Topic: Masstager 1.8.2 - Bug in new variable %now% (Read 1852 times) previous topic - next topic
it only shows the current time if you add or edit the tagging rule "format value from other field". if you load a saved script or just run it from the files context menu, it will only write a question mark to the field.
1.) i load a saved script from the menu in the lower part and this happens:
2.) i double click on the line Format "ADDED" using "..." to open the edit window. then i just click on "ok" and the variable changes to the correct value:
Fixed in 1.8.3, thanks for reporting.
thankx for fixing
