Topic: Why does there seem to be a lack of interest in Musepack? (Read 58220 times) previous topic - next topic
  • 2Bdecided
  • Developer
I think those who have a mpc music library and no current compatibility issue with players used don't have a real need actually to switch to another format.
They do - they need to re-rip to lossless while they still can. If they wait until the next new DAP/car/phone/whatever they want to buy doesn't have MPC support, they might find they don't have the time / hardware / CDs left to re-rip then!
Assuming the people who ripped entire collections to MPC originally are the kind who care about audio quality and technology - these are the very people that are going to find being stuck with MPC a serious inconvenience first.
People who don't care about technology might keep listening on the same old devices. People who don't care about audio quality could just transcode MPC to mp3. But I don't think such people used MPC in the first place. I could be wrong.
  • Antonski
The public interest has shifted down to the fight for <=128 - where I have not noticed serious competition from MPC.
Mainly because nowadays  the music is listened in noisy environment and as a background (DAPs, USB car players, streaming to mobile phones etc.), I believe.
From personal tests i find Musepack to be a poor performer at low bitrates such as 96kbps - 128kbps, i even find --standard to be easy to ABX. At high bitrates such as 210 (Xtreme) it's very competitive.
Musepack has never been optimized for low/midrange bitrates, IIRC.
What is there to talk about anyway? Listening tests? With little to no development, what's the use?
Other problem i see is that for a long time, it was almost abandoned, and no new dev was being done.
This is how i see it.
Little to no development? How would you comment this:
[code]
08/04/09:
22:11 Changeset [452] by r2d
         libmpc/trunk/mpcenc/config.h
   libmpc (mpcenc) : * improved file extension conversion to .mpc * version …
08/03/09:
12:51 Changeset [451] by r2d
         libmpc/trunk/CMakeLists.txt
   libmpc : * shared option default to on, unless on windows
12:44 Changeset [450] by r2d
   libmpc (patch by Samuli Suominen) : * add install target for cmake * add …
07/31/09:
15:38 Changeset [449] by r2d
         libmpc/trunk/libmpcdec/mpcdec_math.h
   libmpc : * typo
15:37 Changeset [448] by r2d
         libmpc/trunk/include/mpc/mpcmath.h
   libmpc : * moved math.h include in mpcmath.h
15:03 Changeset [447] by r2d
         libreplaygain/src/CMakeLists.txt
   libreplaygain : * cmake improvement
14:58 Changeset [446] by r2d
         libcuefile/trunk/src/CMakeLists.txt
   libcuefile : * add a shared library target to cmake * add install target …
07/30/09:
00:00 Changeset [445] by r2d
         libmpc/trunk/Makefile.am
   * autotool changes to support symbol visibility on MinGW. * mpcchap build …
06/24/09:
23:45 Changeset [444] by r2d
         libmpc/trunk/mpcdec/mpcdec.c
   patch by Dr. Fiemost : fixed an error when building mpcdec on MinGW since …
23:22 Changeset [443] by r2d
         libmpc/trunk/common/crc32.c
   renamed crc32 to mpc_crc32 to avoid name conflics with static libs
03/31/09:
14:24 Changeset [442] by Seed
         libmpc/trunk/mpcgain/mpcgain.c
14:23 Changeset [441] by Seed
         libmpc/trunk/win32/mpcgain.vcproj
   a fix to allow wildcards
03/30/09:
01:01 Changeset [440] by r2d
   mpcgain bug correction : open files in binary mode (changed version …
03/17/09:
16:59 Changeset [439] by grimmel
         libmpc/trunk/libmpcdec/mpc_demux.c
   More fixes from DEATH
03/08/09:
13:56 Changeset [438] by radscorpion
         dsfilters/dec_mpc/bin/mmmpcdec.ax
   Fixes for SV7 seeking. Rebuilt with latest libraries
12:59 Changeset [437] by radscorpion
         libmpc/trunk/win32/libcommon_2005.vcproj
   Added VS2005 projects for libcommon / libmpcdec with MFC Static (needed …
03/07/09:
12:42 Changeset [436] by r2d
         libmpc/trunk/libmpcdec/internal.h
   mpccut should now be more resilient to errors
02/26/09:
20:41 Changeset [435] by r2d
   - Added a special case to ignore --xlevel and --noxlevel options - Changed …
02/24/09:
20:10 Changeset [434] by r2d
         libmpc/trunk/libmpcdec/ChangeLog
   spelling fix
05:15 SV8Specification edited by shy
   (diff)
05:05 SV8Build edited by shy
   grammar (diff)
04:50 WikiStart edited by shy
   (diff)
04:48 WikiStart edited by shy
   (diff)
02/23/09:
21:14 Changeset [433] by r2d
   - change libmpcdec API version (libtool) - update ChangeLog and README
20:45 Changeset [432] by r2d
   mpcdec update copyright and version to 1.0.0 for sv8 release
20:44 Changeset [431] by r2d
         libmpc/trunk/include/mpc/mpc_types.h
   update copyright (2nd part)
20:42 Changeset [430] by r2d
         libmpc/trunk/mpc2sv8/mpc2sv8.c
   change mpc2sv8 version to 1.0.0 for sv8 release
20:40 Changeset [429] by r2d
         libmpc/trunk/mpcchap/mpcchap.c
   add version information to mpcchap
20:36 Changeset [428] by r2d
   mpcgain supports chapters : change version
20:15 Changeset [427] by r2d
         libmpc/trunk/libmpcenc/analy_filter.c
   update copyright
02/18/09:
23:09 Changeset [426] by r2d
         libmpc/trunk/libmpcdec/streaminfo.c
   copied too fast  correction for max_band upper bound (thanks DEATH for …
02/16/09:
22:33 Changeset [425] by r2d
   check streaminfo values
02/12/09:
22:54 Changeset [424] by r2d
         libmpc/trunk/libmpcdec/mpc_bits_reader.c
   check block size & changed inline for mpc_inline, MSVC seems to accept …
02/11/09:
23:41 Changeset [423] by r2d
   improves chapter parsing resilience to errors
17:23 Changeset [422] by grimmel
         libmpc/trunk/win32/libcommon.vcproj
01/18/09:
18:17 Changeset [421] by radscorpion
         dsfilters/demux_mpc/bin/mmmpcdmx.ax
   Demuxer updated to 0.4.0.0 Support for APE 2.0 tags Chapters are now …
13:07 Changeset [420] by radscorpion
   DirectShow Musepack Decoder updated to 0.9.2.0 Bug fixed with -6 dB …
01/16/09:
19:47 SV8Specification edited by r2d
   (diff)
00:49 SV8Specification edited by shy
   minor mistypes fixed (diff)
12/10/08:
23:42 SV8Build created by r2d
22:46 WikiStart edited by r2d
   (diff)
11/12/08:
20:15 Changeset [419] by r2d
         libmpc/trunk/include/mpc/mpcdec.h
   - changed version string to 1.28.0 - added const to mpc_demux_chap return …
20:06 SV8Specification edited by r2d
   (diff)
11/02/08:
14:05 Changeset [418] by r2d
         libmpc/trunk/mpcchap/CMakeLists.txt
   libmpc cmake uses libcuefile from svn
14:03 Changeset [417] by r2d
         libcuefile/trunk/src/cuefile.c
   libcuefile builds with msvc
13:37 Changeset [416] by r2d
         libcuefile/trunk/CMakeLists.txt
   moved files, added cmake build system
13:01 Changeset [415] by r2d
         libcuefile
   libcuefile initial import from cuetools 1.3.1
01:21 Changeset [414] by r2d
         libmpc/trunk/common/tags.c
   changes to make mpcchap build with msvc
11/01/08:
22:09 Changeset [413] by r2d
         libmpc/trunk/libmpcdec/mpc_bits_reader.h
   updated mpcgain to fill the chapters' gain / peak
22:01 Changeset [412] by r2d
         libreplaygain/include/replaygain/gain_analysis.h
   libreplaygain can now handle chapters
10/31/08:
00:20 Changeset [411] by r2d
   added chapter gain / peak to libmpcdec and mpcchap as in the spec
10/06/08:
20:30 Changeset [410] by r2d
         libmpc/trunk/configure.in
   fix cross-compilation with mingw (patch by Leandro Nini)
20:26 Changeset [409] by r2d
         libmpc/trunk/libmpcdec/Makefile.am
   installable headers cleanup (patch by Leandro Nini)
09/18/08:
22:39 SV8Specification edited by r2d
   chapter replay gain proposition (diff)
08/12/08:
23:46 Changeset [408] by r2d
         libmpc/trunk/mpcchap/Makefile.am
   removed my local file path (patch by xmixahlx)
06/02/08:
16:23 Changeset [407] by r2d
   added a bound to the seek table size, varying the step between seek points …
05/01/08:
22:46 Changeset [406] by r2d
   mpcchap overflow correction
19:04 Changeset [405] by r2d
   changed declaration to conform to C89
04/25/08:
17:05 Changeset [404] by r2d
   updated mpcgain according to libreplaygain new functions name
17:03 Changeset [403] by r2d
   - reduced libreplaygain symbol exports - prefixed API function names with …
04/24/08:
13:06 Changeset [402] by r2d
   moved mpc_bits_reader definition in mpcdec.h for use in the API
04/21/08:
16:34 Changeset [401] by r2d
   correction for non GCC compilers
16:22 Changeset [400] by r2d
   Limited libmpcdec exported symbols (only for autotools building because …
04/13/08:
23:15 Changeset [399] by radscorpion
         dsfilters/temp/libmpcenc/include/libmpcenc.h
   further encoder library updates. added demo app for the new libmpcenc.
19:00 Changeset [398] by radscorpion
   interface extended for the encoder. rewritten bitstream output system for …
15:06 Changeset [397] by radscorpion
   libmpcpsy should be complete added basic VC++ project
04/11/08:
14:11 Changeset [396] by radscorpion
         dsfilters/temp/libmpcenc/src/fft4g.c
   som more cleanups…
00:29 Changeset [395] by radscorpion
         dsfilters/temp
   Added temporary dir with new cleaner encoding library. Library interface …
04/06/08:
16:19 Changeset [394] by r2d
   mpcchap supports cue/toc files through cuetools library (CMakeLists.txt …
04/05/08:
23:41 Changeset [393] by r2d
         libmpc/trunk/mpcchap/iniparser.c
   added commentary to added iniparser functions
20:34 Changeset [392] by r2d
         xmms-musepack/branches/r2d/Makefile.in
   removed autoconf generated files from the repository
20:33 Changeset [391] by r2d
         xmms-musepack/branches/r2d/src/libmpc.cpp
   xmms-musepack cleanup
20:09 Changeset [390] by r2d
   libmpcdec API cleanup and documentation
04/02/08:
17:30 SV8Specification edited by r2d
   (diff)
17:22 Changeset [389] by r2d
   - libmpcdec can now find chapters in files without seek table
16:01 Changeset [388] by r2d
   - chapters are now able to contain no tag
04/01/08:
23:04 Changeset [387] by r2d
   - mpcchap can now dump chapters
03/29/08:
21:23 Changeset [386] by r2d
   fixed cmake file for mpcchap
20:56 Changeset [385] by r2d
   - added CMakeLists.txt for mpcchap (untested) - corrected mpcenc …
03/25/08:
16:31 Changeset [384] by r2d
   - added mpcchap utility to add (and later dump) chapters in a sv8 mpc file …
03/19/08:
19:16 Changeset [383] by r2d
         libmpc/trunk/libmpcdec/mpc_decoder.c
   removed EQ_TAP, DELAY and FIR_BANDS as suggested by Andree Bushmann
03/06/08:
16:39 Changeset [382] by r2d
         libmpc/trunk/libmpcdec/huffman.h
   made some const changes
01/13/08:
19:23 Changeset [381] by radscorpion
   Recompiled with MFC as Static
01/06/08:
01:03 SV8Specification edited by r2d
   removed chapter number (diff)
01/05/08:
20:49 Changeset [380] by radscorpion
   Fixed SV7 seeking artifacts. Fixed gain info.
11:40 Changeset [379] by radscorpion
         dsfilters/before-you-ask.txt
   SV7 demuxing and decoding works. However there are strange artifacts when …
01/04/08:
13:54 SV8Specification edited by r2d
   added status for the document (diff)
13:42 final.png attached to SV8Specification by r2d
13:41 beta.png attached to SV8Specification by r2d
13:40 alpha.png attached to SV8Specification by r2d
13:07 SV8Specification edited by r2d
   (diff)
11:57 SV8Specification edited by r2d
   added Chapter packet (diff)
10:45 SV8Specification edited by r2d
   added links to packets (diff)
01/03/08:
23:50 Changeset [378] by radscorpion
         dsfilters/demux_mpc/demux_mpc.suo
   Basic SV7 parsing. TODO: Construct seeking table. !!! WARNING !!! If you …
12/20/07:
23:28 Changeset [377] by r2d
   corrected a bug that prevented the scalefactors to be reset on seeking …
12/18/07:
23:55 Changeset [376] by r2d
   added LONG_SEEK_TABLE define for a 64 bits long offset in the seek table …
12/15/07:
21:20 Changeset [375] by radscorpion
   Redesigned property page. Fixed loop-seeking. Added version info for …
21:04 Changeset [374] by radscorpion
   Eye candy property page for the decoder filter.
19:09 Changeset [373] by radscorpion
   Fixed seeking.
17:04 Changeset [372] by radscorpion
   Seeking fixes. Splitter now registers mediatypes
14:49 Changeset [371] by radscorpion
   Decoder now can decode and play SV8 streams. It can be used along with old …
12/14/07:
21:29 Changeset [370] by radscorpion
   Okay. It can now connect. Sound should be done tomorrow.
19:48 Changeset [369] by radscorpion
   Basis for decoder filter. It cannot be created right now. I's just a …
00:22 Changeset [368] by radscorpion
   MPC Demux works. Right now it can only be used with Dump filter, because …
12/13/07:
19:24 Changeset [367] by radscorpion
         dsfilters/demux_mpc/src/bits.cpp
   added a few methods to parse seek table offset and seek table. Golomb …
12:40 SV8Specification edited by r2d
   removed definitely end silence (diff)
12/12/07:
20:09 Changeset [366] by radscorpion
   First build of splitter filter.
12/11/07:
22:21 Changeset [365] by radscorpion
         dsfilters
   Created basic directory structure for DirectShow filters.
12/01/07:
18:46 Changeset [364] by r2d
   stdin/stdout set to binary under windows
11/23/07:
17:39 Changeset [363] by r2d
   - corrections to compile with msvc c (c89?) - removed headers from other …
11/10/07:
12:45 Changeset [362] by r2d
         libmpc/trunk/mpc2sv8/CMakeLists.txt
   - added basename and dirent implementation for win32 - updated mpc2sv8 …
10/21/07:
14:29 Changeset [361] by r2d
   correction for mono files
14:27 Changeset [360] by r2d
10/02/07:
12:20 Changeset [359] by r2d
   changed mpc_quantizer size
11:42 Changeset [358] by r2d
   SV7 seeking bug correction when header not aligned on 4 bytes
10/01/07:
18:54 Changeset [357] by r2d
   - mpc2sv8 can overwrite output (option -o) - mpc2sv8 can output to a …
09/27/07:
12:54 Changeset [356] by r2d
   added pipe input and output for mpcdec
12:18 Changeset [355] by r2d
   - correction of the id3v2 tag seeking bug
11:44 Changeset [354] by r2d
         libmpc/tags/1.27.0-beta-1
   Tag for the first beta of sv8 tools
09/23/07:
22:09 Changeset [353] by r2d
   changed copyright info
20:48 Changeset [352] by r2d
   changed mpcenc version because of bug correction
20:41 Changeset [351] by zorg
         libmpc/trunk/libmpcpsy/psy_tab.c
   fix compilation under mingw
19:20 Changeset [350] by r2d
   replay gain changes again ... last change was not correct
19:12 Changeset [349] by r2d
   corrected error with optimized gcc builds and CVD_FASTLOG defined
18:38 Changeset [348] by r2d
         libmpc/trunk/mpcenc/mpcenc.c
   changed help according to 1.16 version
18:17 Changeset [347] by r2d
   changed replay gain rounding and reference
09/19/07:
21:33 Changeset [346] by zorg
   add missing vcproj for mpcgain fix build on win32 patch by DEATH
21:25 Changeset [345] by zorg
         libreplaygain/libreplaygain.vcproj
   add vcproj for msvc2005. patch by DEATH
09/17/07:
18:41 Changeset [344] by r2d
   added version info for mpcdec and mpcgain
09/09/07:
18:17 Changeset [343] by r2d
         libmpc/trunk/win32/libmpcenc.vcproj
   updated MSVC8 project files, patch by DEATH
08/20/07:
22:37 Changeset [342] by r2d
   made changes so msvc doesn't complain, changes doesn't affects gcc speed …
07/29/07:
19:20 Changeset [341] by r2d
   skip error detection if it's end of stream
07/22/07:
16:42 Changeset [340] by r2d
         libmpc/trunk/libmpcpsy/cvd.c
   corrections for windows build
06/30/07:
20:18 Changeset [339] by r2d
   added check stream option to mpcdec
13:45 Changeset [338] by r2d
   added explicit cast
06/27/07:
20:00 Changeset [337] by r2d
   make aligned swaping in buffer (alignement on buffer start, there is no …
06/09/07:
21:34 Changeset [336] by zorg
         libmpc/trunk/win32/mpcenc.vcproj
   missing defines
21:06 Changeset [335] by zorg
         libmpc/trunk/win32/libmpcpsy.vcproj
   Add fastmath
19:26 Changeset [334] by zorg
   Update cmake
17:43 Changeset [333] by r2d
         libmpc/trunk/common/fastmath.c
   put back FAST_MATH stuff, don't forget to define FAST_MATH and CVD_FASTLOG …
06/08/07:
17:20 Changeset [332] by zorg
         libmpc/trunk/mpccut/CMakeLists.txt
   Enforce C projects
01:19 Changeset [331] by zorg
   misc
00:28 Changeset [330] by zorg
         libmpc/trunk/win32/mpc2sv8.sln
   misc
00:11 Changeset [329] by zorg
   misc
06/07/07:
23:55 Changeset [328] by zorg
   Fix broken args check
23:54 Changeset [327] by zorg
   Add missing header
05/27/07:
18:04 SV8Specification edited by r2d
   (diff)
17:54 SV8Specification edited by r2d
   (diff)
16:36 Changeset [326] by r2d
   removed OSS input in help
05/25/07:
17:37 SV7FrameDecoding edited by r2d
   (diff)
17:36 SV7FrameDecoding edited by r2d
   (diff)
17:29 SV7FrameDecoding edited by r2d
   (diff)
17:25 SV7FrameDecoding created by r2d
16:55 SV7Specification edited by r2d
   (diff)
05/13/07:
15:47 Changeset [325] by r2d
   corrected end of file
05/12/07:
23:45 Changeset [324] by r2d
         winamp-musepack/trunk/in_mpc.cpp
   file is closed after function call
12:43 Changeset [323] by r2d
   - Corrected end of loop condition when encoded file doesn't report correct …
05/11/07:
14:08 Changeset [322] by r2d
   Added winamp extended info (replay gain and title formating)
11:46 Changeset [321] by r2d
         libmpc/trunk/mpccut/mpccut.c
   bug correction for mpccut (bad decoded sample number)
05/10/07:
16:34 Changeset [320] by r2d
   updated Windows/CMake build
16:02 Changeset [319] by r2d
         libmpc/trunk/win32/attgetopt.c
   added getopt function for win32
15:58 Changeset [318] by r2d
   Use getopt.h
13:01 Changeset [317] by r2d
   Added mpccut prog, sv8 files can now be cutted
00:25 Changeset [316] by r2d
   Added old gain view
00:01 Changeset [315] by r2d
   Added -i flag to print file information
05/09/07:
23:11 Changeset [314] by r2d
   Added support for beg_silence (no yet tested as can't make files that use …
23:07 Changeset [313] by r2d
   Added sample number in file info
18:24 Changeset [312] by r2d
         libmpc/trunk/libmpcenc/bitstream.c
   Bug correction, please re-test encoding through pipe
14:52 Changeset [311] by r2d
         libmpc/trunk/include/mpc/streaminfo.h
   Removed end_silence to comply with spec
05/07/07:
23:51 SV8Specification edited by r2d
   End silence is redundant with sample count (diff)
05/04/07:
14:10 Changeset [310] by r2d
   - corrected a M/S bug in sv8 decoding - changed Max_used_band usage in sv7 …
05/03/07:
14:42 Changeset [309] by r2d
   added error reporting to mpc2sv8
14:21 Changeset [308] by r2d
   updated mpcenc version
12:39 Changeset [307] by r2d
   writeBits can't output more than 31 bits !
00:05 Changeset [306] by r2d
   removed a check that may fail on a valid file
05/02/07:
23:20 Changeset [305] by r2d
   forgot to remove debug code
22:55 Changeset [304] by zorg
         libmpc/trunk/libmpcpsy/fft_routines.c
   Simplify code by using array notation. It should also make the task easier …
22:47 Changeset [303] by zorg
         libmpc/trunk/libmpcpsy/psy.c
   Factorize some operations out of the inner loop
22:31 Changeset [302] by r2d
   - added some checks in sv8 demuxing - corrected a bug in mpc2sv8
04/27/07:
22:37 Changeset [301] by r2d
   corrected a bug when seeking after the last frame as been decoded
22:35 Changeset [300] by r2d
   correction : needed even in floating point
12:50 Changeset [299] by r2d
   - moved some MPC_FIXED_POINT defines from mpcdec_math.h to mpc_types.h - …
04/26/07:
22:36 Changeset [298] by r2d
   changed encoder description for sv7 encoder in sv8 stream
21:11 Changeset [297] by r2d
   corrected gain information conversion bug
04/24/07:
15:07 Changeset [296] by r2d
         libmpc/trunk/libmpcdec/huffman.c
   Improved sv8 huffman decoding using canonical property of the huffman …
04/23/07:
21:30 Changeset [295] by r2d
         libmpc/trunk/libwavformat/input.c
   removed aliasing warnings
18:35 Changeset [294] by r2d
   finished branch move
18:23 Changeset [293] by r2d
         libmpc/trunk/r2d
   moving branche to trunk
16:59 Changeset [292] by r2d
   updated according to libmpcdec
16:58 Changeset [291] by r2d
         libmpc/branches/r2d/include/mpc/mpcdec.h
   changed function name to match other functions naming convention
16:47 Changeset [290] by r2d
         libmpc/branches/r2d/libmpcdec/huffman.c
   improved decoder speed using LUT for huffman decoding. profiling/bench …
00:44 Changeset [289] by zorg
         libmpcdec/trunk/configure.ac
   Replace memcmp configure check with a supposedly better one
04/22/07:
15:43 Changeset [288] by r2d
   made huffman tables smaller
04/21/07:
20:59 Ticket #14 (Improper decoding of specific SV7 files) closed by r2d
   fixed
15:31 Changeset [287] by zorg
         libmpc/branches/r2d/win32/libcommon.vcproj
   Misc msvc project fixes
15:29 Changeset [286] by zorg
   Fix headers once again
04/20/07:
23:17 Changeset [285] by r2d
         libmpc/branches/r2d/libmpcdec/mpc_demux.c
   pow works with msvc, not powf
22:53 Changeset [284] by r2d
         libmpc/branches/r2d/libmpcdec/mpc_decoder.c
   corrected seeking to beginning of the file bug (sv7 only)
21:59 Changeset [283] by r2d
         winamp-musepack/trunk/mpc_player.cpp
   I know, I know …
21:38 Changeset [282] by r2d
         libmpc/branches/r2d/Makefile.am
   added wavcmp utility
21:36 Changeset [281] by r2d
   corrected file length error
04/19/07:
23:39 Ticket #2 (Mpcdec) closed by zorg
   wontfix: Leave full-featured decoder to external apps and only provide sample …
23:27 Ticket #14 (Improper decoding of specific SV7 files) created by DEATH
   Libmpcdec decodes this file properly while lower frequencies (?) are …
23:23 Changeset [280] by zorg
   Fix broken headers
19:56 Changeset [279] by r2d
         libmpc/branches/r2d/mpcdec/mpcdec.c
   can now use mpcdec to check if a file is corrupted
19:55 Changeset [278] by r2d
   was always returning error after last frame
04/17/07:
22:12 Changeset [277] by zorg
         libmpcdec/tags/release-1.2.6
   1.2.6 tag
22:05 Changeset [276] by zorg
         libmpcdec/trunk/ChangeLog
   Prepare 1.2.6 release
21:48 Changeset [275] by zorg
         libmpcdec/trunk/src/mpc_decoder.c
   Revert r160 as it breaks some files due to some encoder bug
21:28 Changeset [274] by zorg
         libmpcdec/trunk/src/Makefile.am
   Make sample app use static libraries Fix infinite loop bug on large files
14:10 Changeset [273] by r2d
   - added return codes for mpc_demux_decode - refill buffer only if bit …
14:06 Changeset [272] by r2d
         libmpc/branches/r2d/mpcenc/config.h
   - added unicode (UTF-8) autodetection for unix - changed --longhelp about …
04/16/07:
21:55 Changeset [271] by r2d
   oups
21:53 Changeset [270] by r2d
   initialized all the decoding buffer to 0
20:12 Changeset [269] by r2d
   Improved decoding robustness
19:37 Changeset [268] by r2d
00:04 Changeset [267] by r2d
   be sure allocated size is at least used size !
04/15/07:
23:40 Changeset [266] by r2d
         libmpc/branches/r2d/libmpcdec/internal.h
   Improved decoder robustness against corrupted files
23:39 Changeset [265] by r2d
         libmpc/branches/r2d/libmpcdec/streaminfo.c
   sign issue in replay gain reading in sv7
23:37 Changeset [264] by r2d
         libmpc/branches/r2d/include/mpc/reader.h
   added a way to open a reader with an already open file (patch by DEATH)
04/12/07:
22:57 Changeset [263] by zorg
         libreplaygain/autogen.sh
   Useless file, use Makefile.cvs instead
22:53 Changeset [262] by zorg
   Fix cmake for mpcgain Remove builtin math functions
22:42 Changeset [261] by zorg
   Add autogen.sh to make autotools useable Full cmake update
21:44 Changeset [260] by r2d
         libmpc/branches/r2d/include/Makefile.am
   added missing Makefile.am
04/07/07:
10:43 Ticket #4 (Port winamp plugin to libmpcdec) closed by r2d
   fixed
10:42 Ticket #8 (make a lib from the replay gain app) closed by r2d
   fixed
03/30/07:
19:03 Changeset [259] by r2d
   init scalefactors to 0 because of an encoder bug
13:53 Changeset [258] by r2d
   - corrected a bug crashing winamp when trying to see informations on a …
03/29/07:
23:48 Changeset [257] by r2d
         winamp-musepack/trunk/winamp-musepack.rc
   Comment control supports multi line
18:29 Changeset [256] by r2d
   divide by 0 bug removed
17:20 Changeset [255] by r2d
         winamp-musepack/trunk/mpc_logo.bmp
   added logo
15:42 Changeset [254] by r2d
   - tag writing OK - better tag reading - maybe less pb with x64
13:16 Changeset [253] by r2d
   - tags in accentuated files can now be read - tags are converted from …
03/28/07:
21:19 Changeset [252] by r2d
         libmpc/branches/r2d/mpcgain/mpcgain.c
   mpcgain doesn't crash anymore on read only files
20:56 Changeset [251] by r2d
   More details on files (gain info)
19:19 Changeset [250] by r2d
   - can now read file tags and display - doesn't work with accentuated file …
17:04 Changeset [249] by r2d
   added native windows GUI (work in progress)
16:59 Changeset [248] by r2d
         winamp-musepack/trunk/in2.h
   moved project files
16:56 Changeset [247] by r2d
         winamp-musepack/trunk/winamp-musepack/mpc_info.cpp
   removed .net files
12:39 Changeset [246] by r2d
         libmpc/branches/r2d/mpc2sv8/mpc2sv8.c
   Corrected a mpc2sv8 bug
03/27/07:
12:34 Changeset [245] by r2d
   Corrected a sv7 length decoding bug
11:47 Changeset [244] by r2d
   update version because of bug correction
11:23 Changeset [243] by r2d
   corrected pns encoding/decoding bug (doesn't change bitstream for quality …
03/26/07:
13:27 Changeset [242] by r2d
   added include for windows
13:25 Changeset [241] by r2d
         libmpc/branches/r2d/mpcenc/mpcenc.c
   added windows includes
13:23 Changeset [240] by r2d
         libmpc/branches/r2d/CMakeLists.txt
   CMakeLists.txt update to build replaygain using libreplaygain
13:21 Changeset [239] by r2d
         libreplaygain/CMakeLists.txt
03/25/07:
22:23 Changeset [238] by r2d
   Changed CMakeLists.txt files for Windows buid (doesn't work for mpcgain …
22:13 Changeset [237] by r2d
         libmpc/branches/r2d/libmpcdec/mpc_bits_reader.h
   corrected the high bitrate bug (decoder only bug)
22:06 Changeset [236] by r2d
   - reverted last change (CMakeLists.txt are back)
17:57 Changeset [235] by zorg
   Remove unmaintained cmake build files
03/22/07:
20:58 Changeset [234] by r2d
   - mpc2sv8 doesn't overwrite output file anymore
20:24 Changeset [233] by r2d
         libmpc/branches/r2d/libmpc.kdevelop
   - added build date to mpcenc - mpc2sv8 check for stream version
03/17/07:
01:25 Changeset [232] by r2d
   patch from xmixahlx : - moved replaygain outside - removed build system …
01:11 Changeset [231] by r2d
         libreplaygain/Makefile.am
   added files from xmixahlx
01:01 Changeset [230] by r2d
   moved files in the right dirs
00:53 Changeset [229] by r2d
   moving replaygain in it's own module
00:52 Changeset [228] by r2d
         libreplaygain
03/16/07:
16:56 Changeset [227] by r2d
   - if pns status is unknown, pns = 0xFF
16:54 Changeset [226] by r2d
   - added sv8 options to mpcenc - some change in mpcdec to correctly display …
03/13/07:
00:34 Changeset [225] by r2d
   applied the patch from xmixahlx : - libreplaygain is now a shared library …
03/12/07:
20:18 SV8Specification edited by r2d
   (diff)
20:14 Changeset [224] by r2d
   - corrected date
19:56 Changeset [223] by r2d
   - corrected encoder version info
03/10/07:
15:06 Changeset [222] by r2d
   - applyed same changes as changeset [99] (what was EnableTags used for ?)
02/17/07:
21:18 Changeset [221] by r2d
         libmpc/branches/r2d/libmpcenc/bitstream.c
   - speed optimizations
18:49 Changeset [220] by r2d
         libmpc/branches/r2d/include/mpc/streaminfo.h
   - updated according to the spec - now reads / write beginning / end …
16:14 Changeset [219] by r2d
         libmpc/branches/r2d/libmpcdec/Makefile.am
   - speed improvements (mainly inlining)
15:58 Changeset [218] by r2d
   - update for replay gain
14:22 SV8Specification edited by zorg
   Align stuff (diff)
02/15/07:
12:32 SV8Specification edited by r2d
   (diff)
01:41 SV8Specification edited by zorg
   Mostly Cosmetics, extract RG from SH (diff)
02/13/07:
22:50 Changeset [217] by zorg
         libmpc/branches/r2d/mpcdec/CMakeLists.txt
   remove winmm stuff..
22:49 Changeset [216] by zorg
   mpcdec now needs libm
13:31 Changeset [215] by r2d
   - updated API version
12:25 Changeset [214] by r2d
   - there is not yet sv > 8
12:13 Changeset [213] by r2d
   - mpcenc should now support encoding from pipe with unknow file length …
11:40 Changeset [212] by r2d
   - changed replay gain implementation (using sv8 representation)
02/11/07:
21:17 Changeset [211] by zorg
         libmpcdec/tags/release-1.2.5
   1.2.5 tag
21:11 Changeset [210] by zorg
   Bump version to 1.2.5
20:58 Changeset [209] by zorg
   Add 1.2.5 changelog
20:43 Changeset [208] by zorg
         xmms-musepack/branches/r2d/autogen.sh
   Missing executable state on some scripts
20:39 Changeset [207] by zorg
   Include mpc2sv8 to cmake build system
02/09/07:
18:57 Changeset [206] by r2d
   - corrected a bug where very short frames ( < 1 byte, generally silence) …
12:31 Changeset [205] by r2d
   - corrected a small bug - added copy of header and footer data (tags) of …
02/08/07:
21:36 Changeset [204] by r2d
         libmpc/branches/r2d/include/mpc/mpc_types.h
   - file length should be OK for all files - seems there is a bug at end of …
14:29 Changeset [203] by r2d
   - added sv7 to sv8 conversion utility (still work to do, but able to …
01/20/07:
21:43 Changeset [202] by r2d
   - added more precision to encoding quality information
21:43 Changeset [201] by r2d
20:23 Changeset [200] by r2d
   - removed xlevel stuff
12:13 SV8Specification edited by r2d
   (diff)
01/09/07:
22:56 Changeset [199] by zorg
   - Backwards binary compatibility was broken since 1.2.3
22:22 Changeset [198] by zorg
   - Fix missing internal.h in 'make dist' - Simplify types size detection in …
11:48 Changeset [197] by r2d
   changed mpc_decoder_decode_frame so it should be compatible with programs …
01/02/07:
20:37 SV7Specification edited by r2d
   (diff)
12/30/06:
17:49 Changeset [196] by r2d
   - moved skip_id3v2 to demuxer and changed so it doesn't need seek (not …
12/29/06:
15:21 Changeset [195] by r2d
   - moved libmpcdec includes in /mpc - removed mppdec.h and mpp.h - mpcenc …
12/28/06:
12:11 Changeset [194] by r2d
   win32 compilation corrections
12/27/06:
22:52 Changeset [193] by r2d
   - corrected tag reading bug for utf8 strings - tag writing works but need …
20:53 SV8Specification edited by r2d
   (diff)
00:55 SV8Specification edited by r2d
   (diff)
12/25/06:
23:45 Changeset [192] by r2d
         winamp-musepack/trunk/winamp-musepack/in_mpc.cpp
   added tag writing, but TagLib::FileRef::save() make all crash and I'm too …
03:15 Changeset [191] by r2d
   - Added UI - Display tag & stream info (can't edit)
12/24/06:
18:50 Changeset [190] by r2d
   added licensing terms
17:17 Changeset [189] by r2d
         winamp-musepack/trunk/winamp-musepack/mpc_player.cpp
   Added TagLib support (as a static lib). Used to display track title.
12/23/06:
17:07 Changeset [188] by r2d
   - removed file info bug - improved thread reactivity
13:52 Changeset [187] by r2d
         winamp-musepack/trunk/winamp-musepack.suo
   removed uneeded file
13:46 Changeset [186] by r2d
         winamp-musepack
   import winamp musepack plugin. supports play, seek, pause, stop and bugs …
13:38 Changeset [185] by r2d
         libmpc/branches/r2d/common/huffman.c
   dev tools only for gcc
12/21/06:
13:45 Changeset [184] by r2d
   moved declarations
13:37 Changeset [183] by r2d
   - added peak calculation - gain results are now written to sv8 files
12/20/06:
23:31 Changeset [182] by r2d
         libmpc/branches/r2d/libreplaygain/gain_analysis.c
   - scaled libmpcdec output so I now have meaningful results - removed gain …
21:53 SV8Specification edited by zorg
   (diff)
21:45 Changeset [181] by zorg
   Make mpcgain build with cmake
21:21 Changeset [180] by r2d
   added libreplaygain and mpcgain
20:42 Changeset [179] by r2d
         libmpc/branches/r2d/libmpcdec/mpc_bits_reader.c
   - bugfix
14:47 Changeset [178] by r2d
   - removed unused decoder
14:41 Changeset [177] by r2d
   - corrected decoded length (tested on sv8, not tested on sv7)
13:25 Changeset [176] by r2d
         libmpc/branches/r2d/libmpcenc/encode_sv7.c
   - corrected info length
01:00 Changeset [175] by zorg
         libmpc/branches/r2d/win32/mpcdec.sln
   Cosmetics
00:57 Changeset [174] by zorg
   Update win32 project files
00:54 Changeset [173] by zorg
         libmpc/branches/r2d/mpcenc/mpcenc.h
   Remove default cvd_fastlog
00:53 Changeset [172] by zorg
   Remove C99 construct
12/19/06:
23:02 Changeset [171] by zorg
   Fix endianess
22:27 Changeset [170] by zorg
         mppenc/trunk/CMakeLists.txt
   Fix endianness issues
22:02 Changeset [169] by zorg
         libmpc/branches/r2d/Makefile.cvs
   symlinks won't work on some systems
22:01 Changeset [168] by zorg
         libmpc/branches/r2d/configure.in
   put config.h in include directory
21:53 Changeset [167] by zorg
   put some autotools stuff into separate dir
21:48 Changeset [166] by zorg
   mppenc mutated into mpcenc, part 2
21:39 Changeset [165] by zorg
         libmpc/branches/r2d/mpcenc/CMakeLists.txt
   mppenc mutated into mpcenc, part 1
21:34 Changeset [164] by zorg
   mppenc mutated into mpcenc, prologue
12:08 Changeset [163] by r2d
         libmpc/branches/r2d/mpcdec/Makefile.am
   - removed warning / error in mpcdec compilation
02:08 Changeset [162] by zorg
   Fix mpcdec compilation for latest libmpcdec Fix and update cmake build …
12/18/06:
20:52 Changeset [161] by r2d
   - changed entropy coding (all huffman tables are canonical) - scalefactor …
12/12/06:
00:57 Changeset [160] by r2d
   - improved cutted stream decoding
12/10/06:
19:48 Changeset [159] by r2d
         libmpc/branches/r2d/libmpcenc/quant.c
   - variable name correction
19:42 Changeset [158] by r2d
   - improved cutted stream decoding - sv7 decoding cleanup
12/09/06:
23:00 Changeset [157] by r2d
         libmpc/branches/r2d/common/Makefile.am
   - added huffman codes generation utility
22:45 Changeset [156] by r2d
         libmpc/branches/r2d/include/mpc/mpcmath.h
   - removed slow builtin_ functions
12/07/06:
20:44 Changeset [155] by zorg
         libmpcdec/tags/release-1.2.4
   1.2.4 tag
20:41 Changeset [154] by zorg
   Prepare for 1.2.4 release
20:35 Changeset [153] by zorg
         libmpcdec/trunk/src/streaminfo.c
   Fix broken stream initialization on non-mpc files
11/25/06:
16:05 Changeset [152] by r2d
   - corrected a memory allocation bug
15:19 Changeset [151] by r2d
         libmpc/branches/r2d/include/mpcdec/mpcdec.h
   - updated libmpcdec win32 project files - removed some libmpcdec warnings …
11/24/06:
19:18 Changeset [150] by r2d
   - updated libmpcenc / libmpcdec according to the spec - added seek table …
19:09 SV8Specification edited by r2d
   (diff)
11/23/06:
19:17 Changeset [149] by r2d
   - merged SI and RG blocks - updated seek table according to the spec in …
18:18 SV8Specification edited by r2d
   (diff)
11/21/06:
11:53 SV8Specification edited by r2d
   (diff)
11:52 SV8Specification edited by r2d
   (diff)
00:31 Changeset [148] by r2d
   - corrected a sv8 seeking bug
11/20/06:
20:22 SV8Specification edited by r2d
   (diff)
19:53 Changeset [147] by r2d
   - added a first version of the seek table for sv8
11/18/06:
22:38 Ticket #13 (utf8 issue in mppenc) created by r2d
   Some of my files (encoded under linux) do not display accents correctly. …
22:20 Ticket #12 (tagging issue in xmms-msepack plugin) created by r2d
   when changing tags in xmms plugin, sometimes the new tag values are not …
18:46 Changeset [146] by r2d
   - added seek table
17:04 Changeset [145] by r2d
   - end of stream bug correction
11/17/06:
21:05 Changeset [144] by r2d
         xmms-musepack/branches/r2d/configure
   - put back seeking
21:04 Changeset [143] by r2d
   - added simple seeking for sv7 and sv8
21:00 Changeset [142] by r2d
   - removed warnings (and bugs)
11/16/06:
13:58 SV8Specification edited by r2d
   (diff)
12:35 Changeset [141] by r2d
         libmpcdec/branches/zorg
   removed libmpcdec branche
  • Last Edit: 20 August, 2009, 10:53:24 AM by Antonski
  • GeSomeone
For DAP/phone/car I would rather do that then rerip, I consider the remaining quality easily high enough for those purposes. For quality playback at home (without computer that is) I would convert to WAV and have the same quality as the Musepack.
Only for the existing Musepack files of course.
  • halb27
  • Developer
They do - they need to re-rip to lossless while they still can. If they wait until the next new DAP/car/phone/whatever they want to buy doesn't have MPC support, they might find they don't have the time / hardware / CDs left to re-rip then! ...
Well the time will probably come that they have to re-encode or re-rip. But whether to do it now or later or (with very low chance) never is a personal thing.
When using mpc only on a pc there will be a lot of time until re-encoding will be necessary.
When using mpc on a mobile DAP AFAIK it can be done only with Rockbox armed players. These players are so old that in case that somebody uses them today he won't have a problem to use them for some more years IMO.
Of course with an ever-growing music library it would be wise to switch rather earlier than later.
But even then this is a question of strategy. A useful argument may be 'Within two years memory of mobile DAPs will be so large that I can use lossless (or very high quality lossy like lossyWAV + lossless). I can wait another two years.'
So it's all up to users' preferences.
lame3995o -Q1.7
opus --bitrate 140
2Bdecided has a valid point here. CDs don’t live forever, even pressed ones don’t. Of course hard drives die as well. But you can easily make backups. You can even fully automate that process and have at least two full copies of your library on different physical drives at any given time.
That’s the real advantage of lossless and that’s the reason why I’m currently re-ripping my collection to FLAC. I used Musepack before so I’m probably the more paranoid type anyway.  But the point is that for a backup, i.e. for redundant storage of the original data an approximation of that data (and thus any lossy format) is just not good enough.
As for Muspack’s own problems. I agree with what has been said already.
  • Missing hardware support is probably the biggest factor.
  • With all the excitement around the development, listening tests etc. of the other codecs Musepack just fell by the wayside. Yes, it’s mature, it’s stable, it produces great transparent quality. But there hasn’t been anything new to talk about for a long time to get people’s attention. Even stream version 8 was more of a minor note.
  • Musepack users are likely to be the ones who are paranoid about quality. That’s also the user group with the strongest move towards lossless.
I feel Musepack is a little like the OggMedia container format. That was a great hack to have because it enabled Vorbis audio for movies. Then »real« modern container formats emerged – Matroska and MP4 – and made OGM obsolete.
Musepack isn’t a hack of course. But the situation was somewhat similar. It provided unproblematic transparency when MP3 couldn’t. But then MP3 improved, Vorbis and AAC came along. Musepack lost its advantage and the other formats won with their wider support throughout the industry.
Reply #30
1.5TB HDD = £86 = about 3 pence per CD lossless.
Ah yes...
mind you a new CD here in Sweden is about £17, so a 1.5TB HDD, with room for very roughly 3500 lossless albums makes the whole idea rather amusing.
hehe, that means you're paying around £59000 to fill it up
(another amusing number is if RIAA would find such a collection, I'd estimate their claim somewhere around £1.000.000.000.000.000.000.000.000.000.000)
  • 2Bdecided
  • Developer
Ouch! Really, still? CD prices have collapsed here in the UK. You can still find (quite) expensive shops, but they're going out of business. And supermarkets started doing legal downloads, pushing prices down further.
e.g. all chart CDs here for £7.99 or less:
http://www.cdwow.com/
...and everything else (basic things like bread, milk etc) have been going up stupidly these last two years, so music seams very cheap now.
(Though I'm sure there's still more free/pirated music around than paid for music - far more).
  • bawjaws
I do demand HQ playback on my DAP.  I'm just not delusional enough to believe I can hear the difference between FLAC and LAME v3 on my DAP, and would rather have the battery life and size advantages of MP3.
How does lossless like Flac measure up to MP3 or AAC in battery life?
I'd imagine if you've got a spinning disk in your DAP then that will give the large FLAC files a major disadvantage but many are flash memory based now. Obviously this makes it less likely that you can fit your entire collection without lossy transcoding, but what if you can? I believe Flac decode is less processor intensive in theory but does dedicated hardware support make the difference, or does bitrate alone have the biggest impact?
  • Last Edit: 20 August, 2009, 12:00:22 PM by bawjaws
  • vpa
Reply #33
AFAIK: Musepack is based on MP2, and therefore only uses one blocksize. As a pro this means you have no blockswitching issues (like with MP3, Vorbis, AAC), but as a con you have to use higher bitrates to reach transparency.
WavPack 4.50.1 -hhx6 | LAME 3.98.2 -V 0
  • halb27
  • Developer
Reply #34
How does lossless like Flac measure up to MP3 or AAC in battery life? ...
When I switched from mp3 (for the major part) and wavPack lossy to lossyWAV + FLAC on my HD based iRiver H140 battery life turned better in a very noticable way.
lame3995o -Q1.7
opus --bitrate 140
Reply #35
Yeah, me too. I will not sacrifice my mp3 quality for disk space.
I am more of the quality than disk quantity.
  • Last Edit: 20 August, 2009, 01:45:54 PM by greynol
  • nycjv321
Reply #36
Musepack is still as good as mp3 if not better and on par with modern codecs and vorbis and aac so why does no one talk about it? I was murking around the forum wiki and found out musepack was opensource which is a big plus for me... and older abx tests have it on par with aotuv or lame so why no talk? is it becuase of slow development? I think this is unfair if the codec is already so good no more tuning is needed..... any reason why people don't use mpc anymore other then compatibility? (converting from lossless to another format isn't too trivial... lol....)
For starters, LAME is almost as good as MPC, and Vorbis can be said to be even better.
So, if LAME is on par with MPC, but it has 50 times the hw support, why bother with MPC?
And if you want better quality than LAME, why don't go with Vorbis wich still has much better HW support than MPC.
Or even more, go with FLAC.
dude I don't care about hardware support first of all its not only about "hardware support"...... its also about compatibility, licensing, quality....
1. Foobar2000+lossless backups has fixed all my compatibility needs
2. Vorbis (the codec and its encoders (oggenc) are open source (just found out mpc was and which is why I asked what happened)
3. Vorbis achieves "apparent transparency" for most people at q4 128kbs (I encode to q6-8 though)
development doesn't really matter becuase if the codec is already matured then why bother asking "for more"? Its like people talking about neroaac lacking development somewhere else on this forum.... it works great so why ask for more? you can only go so far...... its a lossy codec. I am the one looking for the hardware that supports my music format of choice not the other way around... goes back to the point about a small group of people in closed door rooms choosing codecs for me NOT FOR ME.... granted this is difficult to do but foobar2000 to the rescue!!!
And it sounds like your actually comparing lame to aoTuV LOL.....  WOW
telling me to go to vorbis becuase of hardware support really kills your argument of choosing lame becuase it has more support then all the codecs so why not just use lame? wait thats becuase hardware isn't the only factor in choosing a format of choice....
  • nycjv321
Reply #37
umm why was the original title of this topic change?
  • 2Bdecided
  • Developer
Reply #38
That's rather limiting.
I mean, I could choose vinyl as my music format of choice, but it's not going to play very well in the car
cheers,
  • twostar
Reply #39
The only thing MPC has going for it is quality. The quality improvement over LAME to most people and for most samples is negligible. As for licensing, they're both free to use. That's what matters. As for compatibility and hardware support, there's no contest.
And good luck looking for hardware that supports MPC.
  • nycjv321
Reply #40
lol yea so we should just disregard what the license says right? as long as its free? LOL.....  let me say it again I don't use mpc... I use vorbis (aoutv) at q6-8 and usually recencode from either that or my lossless backups to aac or lame for my ipod (which I don't use anymore) or my winmo actually I have a vorbis compliment player on it so I could just use vorbis just fine...
  • Soap
Reply #41
*cough*
http://www.roadkillontheweb.com/images/s_hifi4.jpg
Creature of habit.
  • viktor
Reply #42
I like lossless , But shouldn't we be using it outside of our Pc  as well ? I would like to take the same quality library everywhere i can. If HA members don't demand HQ playback DAP (gapless, lossless, exotic lossy..) - who will ?
who said it's not demanded? it's just DAMN EXPENSIVE!  i have 100GB of music, and any player which can store them all is simply not an option for me due to the price. anyway, i'm not sure whether such FLAC/Vorbis-capable player exists at all. so i have to transcode to vorbis to maximize the number of tracks which i can store on my player.
  • viktor
Reply #43
the future (present) of music on pc is lossless. on portable it's transparent and widespread (well supported) lossy (mp3 or occasionally aac, ogg). in long term, the future is lossless on portable too...
I doubt the future is lossless because 1- lossless contain needless information 2- lower than lossless bitrates can give awfully good quality 3- songs sold online are mostly lossy and selling rythm is increasing fast (didn't some months ago digital albums sold surpassed traditional audio CD's selling?).
Besides, in the future desktops PC's will have market penetration as high as it has now? I think they will less and less important among all devices (existents and still to be developed).
1) needless? no, hell no. you can't hear *some* part of it, but it's not needless.
2) yes, but now there's no big cost for storing even better quality. you can eliminate artifacts with a 100% rate and you don't have to bother with transcoding issues if you ever want to process the files. if you want some good demostration, save the same jpeg picture 10 times, and compare the last picture to the first.
3) who cares what they do now? if they do, that doesn't mean they will keep doing so for 100 years. even nowadays i only buy lossless anyway. and the music industry is always badly lagging behind (and fighting against) technology.
and at the same time, you seem to totally ignore that
1) disk space gets cheaper
2) bandwidth gets cheaper
3) computing power gets cheaper (for processing)
oh and about my first post in this thread, people seem to forget that i said it's what most likely *will* happen, not what *should* happen. however, in the long term, i don't see problems with lossless everywhere. and your choice for lossy format on your DAP really won't matter if mainstream distribution ever gets lossless.
  • Last Edit: 21 August, 2009, 10:24:51 AM by viktor
  • AshenTech
Reply #44
actually you can find hardware support for MPC, its rare but it exists, and your wrong about quaility being the only advantage, On my buddys old ass iriver h320(with new larger hdd) using MPC gives better batt life then mp3 or flac, MPC is VERY FAST and low power to decode, hardware support can come with a simple firmware flash if people request it.
look at vorbis and flac support on sansa players like the clip and fuze, sansa saw the demand, and added support to the firmware, the same can be done with musepack and other formats.
last i checked musepack is 100% free and opensource now, Early on it had some copyrighted code in it, but that was fixed a very long time ago and as such is just as free as vorbis.
I use musepack for a long time, and IF sansa can be convenced to add musepack support I would switch back from vorbis, I love aotuv's work, but musepack would likely give me a batt life BOOST rather then loss over mp3(vorbis cuts batt life a bit compared to mp3)
  • viktor
Reply #45
it doesn't matter at all if there are 2 players on earth which support it. it only matters if it's widespread. 5% more battery life is really not a selling point either, especially not in the format war. you can produce massively superior formats, they won't give a shit if they get their music in mp3 and their player support mp3 only.
yeah, so you should understand that it wasn't there at the right time, so it doesn't matter if it's free now if they should have been free 5 or 10 years ago. monkey's audio is also free now, but it wasn't when it should, and now noone's interested in it.
yeah, you prefer battery life. but 99% of people won't re-encode their music and potentially buy new hardware for 20 mins longer playtime, that's for sure. it's somehwat easier to plug in for an hour for charging.
  • prankstare
Reply #46
Hum, I don't think so. That thought might work well for the most audiophiles but the majority probably don't even know what lossless means - and my guess is that they don't really worry about the quality at all, as long as it plays, sounds and recognize the music in their brains.
I could say I enjoy listening to high-quality music, for sure, but do I always look for lossless? Not really. In fact, I consider a 3 or 4 minute-song comprising about 30MB each rather an exaggeration, given the fact that you could get even more of that time with video information, which is much richer than just audio stream. All this regardless of how cheap hdd's may and might be today and in the future.
  • Last Edit: 13 October, 2009, 02:03:33 PM by prankstare
  • viktor
Reply #47
releasing lossy is an additional step, since producers always have lossless copy too. decrease of costs of disk space and bandwidth helps eliminating this unnecessary and (in terms of quality) harmful step.
the spread of lossless has already begun, and it can get only wider.
  • Last Edit: 13 October, 2009, 02:39:47 PM by viktor
Reply #48
Musepack didn't interest me until yesterday. After hearing a MPC-song I instantly fell in love with the format. The quality of a q5-file is absolutely great! My Rockboxed Sansa Clip+ is now playing MPC-files all day long :-) ...
Ain't there something we can do to give Musepack the world wide attention it deserves?
  • Last Edit: 19 May, 2010, 07:25:21 AM by String Theory
The future is lossless!
  • db1989
  • Global Moderator
Reply #49
Sounds like the placebo effect to me.
