Topic: foo_queuecontents - View and edit queue (Read 100685 times) previous topic - next topic
Reply #75
...Also columns ui support added due to user demand!
may i kiss you sir? thank you very much for your work
  • kerpondile
Reply #76
Sorry not with that avatar face  Thanks anyways!
EDIT: btw, please tell me what you like of the columns ui component and if you find something that should be fixed.
  • Last Edit: 17 August, 2010, 07:16:16 PM by shakey_snake
  • jeremija
Reply #77
I get a crash error when I try to rearrange the columns by dragging and dropping.
Reply #78
i'm not at my desktop at the mo, but will get it into my config & give a good testing once i'am.
thanks again, your works appreciated
  • kerpondile
Reply #79
Sorry about that, I don't know what is wrong with it.
I recompiled the code and tested it. Please, try to download the component again from the web site.
  • Hamallainen
Reply #80
.... Also columns ui support added due to user demand!
Just wonderful, thanks a lot for this update.
I find the UI element a better way to manage the queue than the playlist.
I just did quick test but the Auto-scale Columns seems to have no effect. And when the panel has focus, keyboard shorcuts do not work. Will test more later.
Thanks again.
  • kerpondile
Reply #81
CUI or DUI?
  • Last Edit: 17 August, 2010, 07:15:50 PM by shakey_snake
  • Hamallainen
Reply #82
Sorry, i did not say i was using CUI since i was thank you for adding CUI support but yes i'm using CUI
  • kerpondile
Reply #83
What do you mean that auto-scale columns does not work?
The intended behaviour is that (column width) / (ui elem. width) is kept constant for every column when the ui element is resized.
I found out that there is some tweaking to do when resizing columns but it still should work somewhat.
The keyboard shortcut problem truly exists for CUI, I'll look into it.
-kerpondile
  • Last Edit: 17 August, 2010, 07:15:36 PM by shakey_snake
  • Hamallainen
Reply #84
Ah ok, i had misunderstood the behaviour.
I thought, it was supposed to immediately and automatically use the whole width of the panel right after activating it. Now i understand the '... with window size' part. Thanks for explaining.
  • kerpondile
Reply #85
..... And when the panel has focus, keyboard shorcuts do not work. Will test more later.
Thanks again.
Fixed in the newest version 0.3.1.
-kerpondile
Reply #86
Thanks for the update!
Here some bugs/glitches:
  • I can't create columns: after applying OK in preferences the line falls back to origin content (Name, Pattern, Left)
  • When draggin from playlist to uielement then the item in playlist view has no value for queueindex in playing column.
  • After resizing column in uielement manually i see vertical lines going through the display.
german support forum: www.foobar-users.de / user: qwert73
  • kerpondile
Reply #87
* I can't create columns: after applying OK in preferences the line falls back to origin content (Name, Pattern, Left)
Are you sure you have pressed return key after you have modified name/pattern/left?
* When draggin from playlist to uielement then the item in playlist view has no value for queueindex in playing column.
I don't know how I missed that, don't know if it was working on some stage  I'm gonna look at it
*After resizing column in uielement manually i see vertical lines going through the display.
I didn't manage to reproduce this. Are you using CUI or DUI? What operating system?
-kerpondile
  • jeremija
Reply #88
It seems to work OK now! Thank you!
  • Last Edit: 13 April, 2010, 12:46:23 PM by jeremija
  • Hamallainen
Reply #89
  Fixed in the newest version 0.3.1.  -kerpondile
  Yes it works now, thanks.
  Sorry to bother you again but the CUI panel doesnt remember Show column header state after restart. I activate it, it shows. I restart foobar, it's not on anymore, i have to re-activate it. Don't know if it matters but the panel is in a tab stack. Version 0.3 or 0.3.1, it's the same.
Reply #90
...Sorry to bother you again but the CUI panel doesnt remember Show column header state after restart. I activate it, it shows. I restart foobar, it's not on anymore, i have to re-activate it. Don't know if it matters but the panel is in a tab stack. Version 0.3 or 0.3.1, it's the same.
i too am experiencing this issue, whenever i disable the header it reappears on restart.
queue contents is contained in a panel stack splitter.
using latest version of foobar & components in vista sp2.
thanks for your time
  • kerpondile
Reply #91
I will investigate it. I think I found the reason. For the next version this will fixed and probably the drag & drop will work as intended too.
Reply #92
I am sure i have not pressed it!  That was the reason: i navigated with the mouse to next cell without confirming with enter key.  I must say that it is somehow unconvenient.
Sorry for giving almost no information. I am using DUI. I see the border on a Vista SP1 machine on the classic theme. On a XP machine i see no border in any theme.
  • kerpondile
Reply #93
I will fix it in the next version. It annoys me too  ESC-key will be fixed also in the preferences; currently it doesn't work when the grid control is focused.
About the border issue: I cannot reproduce it with Windows 7 (tried classic theme also). So I think I just have to leave it. Sorry
-kerpondile
  • Last Edit: 17 August, 2010, 07:15:04 PM by shakey_snake
  • kerpondile
Reply #94
New version available.
CHANGELOG:
0.3.2 / 2010-04-20
Bug fixes:
* Changes to column names are updated immediately in ui elements.
* "Show Column Header" setting is now correctly preserved over different foobar2000 sessions.
* ESC button works as expected in the preferences dialog: it closes it.
* Fixed column size glitches when enabling/disabling auto-sizing of columns
Improvements:
* UI element automatically refreshes items when one of the queue items has a metadata change.
* UI element has the same border style than the DUI playlist view.
* Preferences dialog: When configuring columns, no need to press return key anymore, text is committed automatically. Also improved processing of ESC and other keys in the prerences.
* Preferences dialog: Columns are sized reasonably by default
* Preferences dialog: Syntax Help button for HA Syntax Help.
* Preferences dialog: Help button brings to the wiki page.
* Drag from playlist to ui element now correctly queues the item preserving the "link" to the playlist (i.e. playlist items will have %queue_index%) for the dragged items in the playlist).
** Behaviour tested with DUI playlist and various playlist components for CUI.
** NOTE: As far as I know there is no proper way to do this, and currently the program checks every drop against the active playlist selection. If they are the same (same items and in the same order), drop is interpreted as queuing from the playlist. In addition, I've implemented a check that matches the dropped items against currently selected items. Currently selected items are the selected items of the currently focused UI element. This is not 100% fool proof but it should work in 99.9 % of the regular cases. (And in the 0.01 % of the cases it still doesn't explode the universe).
Other:
* Queue playlist functionality is now disabled by default for new installations.
EDIT: fixed formatting
  • Last Edit: 20 April, 2010, 04:54:55 AM by kerpondile
Reply #95
thank you for your continued work kerpondile
  • Hamallainen
Reply #96
Thanks for the update, everything's ok now except just a minor thing (sorry).
In the preference dialogue when i set alignement to RIGHT and click OK, it sets the panel's column to right but if i reopen preference dialogue, it says the alignement is set to CENTER while in the panel it's set to right. So it's working but the display is wrong in the preference dialogue.
Win XP SP3, foobar 1.0.2.1, foo_queuecontents 0.3.2
  • kerpondile
Reply #97
Thanks for the bug report. I've fixed the bug and now a new version (0.3.3) is available with the fix. Sorry for the inconvenience!
  • Last Edit: 17 August, 2010, 07:14:47 PM by shakey_snake
  • Hamallainen
Reply #98
Thanks to you.
It's perfect.
  • Naboul
Reply #99
Hello,
thanks a lot for your tool.
I got a little problem trying to reorder queue items by drag & drop. The behavior is quiet outstanding. Sometimes it moves 2 items, sometimes none and quiet often, it mix all the queue. Have you ever seen that kind of problem? I've tried with the last release, an old one, the UI layout and the default one (only foobar and the component).
Regards
