Topic: unknown Jackson song (Read 5974 times) previous topic - next topic
Hi, can anyone identify this Michael Jackson song from the few bars i remember? thanks.
"Give In To Me" from the Dangerous album
That's it! brilliant, thanks very much.
This sample seems to fail to work on foobar2000, but works fine on Quicktime. Maybe its just me.
It's you /mnt    Works fine here on fb2k v0.9.6.8 on Win7RC. Downloaded and opened it with Firefox 3.5.
Fails in Foobar 0.9.6.7 for me.  It sounds weird in VLC.  The left channel has the person whistling and the right channel has a weird beeping.
Strange, i've redownloaded it with IE 8 (shudders) and i still get the "Unable to open item for playback (Unsupported format or corrupted file)" error.
FYI: Same with 0.9.4.3 and 0.9.6.8 on WinXP SP2
C.
The file was encoded using an iPhone, and uploaded using a Mac, but i can assure you /mnt, your not missing much!
I found the reason: I can play the file because I have installed foo_input_alac.dll. If I remove this component fb2k can't play the file. So it's a 16 bits 2 channel Apple Lossless file with samplerate 8000 Hz and average bitrate of 68kbps
Edit: typo and added link to ALAC component
I found the reason: I can play the file because I have installed foo_input_alac.dll. If I remove this component Ifb2k can't play the file. So it's a 16 bits 2 channel Apple Lossless file with samplerate 8000 Hz and average bitrate of 68kbps
I see, its a Apple Lossless file. I did have a outdated version of foo_input_alac.dll though.
I've updated the plugin and it seems to work now.
