Topic: Is FLAC the best choice? (Read 19138 times) previous topic - next topic
58.70% in that table means 58.70% of the original size. In the few tracks that you ripped, you saw 30% reduction or 70% of the original size. Compare the table's 58.70% to your 70%. You should rip more than a few tracks to get a good feeling for how well FLAC can compress the music you typically listen to. I see anywhere between 50% to just over 70%.
In the tag it says (30% Compressed)
On the Comparison Table @ wiki, FLAC's Compression is 58.70%. I have ripped a few tracks using FLAC, and they were compressed at 30%. Where did the 58.70% come from?
I wouldn't pay this too much mind. As the compression ratio from what I understand is kind of dependent on the kind of music being encoded, ie: Pop, Jazz, Rock, Classical...
It's true, i just read this Topic, you can see on the posts the difference when user rip a rock music or classical music.
I ripped a Country CD.
(30% Compressed)
What's the average bitrate of those FLAC files?
So this track is compressed by 30%, or to 70% of its original size.
Reply #34
It was compressed 30% of the original size with lossless quality.
Edit: Here you go...
Original Size: 39.43 MB
Compressed to: 27.83 (30%)
Sample Rate: 44.1 KHz
Sample Size: 16 bit
Bit Rate: 1,411 kbps
Audio Quality: Perfect (Loseless)
Reply #35
That's what I said, '30% reduction or 70% of the original size.' I have ripped thousands of tracks (pop, rock, country, rap, etc) and I typically see around 65%. As I mentioned, I see anywhere between 50 to just over 70%, so your 70% for only one track is fine.
Reply #36
As someone who does not use lossless on a portable, I'm almost tempted to use WAV.
If it weren't for the lack of tagging, I probably would.
Storage, for me, is not a consideration any longer. Those 1 Tb drives are downright cheap looking at what I paid for a 1 Gb drive 15 years ago.
For now, I use Wavpack for archiving, put the CUE, LOG, and cover art into a folder. I calculate an MD5 for the folder's contect and store it in the folder. Then I use WinRAR to store (not compress) the entire folder using a 3% recovery record. When I have a DVD of these archive RARs, I burn them to two DVDs. Once burned, I delete the folders. Puts a lot of trust into a bit of ink on a shiny platter, eh?
Reply #37
I'm looking to rip a lot of music for a friend. Normally I encode to MP3 with LAME, but he wants lossless. Is FLAC the best choice? I've looked at a few polls, and FLAC was top choice in all of them.
Have you already checked this page with this table?
Robertina.
In that chart, shorten has RIFF chunks - yes  , but it is orange coloured not green.
