Topic: Album List exclude genre (Read 2100 times) previous topic - next topic
  • sonvolt
Hi very new here , tho decided on using Foobar a while back and just recently ripped my CD's and now customizing ..
Use Columns UI , want to seperate album list views Classical/Other
Using following view script to show list only containing classical works fine
$if($not($strcmp(%genre%,Classical)),,%album artist% %album%)
What do I need for showing everything except genre classical my efforts to date still show the genre
$if($not($strcmp([%genre%,Classical))],,$swapprefix(%album artist%))- ['['%date%']' ]%album%|[[%discnumber%.]%tracknumber%. ][%track artist% - ]%title%
Would appreciate any pointers "while i find my feet"
  • nc30
You can make an autoplaylist. Library > Search > and make a query like: NOT %genre% IS Classical. Then click on the ... and Create Autoplaylist. This will create a playlist with all the genres except classical.
  • sonvolt
Cheers but I Want it family friendly so wanting it via album list panel on Columns UI
  • sonvolt
After lots of failed attempts this seems to do the trick.. It's the syntax I have a bit of a problem withOh well practice needed I suppose.
$if($strstr(%genre%,Classical),,$swapprefix(%album artist%) - ['['%date%']' ]%album%|[[%discnumber%.]%tracknumber%. ][%track artist% - ]%title%)
  • shakey_snake
  • Moderator
You could also just do something like this.
$if($stricmp(%genre%,Classical),zzClassical|)$swapprefix(%album artist%) - ['['%date%']' ]%album%|[[%discnumber%.]%tracknumber%. ][%track artist% - ]%title%
Then classical will just be placed in it's own category at the bottom.
note: while $strsrt() might work in your above title formatting, $strcmp() (string compare) or $stricmp() (string case-insensitive compare) is more appropriate.
  • Last Edit: 15 August, 2009, 02:50:56 PM by shakey_snake
elevatorladylevitateme
  • sonvolt
Cheers I like that...
