Topic: foo_playlists_sort (Read 7641 times) previous topic - next topic
foo_playlists_sort
foo_playlists_sort makes you able to sort your playlist list.
Current version (will be edited if new would come): 0.1.9
Use cases:
  • sort playlists alphabetically (ASC/DESC)
  • sort playlists by time (ASC/DESC)
  • sort playlists by tracks number (ASC/DESC)
  • sorting automatically! (there exists option to disable automatic)
Where to use:
  • View->Sort Playlists
>> Download Link <<
foo_playlists_sort
Works great. Thank you for this useful component.
foo_playlists_sort
version: 0.1.9
  • autosorting on changes (as an option)!
  • new options - sorting by time and by tracks number
BTW: Where the heck is EDIT option for posts?
foo_playlists_sort
>> Download Link <<
I cannot get the component, the download link leads to a site which shows: "B??d 404 - Obiekt nieznaleziony" (the typical error 404 I assume).
foo_playlists_sort
My blog server (ovh.org) doesn't work properly and site is broken for now. Sorry for that little mess. Please download component from link that Yirkha gave (thanks Yirkha).
For now should be okay (>> Download Link <<).
Any suggestions about component?
foo_playlists_sort
Hi. I've tried to install foo_playlist_sort component, but I get this message:
"Failed to load DLL: foo_playlists_sort.dll
Reason: Couldn't star application because setup is incorrect. Reinstall the application cuold solve the problem" (or something like that: my version is in spanish).
What should I do?
foo_playlists_sort
Install this.
