Topic: .tta -> .flac conversion with cue file (Read 14315 times) previous topic - next topic
I have a album in lossless .tta format but the problem is the entire album is one .tta file with a .cue sheet included. I can't directly convert the .tta file to .flac without first seperating the individual tracks. What I've been doing is burning the album using Burrrn 1.14 Beta 2 to a CD-RW and using EAC to rip the tracks to .flac.
I feel like I'm taking a extra step by burning it to CD and then converting it to FLAC as the .tta file is already a compressed lossless file to begin with.
Since there is a foobar2000 plugin for TTA, couldn't you just install it and use foobar2000 to transcode from TTA to FLAC?
http://fb2k.org/show.php?id=181
Also you can use ttaenc to decode to wav. then edit the cue file
Problem is, I'm not too familiar with foobar2000.
I've did some digging and I found a program called Medieval CUE Splitter and I'm currently using that to split the files. Now I just need to find a program to transcode to FLAC.
ALAC is supported as input, experiment with the tool a bit yourself as I don't use Apple's lossless CODEC myself.
WavPack 5.8.1 -b384hx6cmv / qaac64 2.84 -V 100
shntool handles most lossless formats (including tta and flac).
