Topic: How do I join wav files using Foobar? (Read 11149 times) previous topic - next topic
Hi all -- I'm new to foobar, and have gone through the menus, and just don't see how to do what I want to do!  I have 9 small .wav files, and I want to join them end to end to create one .wav file.  Can someone tell me how?  Thanks!
Have never done it, though I would think the convert dialog should give you enough options.
Select all files you need >Right Click> Convert > ... > take a look around and select appropriate options for wav and etc.
Output>Generate a multitrack file ; you will see that one file will be generated
terry
And if you want to merge the files without declaring them as separate parts with a cue sheet or chapters, then you use Output -> Merge all tracks into one output file.
Ah!
Thanks you for pointing that out. Probably much closer to what the OP was looking for.
terry
Thanks so much!  It worked like a charm.  Great Community folks -- I've wanted to know how to do this for years and just never quite dug deep enough, and you guys and foobar made it easy.  Thanks again!
