Topic: fb v. 0.9.6.8 incorrectly displays ISO-8859-1 ID3v2 tags (Read 4683 times) previous topic - next topic
  • cancel
My default locale is cyrillic and foobar2000 doesn't display properly ISO-8859-1 encoded frames of id3v2 tags. It looks like it displays ISO-8859-1 frames converted to CP1251.
Is it possible to tell fb2000 to not translate ISO-8859-1 frames?
  • 2E7AH
Foobar reads/writes in UTF-8. If the tags are not in your code page (cyrillic) or standard ASCII, I suppose you'll see some garbage for some chars in different code page, if that's what you are telling. That can be solved using foo_chacon
[edit] You shouldn't have porblem with latin-1
  • Last Edit: 06 July, 2009, 02:07:16 AM by 2E7AH
  • cancel
But I have unfortunately. Latin-1 is always converted to CP1251.
  • cancel
Here is an example http://i067.radikal.ru/0907/44/6a3e1b230055.png
Instead of “Väsen - Spirit | Höllöl” it shows what you see on screenshot.
  • 2E7AH
OK then, for accented characters you should use foo_chacon
[edit] Hm, I tried foo_chacon right now but it doesn't seems to convert latin-1 chars right (same CP1251)
  • Last Edit: 06 July, 2009, 02:32:12 AM by 2E7AH
  • cancel
But I don't want to edit files (actually I can't), they are absolutely normal, I just want to see latin-1 frames content not converted to local default one-byte encoding. Is it normal to silently convert latin-1 to local charset? Maybe there is somewhere extension to override suce behavior?
  • 2E7AH
They are not converted, but just displayed as is in your code page. Put the files in WMP or Winamp and you'll see the same garbage chars, but I'm right now looking why foo_chacon can't convert it as it should.
[edit] missunderstood
  • Last Edit: 06 July, 2009, 02:57:56 AM by 2E7AH
  • cancel
Well, it's normal if you what it to. Put the files in WMP or Winamp and you'll see the same garbage chars, but I'm right now looking why foo_chacon can't convert it as it should.
Nope, winamp (mp3 decoder actually) has the option how to interpret latin-1 tags so winamp displays tags properly.
  • 2E7AH
For users in CP1251 (cyrillic) who might have problems with old ISO_8859-1 (latin1) charset, here is quick macro for masstagger or "properties > tools > automatically fill values..."
Example is for TITLE which is most common, and like I run to it just now downloading some autoplate release if it's for believing
$replace(%title%,
'Ў','¡','ў','¢','Ј','£','Ґ','¥','Ё','¨','Є','ª','Ї','¯','І','²','і','³','ґ','´','ё','¸','№','¹','є','º','ј','¼','Ѕ','½','ѕ','¾','ї','¿','А','À','Б','Á','В','Â','Г','Ã','Д','Ä','Е','Å','Ж','Æ','З','Ç','И','È','Й','É','К','Ê','Л','Ë','М','Ì','Н','Í','О','Î','П','Ï','Р','Ð','С','Ñ','Т','Ò','У','Ó','Ф','Ô','Х','Õ','Ц','Ö','Ч','×','Ш','Ø','Щ','Ù','Ъ','Ú','Ы','Û','Ь','Ü','Э','Ý','Ю','Þ','Я','ß','а','à','б','á','в','â','г','ã','д','ä','е','å','ж','æ','з','ç','и','è','й','é','к','ê','л','ë','м','ì','н','í','о','î','п','ï','р','ð','с','ñ','т','ò','у','ó','ф','ô','х','õ','ц','ö','ч','÷','ш','ø','щ','ù','ъ','ú','ы','û','ь','ü','э','ý','ю','þ','я','ÿ')
  • Last Edit: 06 July, 2009, 08:22:24 AM by 2E7AH
  • cancel
here is quick macro for masstagger or "properties > tools > automatically fill values..."here is quick macro for masstagger or "properties > tools > automatically fill values..."
Is there any plugin/script that doesn't touch original files and just edit database records? I don't want to alter mp3s because they are absolutely correct.
  • 2E7AH
No, there isn't mainly for performance reason. And I wouldn't say that files tagged in 8859-1 code are correct from the code page perspective. Today everything is in UTF, unless you are talking about compatibility with same old hardware or you want to use old standard ID3v2.3 in 8859-1
