertain purpose, but the Original Artist still doesn't appear.
What can I do to get the Original Artist column (or, for that matter, any of the other more "obscure" tags to show up in a Library column. My guess is the solution 1) is blindingly obvious to all but a complete noob like myself or 2)impossible and I should just give up and go back to Media Monkey.
Either way, I'd appreciate any help that may be forthcoming here.
Reply #461
I have a question.  I want to use WMP 12 64bit with WMP Tag Plus 2.1.  I had it working with 32 bit version but I want to use it on 64 bit WMP12.  How do I make it so that the 64 bit version will be the main media player that the WMP Tag Plus will use?
  • Tim De Baets
Reply #462
You can't - WMP Tag Plus doesn't support the 64-bit version of WMP, only the 32-bit version is supported.
  • zafer
Reply #463
Hello Tim !
I was checking Taglib's page, and by chance I found this in the current 1.8 beta release info : "Support for reading audio properties from ALAC and Musepack SV8 files" So great news I guess
I have a question not regarding tag reading, but similar to one issue mentioned in this thread some weeks ago. If you don't happen to have the answer, just disregard it. So here is the question : how by changing registry settings can I force WMP to store "mod" files in Music library and not in other media. I saw a fix for mp4, tried it with mod, but it didn't work. Any clue?
Thanks for eveything
  • Tim De Baets
Reply #464
You could simply use WMP Tag Plus for this, even though MOD isn't a supported format. Head to WMP Tag Plus settings, add mod to the list of supported file extensions and set its format to, for example, FLAC (it doesn't really matter which format). Then restart WMP.
If your MOD files are still in Other media after restarting WMP, you can use Refresh song tags (WMP Tag Plus settings - Tools) to move them to Music. Once the files are in Music you can remove mod again from WMP Tag Plus's list of supported extensions.
  • zafer
Reply #465
Thanks for your answer Tim .
I tried, but it didn't work.
There are two extensions showing in Other Media : mod and mid.
Now I have no idea why mod shows in other media, since it is not a native format in WMP.
I understand that MS wants mid files (general midi) to appear in other media.
So I tried with both : I added in WMP Tag Plus the mod and mid extensions, associated with FLAC (mod) and APE (mid), Applied changes, restarted WMP, refreshed tags (at amazing speed as usual ) and they are still in other media.
So I tried the following : removed them from the library, then dragged and dropped them back, and they still appear in other media
I have no idea. I hope I didn't mess the registry entries for these formats with my previous unsuccessful attempts...
  • Last Edit: 18 August, 2012, 04:23:13 PM by zafer
  • Tim De Baets
Reply #466
I have looked into some things on my Windows 7 system to see if I could get .mod files to appear in Music instead of Other media.
It seems that MOD is in fact a native format in WMP (and Windows). However, this isn't the MOD audio format, but a video format used for digital tapeless camcorders that has the same name and file extension and is MPEG2 encoded. See the MOD and TOD article at Wikipedia.
This means that whenever WMP tries to get the tags of a .mod file in the audio format, the native MOD parser returns an "invalid format" error. This can be prevented by removing the registration of the native MOD parser with the .mod file extension (by editing the registry).
But even after removing that registration, .mod files were still added to Other media although I was sure that all the required registry settings for WMP to recognize MOD as music were correct. Further investigation revealed that WMP is hardcoded to add .mod files to Other media (just like it is for .mid). So unfortunately I don't see any immediate way to get .mod files to show up in Music.
  • zafer
Reply #467
I understand. Indeed, I remember that I spent hours working on the registry in vain. So that would explain where the problem comes from.
Anyway, this is not a big issue. I guess having my musepack files displaying proper length is much more important
Tim, sincerely, many thanks for taking the time to look into that, and for all the useful information
  • zafer
Reply #468
Hi Tim !
I just notices that a new final version of taglib has been released, with support for what was lacking before (such as mpc v8 audio properties)... Would you release a new version of WMP Tag plus with the new taglib ?
Cheers
  • Tim De Baets
Reply #469
Yes, I'm planning to release a new version of WMP Tag Plus soon.
  • zafer
Reply #470
thanks  i'll be checking so i'll be the first to test it
  • EpicForever
Reply #471
I'm not sure if I was careful enough in fast reading of this topic, but I think I didn't faound here the answer to question that was aksed here several times - is it possible to display FLAC album art and metadata infos in Windows Explorer in Windows 7? Yes it is. On both x86 and x64.
http://www.mediafire.com/?2o8o1z5so3l2l6k
100% tested on x64.
Reply #472
100% tested on x64.
And that file is what?  A virus... ?
  • EpicForever
Reply #473
Unfortunately no. It's just FLAC preview handler. RAR contains just 2 execs - one installer for x86 systems and the other one for x64 systems. Sorry, no virus...
Just download it and check with your AV before you use it if you aren't sure.
  • Robbidoo
Reply #474
Sorry to drag up what I'm sure has been answered before (but I couldn't see a FAQ nor anywhere else to ask on the WMP Tag Plus page).
I have been ripping a bunch of CDs to ALAC using MyMovies, and I was wondering how often WMP will scan the new files and move them out of "Other media" into Music?
If I run the "Refresh song tags" option from the WMP Tag Plus dialog, they are all edited and categorised correctly. I did read somewhere that WMP should be doing this periodically without user input? Is that the case, and if so how often is it done? (3 days and counting for me).
Thanks for a great plugin!
