Topic: mp3DirectCut - cut, split, fade and record mp3s (Read 15230 times) previous topic - next topic
  • sPeziFisH
Current version: 2.11, 2009-04-10
    * Batch processing dialog
    * Prelisten did not work on a selection from beginning
    * Saving storage behaviour for ID3v1 tag to config
    * Splitted status line with ID3 usage info
    * New languages: Croatian, Indonesian
    * Adjustable big timer height
    * Other improvements
http://mpesch3.de1.cc
Trying to establish this thread for tracking updates on mp3DirectCut.
  • sPeziFisH
Current version: 2.12, 2010-05-22
    * Unicode support (enable under Settings/Misc)
    * Stupid hang on language selection fixed
    * Unselectable record base name problem fixed
    * Optional slim button layout
    * Batch function corrections
    * Pause detection optimizations
    * Improved compatibility for Windows Vista/7
    * Some more improvements
http://mpesch3.de1.cc/
  • sPeziFisH
    * Symbol button layout, volume slider and toolbar
    * Allowing Cue sheet save on modified audio length
    * Second overwrite/close warning can be disabled
    * ID3 tag saving also on selection export
    * Adjustable normalizing level in batch mode
    * Some other things
  • sPeziFisH
    *High resolution icon
    *New function: Check for Re-syncs
    *Restart button for config options
    *Save selection on VBR bug fixed
    *Tooltips should work on Wine/Linux
    *Lots of improvements and corrections
[..checking for updatez is a disease and not healable!  ]
Thanks for the updates.
Woody
  • Sunhillow
  • Members (Donating)
Great! Thank you for the update
  • sPeziFisH
* Cue flag (pause/cut/split) issues corrected
* Crash on Re-sync check fixed
* Batch dialog unicode issue fixed
* Other changes
edit: replaced changelog of homepage with those given inside mp3directcut
  • Last Edit: 07 January, 2012, 06:40:52 AM by sPeziFisH
  • sPeziFisH
  - AAC support implemented (no MP4, play with libfaad2.dll)
  - Project files with ANSI filenames working in Unicode mode
  - Bug on command line normalize fixed
  - Auto cue with minimum length and optional time name
  - Visualization improvements
  - Other changes
  • naturfreak
Update to Version 2.17
Changelog
    Auto crop function
    2GB file size limit error fixed
    ANSI mode recent list crash fixed
    MPEG visualisation modifications
    Disabling unusable menu items
    Optionally keeping source date on new file
    Default buttons in dialogs
    Some more improvements and corrections
http://mpesch3.de1.cc/mp3dc.html
  • naturfreak
2.18 · 2013-01-11 · Recent changes:
- Bugs on Split save fixed
- Adjustable recent file number
- Adjustable undo step number
- Project/Cue filename in windows title
  • sPeziFisH
  - Optional timeline in the audio graph
  - No Split save abort on Batch if nothing to split
  - Cleared out some Lame settings
  - ID3v1 genre bug fixed
  - Icon resolution improved
  • naturfreak
2.20 · 2014-04-04 · Recent changes:
-  Auto crop improved and added to command line options
-  Command line bug fixed (filename detection)
-  "Lowest gain" setting (fades, Auto crop) added to config dialog
-  Check for re-syncs did not work after bug fix
-  Cut button renamed to Cut/Cue (to differ from Cut/Copy/Paste)
-  More mouse wheel functions (zoom, fast scroll, volume)
-  Two-stage fade function
-  Some other improvements
  • sPeziFisH
2.21 · 2015-09-30 · Recent changes:
- Dark and bright themes and button symbols
- Window color adjustable
- VU meter slightly improved
- Settings window re-arrangements
- Dark style about window
- New icon
- Optional recording time limitation
- Optional recording split by time
- Some corrections
  • sPeziFisH
Re: mp3DirectCut - cut, split, fade and record mp3s
  - Two more zoom out levels
  - Crash on large window size fixed
  - Less CPU usage for selection graph
  - Editable folder fields for Batch and Split
  - Possible crash on simple fade out fixed
  - Some more corrections and adaptions
mpesch3.de1.cc
  • Nystagmus
Thanks for such a good program.  I especially like using it on tracks with empty space at the beginning and some album tracks that have junk from the next track at the end of the tune.  I use it on Linux via Wine and it still works quite well.
Be a false negative of yourself!
MP3DirectCut is a bloody marvellous thing!
Thanks for such a good program.  ... ... ...   I use it on Linux via Wine and it still works quite well.
Me too and me too.
A really useful tool. I hadn't known about recent updates, so will catch up. Nice to see that it is under active development.
The most important audio cables are the ones in the brain
  • sPeziFisH
  - MP4 demuxing by calling external ffmpeg
  - Bug on Xing VBR header reading fixed
  - Saving "Cut whole pause" setting
  - Big timer with total track time option
  - Minor improvements
  • jaybeee
Great prog that I use almost everyday, so many thanks  :D
The demuxing the MP4 files is handy but it would be even better if we could remux the edited AAC file(s) back into M4A file(s); maybe by adding an option to perform this (default is off).
Apologies if this isn't the right place to ask for a feature request.
  • [JAZ]
@jaybeee : Indeed. The addition of reading M4a is nice but not so much the fact that each file that you read, it extracts the .aac file and leaves it there, since it is the format in which the program works.
When I've had the need to work with m4a files in mp3directcut, I used the following small script: (it works by dragging the file into it, or by calling it with the full path of the file)
%DIRFFMPEG%\ffmpeg.exe -i %1 -acodec copy -vn %1.aac
echo Waiting for the changes...
pause
%DIRFFMPEG%\ffmpeg.exe -i %1.aac -acodec copy -bsf:a aac_adtstoasc -vn %1.m4a
This intentionally leaves the original and the new file, but the script could delete it if needed. Basically, what the program is doing now is just the first ffmpeg command.
Note: it could also be modified so that it launches the program with the file automatically instead of the pause command:
%DIRMP3DC%\mp3DirectCut.exe %1.aac
  • jaybeee
Thanks [JAZ], I already have loads of scripts that I wrote to use mp4box &/or ffmpeg to do muxing/remuxing etc work. Nice to know I'm not the only one that has had to do this.
I posted up a script I wrote for using ffmpeg to split an m4a file without having to extract the aac first: clicky; it might be of use to you  ;)
  • tor11
mp3DirectCut can join multiple files to a file in its Batch processing, is it possible to do it using command line?
