Topic: foo_facets search bar has jagged edges (Read 2166 times) previous topic - next topic
When using foo_facets in Windows XP with Windows Classic theme, the search bar of the foo_facets component appears to have jagged edges.  It seems to get worse the longer that foobar2000 stays open.  I am using foo_facets v2008-02-25.
I've actually noticed the same thing on my PC using Windows Classic Theme. I'm not sure if it's been discussed before, but what you're actually seeing is what is behind the foobar2000 window. Move foobar2000 over a white window and all of the edges of the search box will be white. If you do the same with a black background, all of the edges will be black, etc. I'm not sure why it happens, but it may have been discussed before.
You're right.  I tried changing the background.  After changing the background, the search box had edges that were the same color as the background.
