Topic: I mad a sox script that converts automatically (Read 2061 times) previous topic - next topic
So this script is in a folder and you put the folder in the directory with the files.  Then run the wav.to.flac.bat script and it will convert all the wav files to flac.
It renames them taking out spaces and replacing with periods. - but that can be changed.
There is also a script that converts wv to flac which I've been using.
IF YOU DON'T WANT IT TO DELETE THE SOURCE FILES, EDIT THE SCRIPT AND REMOVE THE DEL LINE OR AD REM TO THE BEGINNING OF THAT LINE
http://www.mediafire.com/?sharekey=c23333a...04e75f6e8ebb871
I MADE IT, BUT I'M NOT MAD
