Topic: sorting order, with a longer name (Read 3251 times) previous topic - next topic
I would like to know if sorting between "foo" and "foo bar" could be made more consistent
let me introduce with this screenshot :
[a href="http://img265.imageshack.us/i/fb2ksorting.png/" target="_blank"]
Cheers
  • smkk
Made a thread about this a while ago: http://www.hydrogenaudio.org/forums/index....c=69885&hl=
I forget to mention I am using a custom grouping scheme :
$if($meta_test(album artist),'['%album artist%']  ',$if($meta_test(artist),'['%artist%']  '))$if($meta_test(date),%date%[ - %album%],[%album%])
however the issue is identical with predefined grouping schemes
I think the issue is related with this precise part :
[a href="http://img5.imageshack.us/i/spacebackslash.png/" target="_blank"]
usings some things like $directory_path(%path%)
Cheers
  • Last Edit: 30 June, 2009, 08:58:29 AM by BigBertrand
  • Frank Bicking
  • Global Moderator
Can't help with the sorting issue, but except for the fact that %album artist% does not only fall back to artist but also composer and performer, your grouping pattern should be the same as:
['['%album artist%']'  ][%date% - ][%album%]
Hi again,
I've begun, crafting this:
$replace($directory_path(%path%)'*'%filename_ext%, ,:)
it uses the facts * and : are forbidden characters in paths, and considers this ordering : "*" then ":"
C:\my path 2\another file.mp3
C:\my path\my file.mp3
becomes :
C:\my:path*my:file.mp3
C:\my:path:2*another:file.mp3
I'm open to suggestions
Cheers
edit : thank you Frank Bicking, I hadn't noticed %album artist% fall back to %artist% ! so my current grouping scheme becomes simpler :
['['%album artist%']'  ]$if($meta_test(date),%date%[ - %album%],[%album%])
ah, I use a $if(...) instead of [%date% - ], because I have files with %date% but no %album%, and don't like to display "ghost" hyphens
  • Last Edit: 30 June, 2009, 09:55:09 AM by BigBertrand
It's me again,
I cannot fully use this scheme, because the file order is determined when adding to playlist...
I can add a column with my scheme, and click on its header to sort the list, but I cannot directly load the playlist sorted
does anybody have an idea ?
cheers
  • Last Edit: 30 June, 2009, 10:31:33 AM by BigBertrand
  • shakey_snake
  • Moderator
Edit->Sort->Sort By...
  • Last Edit: 30 June, 2009, 10:33:55 AM by shakey_snake
elevatorladylevitateme
thank you shakey_snake, I didn't know about this option
however, it doesn't solve the problem: it needs to be called each time... the setting is not automatically applied
edit : half solved... I put my scheme into : "Preferences > General > Sort incoming files by"
it is applied when loading from Windows Explorer, but not when loading from Album List...
  • Last Edit: 30 June, 2009, 11:19:42 AM by BigBertrand
  • shakey_snake
  • Moderator
edit : strange... I put my scheme into :
but looks like it is not applied
Playlists created from the Album List inherit their sort pattern from the Album List view.
It just so happens that the sort pattern is treated differently with Window's Natural Sort (what is used on the playlist, or Sort Incoming Files By...) than it is using the windows explorer tree (what sorts the Album List in "by folder structure" mode and the tree in explorer).
There's not much fb2k can do about it.
  • Last Edit: 30 June, 2009, 11:53:32 AM by shakey_snake
Ideally, this behaviour of Album List might be corrected
One sees part of a folder structure in Album List, he expects this structure to be loaded in the same order in the Playlist View...
It would really be helpful for some users, including myself
Cheers
