Topic: VBR settings with LAME 3.98.2 (Read 5806 times) previous topic - next topic
I'm still using LAME 3.93 due to the greater control over VBR encoding parameters, which unfortunately were removed in later versions and replaced by "presets" - maybe in an attempt to noobify the codec and make it easier for the populace to use - and found this table at the Wiki while researching about the 3.98.2 release:
Bitrate overview (mostly based on LAME 3.98.2 results) Switch    Preset    Target Kbit/s    Bitrate range kbit/s
-b 320    --preset insane    320    320 CBR
-V 0    --preset fast extreme    245    220...260
-V 1        225    190...250
Does that mean that, using the -V 0 switch, the encoder will never go beyond 260 kbps or even reach 320 when needed?
No. These are typical average bitrates.
I usually find those numbers true with R&B and hip-hop, but completely tossed out the window with metal.
Do you mean that, with metal, the encoder reaches higher bitrates more often? That's what should happen, since metal music naturally needs more data, and that's what I was trying to find out with my question (that the encoder will go higher in cases like this). I guess I'll download version 3.98.2 and run some tests comparing the average bitrates with the same material encoded with 3.93.
Mainly because of a design limitition on the Mp3 spec that handles high freqs, which causes metal music to be bloated with high bitrates.
You can use your control all you want, but it's been discussed many times over that the VBR presets (designated -VX, with lower X being higher quality and higher bitrate) are the most reasonable way to go if your goal is the quality of the encode. If your goal is a certain bitrate or range, use CBR or ABR.
None of the -V settings have a maximum-bitrate limit (other than the 320 kbps limit of the mp3 spec itself). -V0 will reach 320 quite frequently depending on the music. -V2 (the descendant of alt-preset standard) will reach 320 kbps less frequently, etc.
It's worth noting that there is no such thing as a 260 kbps mp3 frame. A given mp3 frame is limited to a set of discrete values. Starting above 100, the available bitrates for a given frame are 112, 128, 160, 192, 224, 256, and 320.
God kills a kitten every time you encode with CBR 320
Thans for your reply. I only mentioned the 260 value because I was quoting the Wiki.
