I tried to play my recommended last.fm station with Xchange but got an error in the seekbar (something like "File not exists" in Line 728, col 2).
since last.fm radios are no more free for french users, i can't test it.
could you try this fcl, and tell me if it fix the problem with last.fm radios please ?
or just replace the seekbar jscript with this one:
var bt_dir = fb.FoobarPath+"\\skins\\xchange\\bt\\";
var bg_dir = fb.FoobarPath+"\\skins\\xchange\\bg\\";
var moodbar_dir = fb.FoobarPath+"\\moodbar\\";
var track_path = fb.TitleFormat("$replace(%path%,%filename_ext%,)");
var track_fullpath = fb.TitleFormat("%path%");
var track_filename = fb.TitleFormat("%filename%");
var track_filename_ext = fb.TitleFormat("%filename_ext%");
var track_ext = fb.TitleFormat("$ext(%filename_ext%)");
var char_quote = fb.TitleFormat("$char(34)");
var is_archive = fb.TitleFormat("$add($strstr(%path%,'.zip|'),$strstr(%path%,'.rar|'))");
var s_track_path;
var s_track_fullpath;
var s_track_filename;
var s_track_filename_ext;
var archive;
var moodbar_fullpath;
var s_moodbar_fullpath;
var moodbar_filename;
var s_moodbar_filename;
var trk_filename;
var trk_fullpath;
var trk_ext;
var s_trk_fullpath;
var definitive_moodbar_fullpath;
var bool_movefile=1;
//Text formatting function
function StringFormat() {
var h_align = 0, v_align = 0, trimming = 0, flags = 0;
switch (arguments.length)
// fall-thru
case 4:
flags = arguments[3];
case 3:
trimming = arguments[2];
case 2:
v_align = arguments[1];
case 1:
h_align = arguments[0];
break;
default:
return 0;
return ((h_align << 28) | (v_align << 24) | (trimming << 20) | flags);
//Time formatting 00:00:00
function Format_hms(t){
var hms;
switch (t.length)
case 4:
hms="00:0"+t;
break;
case 5:
hms="00:"+t;
break;
case 7:
hms="0"+t;
break;
default:
hms=t;
break;
return hms;
//Time formatting secondes -> 0:00
function TimeFmt(t){
var zpad = function(n){
var str = n.toString();
return (str.length<2) ? "0"+str : str;
var h = Math.floor(t/3600); t-=h*3600;
var m = Math.floor(t/60); t-=m*60;
var s = Math.floor(t);
if(h>0) return h.toString()+":"+zpad(m)+":"+zpad(s);
return m.toString()+":"+zpad(s);
StringAlignment = {Near: 0,Centre: 1,Far: 2};
var font = gdi.Font("tahoma", 9, 0);
var l_stringformat = StringFormat(StringAlignment.Near, StringAlignment.Centre);
var c_stringformat = StringFormat(StringAlignment.Centre, StringAlignment.Centre);
var r_stringformat = StringFormat(StringAlignment.Far, StringAlignment.Centre);
//=====================================================================================// OBJECT button
button = function () {
this._attrb = {};
this.create = function (path_normal, path_hover, path_down) {
this._attrb.normal = gdi.Image(path_normal);
this._attrb.hover = gdi.Image(path_hover);
this._attrb.down= gdi.Image(path_down);
if (typeof this._attrb.x == "undefined") this._attrb.x= 0;
if (typeof this._attrb.y == "undefined") this._attrb.y= 0;
this._attrb.w = this._attrb.normal.Width;
this._attrb.h= this._attrb.normal.Height;
if (typeof this._attrb.state == "undefined") this._attrb.state=0;
this.draw = function (gr, bx, by, alpha) {
var image;
this._attrb.x = bx;
this._attrb.y = by;
switch(this._attrb.state)
case 0:
image = this._attrb.normal;
break;
case 1:
image = this._attrb.hover;
break;
case 2:
image = this._attrb.down;
break;
gr.DrawImage(image, bx, by, this._attrb.w, this._attrb.h, 0, 0, this._attrb.w, this._attrb.h, 0, alpha);
this.checkstate = function (action, x, y) {
switch(action)
case "down":
if (x>this._attrb.x && x<this._attrb.x+this._attrb.w && y>this._attrb.y && y<this._attrb.y+this._attrb.h)
this._attrb.state=2;
window.Repaint();
} else if (this._attrb.state==2){
window.Repaint();
break;
case "move":
this._attrb.state=1;
window.Repaint();
} else if (this._attrb.state==1){
window.Repaint();
break;
case "up":
} else {
break;
return this._attrb.state;
var mood_bt = new button;
var ButtonStates = {normal: 0,hover: 1,down: 2};
//=====================================================================================// Image Cache
image_cache = function () {
this._cachelist = {};
this.hit = function (path) {
var v = this._cachelist[path];
if (typeof v == "undefined") {
v = gdi.Image(path);
this._cachelist[path] = v;
return v;
var g_image_cache = new image_cache;
var g_drag = 0;
var g_drag_seek = 0;
var g_drag_hov = 0;
var mA_hov = 0;
var mB_hov = 0;
// images
var hov_bg = gdi.Image(bg_dir+"hov_bg.png");
var seeker0 = gdi.Image(bt_dir+"scrollpos04.png");
var seeker1 = gdi.Image(bt_dir+"scrollpos03.png");
var seeker2 = gdi.Image(bt_dir+"scrollpos05.png");
var mark_A_on = gdi.Image(bt_dir+"mark_a.png");
var mark_B_on = gdi.Image(bt_dir+"mark_b.png");
var mark_A_off = gdi.Image(bt_dir+"mark_a0.png");
var mark_B_off = gdi.Image(bt_dir+"mark_b0.png");
var moodbar_img;
var ww = window.Width;
var wh = window.Height;
//Titleformatting
var len = fb.Titleformat("%length%");
var elap = fb.TitleFormat("%playback_time%");
var remain = fb.TitleFormat("%playback_time_remaining%");
var len_seconds = fb.Titleformat("%length_seconds%");
var pos = 0;
var seekpad = 0;
//var seekerwidth = 9/2;
var seekerwidth = 4;
var seekstart_bg = 65;
var seekend_bg = 60;
var seekstart = 62;
var seekend = 57;
var g_timer;
var g_metadb;
var lbtn_click=false;
var refresh_timer=50;
var hov_x;
var pad_y=15;
var mA_drag = 0;
var mA_drag_seek = 0;
var mA_drag_hov = 0;
var mB_drag = 0;
var mB_drag_seek = 1;
var mB_drag_hov = 0;
var marks_xmin;
var marks_xmax;
var mark_A_x=seekstart-10+seekerwidth;
var mark_B_x=window.Width-seekend+1-seekerwidth;
var size_changed=false;
var moodbar_bool=0;
var moodbar_enabled=0;
var moodbar_show=0;
var moodbar_radio=0;
var WshShell = new ActiveXObject("WScript.Shell");
var timer_t1=0;
// ================================================================================/ on_paint
function on_paint(gr)
var bg_x=0;
var bg_y=pad_y-1;
gr.SetTextRenderingHint(5);
// background
//gr.FillGradRect(0, 0, ww, wh, 90, 0xFF202040, 0x00F0F0F0);
// seebar bg
gr.SetSmoothingMode(2);
gr.DrawRoundRect(bg_x, bg_y+1, ww-(bg_x*2)-1, 10, 4, 5, 1, 0x99202020);
gr.DrawRoundRect(bg_x, bg_y, ww-(bg_x*2)-1, 10, 3, 3, 1, 0xFFFFFFFF);
gr.DrawRoundRect(bg_x, bg_y+1, ww-(bg_x*2)-1, 9, 3, 3, 1, 0xCB505050);
gr.FillRoundRect(bg_x, (bg_y), ww-(bg_x*2)-01, 10, 4, 4, 0x80F0F0F0);
gr.FillGradRect(bg_x+1, (bg_y), ww-(bg_x*2)-02, 10, 90, 0xAFF0F0F0, 0x00F0F0F0);
gr.FillRoundRect(bg_x, (bg_y), ww-(bg_x*2)-01, 5, 2, 2, 0x88FFFFFF);
if(ww-(bg_x*2)-seekstart-seekend>10) {
gr.DrawRoundRect(bg_x+seekstart, bg_y+1, ww-(bg_x*2)-seekstart-seekend, 8, 4, 4, 1, 0xFF202020);
gr.FillRoundRect(bg_x+seekstart, (bg_y+1), ww-(bg_x*2)-seekstart-seekend, 8, 4, 4, 0xD3101015);
gr.SetSmoothingMode(1);
// draw moodbar if file exists (.png)
if (moodbar_bool==1 && fb.IsPlaying && moodbar_show==1) {
gr.DrawImage(g_image_cache.hit(moodbar_fullpath), seekstart_bg, pad_y+1, ww-seekstart_bg-seekend_bg, 7, 0, 0, 1024, 2, 0, 150);
if(fb.PlaybackLength>0)
gr.DrawString(Format_hms(elap.Eval()), font, 0xff666666, 16, pad_y-5, seekstart+seekpad, 18, l_stringformat);
gr.DrawString(Format_hms(elap.Eval()), font, 0xff000000, 16, pad_y-5, seekstart+seekpad, 18, l_stringformat);
gr.DrawString(Format_hms(len.Eval()), font, 0xff666666, ww-seekend-12, pad_y-5, seekend+seekpad, 18, r_stringformat);
gr.DrawString(Format_hms(len.Eval()), font, 0xff000000, ww-seekend-12, pad_y-5, seekend+seekpad, 18, r_stringformat);
} else if (fb.IsPlaying && fb.PlaybackLength) {
gr.DrawString("~STREAM", font, 0xff2040EE, ww-seekend-12, pad_y-5, seekend+seekpad, 18, r_stringformat);
} else {
gr.DrawString("00:00:00", font, 0xff999999, 16, pad_y-5, seekstart+seekpad, 18, l_stringformat);
gr.DrawString("00:00:00", font, 0xff555555, 16, pad_y-5, seekstart+seekpad, 18, l_stringformat);
gr.DrawString("00:00:00", font, 0xff999999, ww-seekend-12, pad_y-5, seekend+seekpad, 18, r_stringformat);
gr.DrawString("00:00:00", font, 0xff555555, ww-seekend-12, pad_y-5, seekend+seekpad, 18, r_stringformat);
gr.DrawImage(mA_drag_seek==0?mark_A_off:mark_A_on, mark_A_x, pad_y-7, 10, 20, 0, 0, 10, 20, 0, mA_drag_seek==0?(mA_hov?180:080):(mA_drag?250:175));
gr.DrawImage(mB_drag_seek==1?mark_B_off:mark_B_on, mark_B_x, pad_y-7, 10, 20, 0, 0, 10, 20, 0, mB_drag_seek==1?(mB_hov?180:080):(mB_drag?250:175));
if(mA_drag_seek!=0 || mB_drag_seek!=1) {
gr.FillGradRect(mark_A_x+10, (bg_y+2), mark_B_x-mark_A_x-10, 7, 00, 0x7730FF30, 0x77FF3030);
if(g_drag)
pos = seekstart+seekpad+seekerwidth+(ww-(seekstart+seekend+2*(seekpad+seekerwidth))) * g_drag_seek;
else
pos = seekstart+seekpad+seekerwidth+(ww-(seekstart+seekend+2*(seekpad+seekerwidth))) * (fb.PlaybackTime / fb.PlaybackLength);
// stop at the end if track time is corrupted (
pos = pos>marks_xmax-1?marks_xmax-1:pos;
gr.DrawImage(g_drag?seeker0:fb.IsPaused?seeker2:seeker1, pos-seekerwidth-0.5, pad_y-1, 15, 15, 0, 0, 15, 15, 0, 255);
if (g_drag_hov) {
gr.DrawImage(hov_bg, hov_x-29, 0, 60, 32, 0, 0, 60, 32, 0, (lbtn_click==true)?255:255);
gr.DrawString(Format_hms(TimeFmt(fb.PlaybackLength*g_drag_seek)), font, (lbtn_click==true)?0xFFFFFFFF:0xC2FFFFFF, hov_x-22, pad_y-17, 46, 18, c_stringformat);
//For streams
else if(fb.IsPlaying && fb.PlaybackLength)
//seekstart = 0;
//seekend = 0;
//gr.DrawString(elap.Eval()+" / continuous", font, 0xff000000, 0, 0, window.Width, 18, c_stringformat);
} else {
gr.DrawImage(seeker0, seekstart, pad_y-1, 15, 15, 0, 0, 15, 15, 0, 255);
if (archive==0 && moodbar_enabled && fb.PlaybackLength>0 && (trk_ext=="flac" || trk_ext=="fla" || trk_ext=="mp3" || trk_ext=="wav")) {
mood_bt.draw(gr,3,15,255);
} else {
mood_bt.draw(gr,3,15,110);
// ================================================================================/ on_size
function on_size()
var trk_fn;
var pref_fn;
refresh_timer = (fb.PlaybackLength>0)?(Math.floor(len_seconds.Eval()/60)*25):50;
if (refresh_timer<16) refresh_timer=16;
if(ww!=window.Width) {
size_changed=true;
ww = window.Width;
wh = window.Height;
marks_xmin=seekstart-1+seekerwidth;
marks_xmax=ww-seekend+1-seekerwidth;
// disable moodbar if moodbar.exe not found
if(file_exists(moodbar_dir+"moodbar.exe")) {
moodbar_enabled = true;
} else {
moodbar_enabled = false;
// disable moodbar if last.fm radio station!
trk_fn = track_filename.Eval();
pref_fn = trk_fn.substring(0,10);
if(pref_fn=="FOO_LASTFM")
moodbar_radio=1;
} else {
moodbar_radio=0;
mood_bt.create(bt_dir+"bt_moodbar0.png",bt_dir+"bt_moodbar1.png",bt_dir+"bt_moodbar1.png");
moodbar_bool = 0;
if(fb.IsPlaying && fb.PlaybackLength>0 && moodbar_radio!=1) {
// refresh file info (music path, filenames, moodbar)
get_file_info();
if(file_exists(moodbar_fullpath)) {
moodbar_bool = 1;
} else {
moodbar_bool = 0;
moodbar_show=0;
// ==============================================================/ mouse left click
function on_mouse_lbtn_down(x,y)
lbtn_click=true;
// Seeker
if(x>seekstart+seekpad && x<ww-(seekend+seekpad) && y>pad_y)
if(fb.PlaybackLength){g_drag = 1;}
g_drag_seek = (x>seekstart+seekpad+seekerwidth)?(x-(seekstart+seekpad+seekerwidth))/(ww-(seekstart+seekend+2*(seekpad+seekerwidth)))x<(ww-(seekend+seekpad+seekerwidth)))?(x-(seekstart+seekpad+seekerwidth))/(ww-(seekstart+seekend+2*(seekpad+seekerwidth))):1;
g_drag_seek = (g_drag_seek<0) ? 0 : (g_drag_seek<1) ? g_drag_seek : 1;
// mark A
if(x>=mark_A_x && x<=mark_A_x+10 && y<12)
mA_drag = 1;
mA_drag_seek = (x>seekstart+seekpad+seekerwidth)?(x-(seekstart+seekpad+seekerwidth))/(ww-(seekstart+seekend+2*(seekpad+seekerwidth)))x<(ww-(seekend+seekpad+seekerwidth)))?(x-(seekstart+seekpad+seekerwidth))/(ww-(seekstart+seekend+2*(seekpad+seekerwidth))):1;
mA_drag_seek = (mA_drag_seek<0) ? 0 : (mA_drag_seek<1) ? mA_drag_seek : 1;
// mark B
if(x>=mark_B_x && x<=mark_B_x+10 && y<12)
mB_drag = 1;
mB_drag_seek = (x>seekstart+seekpad+seekerwidth)?(x-(seekstart+seekpad+seekerwidth))/(ww-(seekstart+seekend+2*(seekpad+seekerwidth)))x<(ww-(seekend+seekpad+seekerwidth)))?(x-(seekstart+seekpad+seekerwidth))/(ww-(seekstart+seekend+2*(seekpad+seekerwidth))):1;
mB_drag_seek = (mB_drag_seek<0) ? 0 : (mB_drag_seek<1) ? mB_drag_seek : 1;
if(mood_bt.checkstate("down",x,y)==ButtonStates.down) {
if(moodbar_bool==1) {
moodbar_show=moodbar_show==1?0:1;
} else {
moodbar_show=1;
create_batch(trk_ext);
window.Repaint();
// ==============================================================/ double click
function on_mouse_lbtn_dblclk(x, y, mask) {
if((x>=mark_A_x && x<=mark_A_x+10 && y<12)||(x>=mark_B_x && x<=mark_B_x+10 && y<12))
mA_drag_seek=0;
mB_drag_seek=1;
mark_A_x = seekstart - 10 + seekerwidth;
mark_B_x = ww-seekend + 1 - seekerwidth;
window.Repaint();
// ==============================================================/ mouse move
function on_mouse_move(x, y)
// Seeker
hov_x = x;
if((fb.IsPlaying&&fb.PlaybackLength>0&&x>seekstart_bg&&x<ww-seekend_bg&&y>pad_y)||(g_drag&&x>seekstart_bg&&x<ww-seekend_bg))
g_drag_hov = true;
} else {
g_drag_hov = false;
// mark A
if(mA_drag && x+1<mark_B_x && x>=marks_xmin && x<=marks_xmax)
mark_A_x = x-9;
// mouse over with no drag
mA_hov=true;
} else {
mA_hov=false;
// mark B
if(mB_drag && x>mark_A_x+10 && x>=marks_xmin && x<=marks_xmax)
mark_B_x = x;
mB_hov=true;
} else {
mB_hov=false;
mB_hov=true;
} else {
mB_hov=false;
if (archive==0 && moodbar_enabled && fb.PlaybackLength>0 && moodbar_show==0 && (trk_ext=="flac" || trk_ext=="fla" || trk_ext=="mp3" || trk_ext=="wav")) {
mood_bt.checkstate("move",x,y);
window.Repaint();
// ==============================================================/ left button up
function on_mouse_lbtn_up(x, y)
lbtn_click=false;
// Seeker
if(g_drag)
g_drag = 0;
fb.PlaybackTime = fb.PlaybackLength * g_drag_seek;
// mark A
if(mA_drag)
mA_drag = 0;
if(x+1<mark_B_x && x>=marks_xmin && x<=marks_xmax)
if (fb.PlaybackTime<fb.PlaybackLength*mA_drag_seek) {
fb.PlaybackTime = fb.PlaybackLength*mA_drag_seek;
// mark B
if(mB_drag)
mB_drag = 0;
if (fb.PlaybackTime>fb.PlaybackLength*mB_drag_seek) {
mood_bt.checkstate("up",0,0);
window.Repaint();
// ==============================================================/ mouse Leave
function on_mouse_leave()
g_drag_hov = false;
mA_hov = false;
mB_hov = false;
window.Repaint();
function on_playback_seek(time)
window.Repaint();
// ==============================================================/ playback time (every seconds)
function on_playback_time(time)
if(g_timer){window.KillTimer(g_timer);}
if(fb.PlaybackLength>0){
g_timer = window.CreateTimerInterval(refresh_timer);
if(moodbar_enabled && moodbar_bool==0) {
timer_t1+=1;
if (timer_t1>=3) {
timer_t1=0;
// check every seconds if moodbar .png file found in music folder
moodbar_bool = 1;
} else {
moodbar_bool = 0;
// renaming moodbar file from short name to long name
var fso;
if(file_exists(definitive_moodbar_fullpath)==0 && file_exists(s_moodbar_fullpath) && bool_movefile==2) {
bool_movefile=1;
fso = new ActiveXObject("Scripting.FileSystemObject");
fso.MoveFile(s_moodbar_fullpath, definitive_moodbar_fullpath);
window.Repaint();
function on_playback_stop()
if(g_timer){
window.Repaint();
function on_playback_pause(state)
window.Repaint();
// ==============================================================/ Playback starting
function on_playback_starting(cmd, is_paused)
refresh_timer=Math.floor(len_seconds.Eval()/60)*25;
// check if moodbar .png file found in music folder
moodbar_bool = 1;
} else {
moodbar_bool = 0;
window.Repaint();
// ==============================================================/ Redraw more than once per sec
function on_timer(id)
if(size_changed) {
mark_A_x=Math.round((ww-120)*mA_drag_seek+(seekstart-5));
mark_B_x=Math.round((ww-120)*mB_drag_seek+(seekend+2));
size_changed=false;
if(mB_drag_seek==0.9985 && mA_drag_seek==0) mB_drag_seek=1;
if(mB_drag_seek==1) mB_drag_seek=0.9985;
if (fb.PlaybackTime >= fb.PlaybackLength*mB_drag_seek) {
if(mB_drag) {
fb.PlaybackTime = fb.PlaybackLength*mB_drag_seek;
} else {
if (fb.PlaybackTime < fb.PlaybackLength*mA_drag_seek) {
window.Repaint();
//Seek using mouse wheel
function on_mouse_wheel(delta){
if(delta>0)
fb.RunMainMenuCommand("Seek Ahead by 10 Seconds");
else
fb.RunMainMenuCommand("Seek Back by 10 Seconds");
// ===============================================================================/ new track
function on_playback_new_track(info) {
bool_movefile=0;
var trk_fn;
var pref_fn;
moodbar_radio=1;
} else {
moodbar_radio=0;
// reset markers A & B pos
mA_drag_seek = 0;
mB_drag_seek = 1;
CollectGarbage();
if(fb.PlaybackLength>0 && moodbar_radio!=1) get_file_info();
moodbar_bool = 0;
moodbar_bool = 1;
moodbar_show=0;
// ===============================================================================/ Seek using mouse wheel
if(delta>0)
goto_bookmark_ahead();
else
goto_bookmark_back();
// ===============================================================================/ Seek ahead 5 sec.
function goto_bookmark_ahead()
var i;
for(i=0;i<5;i++) {
fb.RunMainMenuCommand("Seek Ahead by 1 Second");
window.Repaint();
// ===============================================================================/ Seek back 5 sec.
function goto_bookmark_back()
var i;
for(i=0;i<5;i++) {
fb.RunMainMenuCommand("Seek Back by 1 Second");
window.Repaint();
// ===============================================================================/ file_exists
function file_exists(chemin) {
var fso, bool;
bool=fso.Fileexists(chemin);
return bool;
function GrabShortPath(filespec)
var fso, f, s;
f = fso.GetFile(filespec);
s = f.ShortPath;
return(s);
function GrabShortName(filespec)
var fso, f, s;
s = f.ShortName
return(s);
// ===============================================================================/ refresh file info (tf)
function get_file_info() {
var s1, s2, s3, s4;
archive = is_archive.Eval();
trk_fullpath = track_fullpath.Eval();
trk_ext = track_ext.Eval();
if(archive==0) {
s_trk_fullpath = GrabShortPath(trk_fullpath);
s_trk_filename_ext = GrabShortName(trk_fullpath);
s1 = trk_ext.length;
s2 = trk_fullpath.length;
s3 = s_trk_fullpath.length;
moodbar_fullpath = trk_fullpath.substring(0,s2-s1-1) + ".png";
s_moodbar_fullpath = s_trk_fullpath.substring(0,s3-4) + ".png";
s4 = s_trk_filename_ext.length;
trk_filename = track_filename.Eval();
definitive_moodbar_fullpath = s_trk_fullpath.substring(0,s3-s4)+trk_filename+".png";
bool_movefile=2;
// ===============================================================================/ create .bat file to convert to mp3
function create_batch(ftype) {
var fso, f1, ts, s;
var ForReading = 1;
var ForWriting = 2;
var Str0, Str1, Str2, Str3, Str4;
var chem;
var mypath;
var wtitle="MoodBar";
var runcmd;
var c_quote;
c_quote = char_quote.Eval();
chem = track_path.Eval();
mypath = s_trk_fullpath.substring(0,s_trk_fullpath.length-12);
if (file_exists(moodbar_dir + "foobar.bat")==true) {
ts = fso.OpenTextFile(moodbar_dir + "foobar.bat", ForWriting);
} else {
ts = fso.CreateTextFile(moodbar_dir + "foobar.bat", ForWriting);
switch(ftype)
case "mp3":
// ts.WriteLine(GrabShortPath(moodbar_dir+"moodbar.exe")+" -r -p -c:3 -h:2 -w:1024 -mp3:"+s_trk_fullpath);
ts.WriteLine(GrabShortPath(moodbar_dir+"moodbar.exe")+" -r -p -c:3 -h:10 -w:1024 -mp3:\""+s_trk_fullpath+"\"");
break;
case "flac":
Str0 = GrabShortPath(moodbar_dir+"flac.exe");
Str1 = GrabShortPath(moodbar_dir+"gogo.exe");
Str2 = Str1.substring(0,Str1.length-8)+"moodbar.exe";
if(ftype.length==3) {
Str3 = s_trk_fullpath.substring(0,s_trk_fullpath.length-trk_ext.length-1)+".mp3";
} else {
Str3 = s_trk_fullpath.substring(0,s_trk_fullpath.length-trk_ext.length-0)+".mp3";
Str4 = s_trk_fullpath.substring(0,s_trk_fullpath.length-trk_ext.length)+".wav";
if(ftype=="flac") {
ts.WriteLine(Str0+" -d "+s_trk_fullpath);
ts.WriteLine(Str1+" -b 128 -m s -nopsy -q 9 "+Str4);
} else {
ts.WriteLine(Str1+" -b 128 -m s -nopsy -q 9 "+s_trk_fullpath);
ts.WriteLine(Str2+" -r -p -c:3 -h:10 -w:1024 -mp3:"+Str3);
ts.WriteLine("del "+Str3);
ts.WriteLine("del "+Str4);
break;
case "wav":
} else {
if(ftype=="flac") {
} else {
break;
ts.WriteLine("del "+mypath+"*.mood");
ts.Close();
runcmd = "START "+c_quote+wtitle+c_quote+" /MIN cmd /C ";
WshShell.run("cmd /C "+runcmd+GrabShortPath(moodbar_dir+"foobar.bat"));
