See below last failure.txt. I've had to trim the module list.
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 0000073Ch
Access violation, operation: write, address: 0000073Ch
Call path not available.
Stack (3979F6B0h):
3979F690h: 4DD58010 00000000 00000000 00E10000
3979F6A0h: 00000002 00000003 00000017 00E10000
3979F6B0h: 00EE3BA4 4A244A84 4CE5C5D8 27ED5A53
3979F6C0h: 00000000 015A0000 00E16468 00000000
3979F6D0h: 3979F6F4 77DE5C7E 4CE5C830 77DE5C7E
3979F6E0h: 00000000 00000000 000000A9 00000000
3979F6F0h: 4CE5C6B8 3979F710 76000166 015A0000
3979F700h: 00000000 000000A9 4CE5C834 4CE5C834
3979F710h: 3979F768 00E49816 000000A9 3979F6B4
3979F720h: 3979F77C 00FE8A58 00000001 3979F768
3979F730h: 00F7A110 01017608 4CE5C5D8 00000098
3979F740h: 00E491D4 00000099 4A244A84 4CE5C5D8
3979F750h: 27ED5A53 00F7A0F7 3979F734 3979F984
3979F760h: 4CE5C5D8 4CE5C500 3979F788 00F7B976
3979F770h: 4883BD98 4A244A84 4CE5C5D8 3979F82C
3979F780h: 00FDFCE8 00000000 3979F838 6CA8ADD0
3979F790h: 3979F820 4883BD98 4A244A84 C533018B
3979F7A0h: 3979F83C 49F99628 2928BF01 3979F984
3979F7B0h: 6CAC5618 00000000 00000000 00000000
3979F7C0h: 00000015 6CA771F1 3979F7D4 6CA773B0
Registers:
EAX: 0000073C, EBX: 27ED5A53, ECX: 4A244A84, EDX: 00000000
ESI: 4A244A84, EDI: 4A244A84, EBP: 3979F72C, ESP: 3979F6B0
Unable to identify crash location!
Loaded modules:
foobar2000 loaded at 00E40000h - 010A1000h
foo_dsp_replaygain loaded at 6EAD0000h - 6EAE3000h
foo_dsp_nogaps loaded at 6EAB0000h - 6EACB000h
foo_onewaysync loaded at 10000000h - 10494000h
oledlg loaded at 6EA80000h - 6EAAC000h
WINSPOOL loaded at 6EA10000h - 6EA7D000h
foo_discogs loaded at 06510000h - 065BE000h
foo_musical_spectrum loaded at 04250000h - 0426C000h
foo_dsp_src_resampler loaded at 6E890000h - 6EA09000h
foo_input_dts loaded at 6E860000h - 6E885000h
avformat-foodts-58 loaded at 6E620000h - 6E68E000h
avcodec-foodts-58 loaded at 6E690000h - 6E851000h
avutil-foodts-56 loaded at 6E570000h - 6E61F000h
foo_external_tags loaded at 6E4C0000h - 6E570000h
foo_enhanced_playcount loaded at 04290000h - 042C5000h
foo_uie_console loaded at 6E470000h - 6E4B9000h
foo_acfu loaded at 042F0000h - 04357000h
foo_skip loaded at 6E440000h - 6E46B000h
foo_dsp_delta loaded at 04370000h - 0438F000h
foo_runcmd loaded at 6E400000h - 6E433000h
foo_dsp_resampler_mod loaded at 6E2C0000h - 6E3F7000h
foo_playcount loaded at 6E290000h - 6E2B7000h
foo_input_std loaded at 6E130000h - 6E28B000h
avcodec-fb2k-58 loaded at 6DF10000h - 6E127000h
MSACM32 loaded at 6DEF0000h - 6DF09000h
winmmbase loaded at 6DED0000h - 6DEED000h
avutil-fb2k-56 loaded at 6DC20000h - 6DEC5000h
bcrypt loaded at 76D10000h - 76D29000h
foo_jscript_panel loaded at 6DA60000h - 6DC15000h
foo_out_upnp loaded at 6D9F0000h - 6DA60000h
WS2_32 loaded at 75DB0000h - 75E13000h
IPHLPAPI loaded at 75A80000h - 75AB2000h
foo_dsp_std loaded at 6D9C0000h - 6D9ED000h
foo_quicksearch loaded at 6D960000h - 6D9B7000h
WindowsCodecs loaded at 6D7F0000h - 6D960000h
foo_bitcompare loaded at 6D7D0000h - 6D7ED000h
foo_mouse_gesture loaded at 06890000h - 068BE000h
foo_out_wasapi loaded at 068D0000h - 068E2000h
foo_cdda loaded at 6D790000h - 6D7C9000h
foo_wave_minibar_mod loaded at 6D6E0000h - 6D781000h
foo_httpcontrol loaded at 6D660000h - 6D6D4000h
foo_spider_monkey_panel loaded at 6D410000h - 6D65B000h
foo_unpack loaded at 6D0B0000h - 6D11E000h
foo_uie_panel_splitter_mod loaded at 06960000h - 069B9000h
foo_texttools loaded at 6D070000h - 6D0A4000h
foo_spotify loaded at 6CF00000h - 6D06E000h
credui loaded at 73B70000h - 73B7D000h
HTTPAPI loaded at 710B0000h - 710BB000h
urlmon loaded at 71AB0000h - 71C59000h
iertutil loaded at 73070000h - 7329B000h
libspotify loaded at 04D10000h - 05091000h
DPAPI loaded at 710C0000h - 710C8000h
foo_dsp_xgeq loaded at 6CAE0000h - 6CB1C000h
foo_misc_addons loaded at 04CB0000h - 04CDB000h
foo_musicbrainz loaded at 6CA70000h - 6CAE0000h
foo_converter loaded at 6C9E0000h - 6CA6E000h
foo_masstag loaded at 05180000h - 051BD000h
foo_ui_columns loaded at 6C800000h - 6C9DE000h
USP10 loaded at 6C7E0000h - 6C7F7000h
foo_queuecontents loaded at 052C0000h - 0532E000h
foo_audioscrobbler loaded at 05340000h - 05375000h
foo_playlist_attributes loaded at 053D0000h - 0540B000h
foo_sanitizer loaded at 6C7C0000h - 6C7DF000h
foo_dsp_effect loaded at 05460000h - 054E3000h
foo_jesus loaded at 6C7A0000h - 6C7BA000h
foo_rgscan loaded at 6C750000h - 6C79D000h
foo_tfsandbox loaded at 6C700000h - 6C742000h
foo_cover_info loaded at 6C6D0000h - 6C6F3000h
foo_random_pools loaded at 054F0000h - 05528000h
foo_fileops loaded at 6C680000h - 6C6C2000h
foo_verifier loaded at 07B10000h - 07B53000h
foo_ui_std loaded at 6C560000h - 6C671000h
foo_run loaded at 07B70000h - 07BAA000h
foo_freedb2 loaded at 6C520000h - 6C551000h
foo_playlist_manager loaded at 07BB0000h - 07BF4000h
foo_dsp_vocal_exciter loaded at 6C500000h - 6C514000h
foo_lastfm_playcount_sync loaded at 6C4C0000h - 6C4F8000h
foo_input_sacd loaded at 6A840000h - 6ACCA000h
foo_dbsearch loaded at 07CB0000h - 07D20000h
foo_dsp_eq loaded at 6C490000h - 6C4B8000h
foo_run_group loaded at 6C460000h - 6C48C000h
foo_uie_playlists_dropdown loaded at 07D20000h - 07D5C000h
foo_albumlist loaded at 6C410000h - 6C459000h
foo_dsp_resampler loaded at 6C2D0000h - 6C407000h
foo_input_dsdiff loaded at 6C220000h - 6C24F000h
foo_masstag_addons loaded at 07DB0000h - 07DCF000h
foo_utils loaded at 6A7F0000h - 6A834000h
foo_vis_vumeter loaded at 6A740000h - 6A7E5000h
foo_input_monkey loaded at 0FE50000h - 0FEA9000h
foo_dsp_fsurround loaded at 154C0000h - 15599000h
foo_burninate loaded at 6A6C0000h - 6A6FE000h
foo_enhanced_spectrum_analyzer loaded at 0FF10000h - 0FF53000h
foo_dsd_processor loaded at 6A250000h - 6A608000h
foo_uie_elplaylist loaded at 6A640000h - 6A6B3000h
foo_beefweb loaded at 6A0D0000h - 6A241000h
<snip>
Stack dump analysis:
Address: 00EE3BA4h (foobar2000+A3BA4h)
Address: 77DE5C7Eh (ntdll+45C7Eh), symbol: "RtlAllocateHeap" (+3Eh)
Address: 76000166h (ucrtbase+30166h), symbol: "malloc_base" (+26h)
Address: 00E49816h (foobar2000+9816h)
Address: 00FE8A58h (foobar2000+1A8A58h)
Address: 00F7A110h (foobar2000+13A110h)
Address: 01017608h (foobar2000+1D7608h)
Address: 00E491D4h (foobar2000+91D4h)
Address: 00F7A0F7h (foobar2000+13A0F7h)
Address: 00F7B976h (foobar2000+13B976h)
Address: 00FDFCE8h (foobar2000+19FCE8h)
Address: 6CA8ADD0h (foo_musicbrainz+1ADD0h)
Address: 6CAC5618h (foo_musicbrainz+55618h), symbol: "foobar2000_get_interface" (+23408h)
Address: 6CA771F1h (foo_musicbrainz+71F1h)
Address: 6CA773B0h (foo_musicbrainz+73B0h)
Address: 6CAC4474h (foo_musicbrainz+54474h), symbol: "foobar2000_get_interface" (+22264h)
Address: 6CAC2AE0h (foo_musicbrainz+52AE0h), symbol: "foobar2000_get_interface" (+208D0h)
Address: 01052E4Ch (foobar2000+212E4Ch)
Address: 6CABED70h (foo_musicbrainz+4ED70h), symbol: "foobar2000_get_interface" (+1CB60h)
Address: 6CABED3Ah (foo_musicbrainz+4ED3Ah), symbol: "foobar2000_get_interface" (+1CB2Ah)
Address: 6CA971F7h (foo_musicbrainz+271F7h)
Address: 77DDED10h (ntdll+3ED10h), symbol: "RtlLeaveCriticalSection" (+0h)
Address: 6CAC56DCh (foo_musicbrainz+556DCh), symbol: "foobar2000_get_interface" (+234CCh)
Address: 77E277B4h (ntdll+877B4h), symbol: "RtlGetNtGlobalFlags" (+7B4h)
Address: 77DE3AB6h (ntdll+43AB6h), symbol: "RtlFreeHeap" (+46h)
Address: 76003C9Bh (ucrtbase+33C9Bh), symbol: "free_base" (+1Bh)
Address: 76003C68h (ucrtbase+33C68h), symbol: "free" (+18h)
Address: 6CABFC23h (foo_musicbrainz+4FC23h), symbol: "foobar2000_get_interface" (+1DA13h)
Address: 6CAA1027h (foo_musicbrainz+31027h)
Address: 6CABA760h (foo_musicbrainz+4A760h), symbol: "foobar2000_get_interface" (+18550h)
Address: 6CAC02B8h (foo_musicbrainz+502B8h), symbol: "foobar2000_get_interface" (+1E0A8h)
Address: 6CABA69Ah (foo_musicbrainz+4A69Ah), symbol: "foobar2000_get_interface" (+1848Ah)
Address: 6CAC14B0h (foo_musicbrainz+514B0h), symbol: "foobar2000_get_interface" (+1F2A0h)
Address: 6CABA769h (foo_musicbrainz+4A769h), symbol: "foobar2000_get_interface" (+18559h)
Address: 76014F9Fh (ucrtbase+44F9Fh), symbol: "o_iswdigit" (+5Fh)
Address: 76014F60h (ucrtbase+44F60h), symbol: "o_iswdigit" (+20h)
Address: 76031FD0h (ucrtbase+61FD0h), symbol: "crt_debugger_hook" (+C0h)
Address: 767DFA29h (KERNEL32+1FA29h), symbol: "BaseThreadInitThunk" (+19h)
Address: 767DFA10h (KERNEL32+1FA10h), symbol: "BaseThreadInitThunk" (+0h)
Address: 77E07C7Eh (ntdll+67C7Eh), symbol: "RtlGetAppContainerNamedObjectPath" (+11Eh)
Address: 777ADAE0h (KERNELBASE+1BDAE0h), symbol: "UnhandledExceptionFilter" (+0h)
Address: 7529BBCCh (MSWSOCK+BBCCh), symbol: "WSPStartup" (+21ECh)
Address: 77E1AF00h (ntdll+7AF00h), symbol: "wcstombs" (+70h)
Address: 77E07C4Eh (ntdll+67C4Eh), symbol: "RtlGetAppContainerNamedObjectPath" (+EEh)
Address: 77E288C2h (ntdll+888C2h), symbol: "RtlCaptureContext" (+F2h)
Environment:
App: foobar2000 v1.6.5
UI: Columns UI 1.6.0
Components:
Core (2021-04-06 09:16:06 UTC)
foobar2000 core 1.6.5
foo_acfu.dll (2019-01-12 12:00:54 UTC)
Auto Check for Updates 0.3
foo_albumlist.dll (2021-04-06 09:15:10 UTC)
Album List 1.6.5
foo_audioscrobbler.dll (2012-08-20 15:49:44 UTC)
Audioscrobbler 2.3.1
foo_beefweb.dll (2020-02-02 06:11:58 UTC)
Beefweb Remote Control 0.4
foo_bitcompare.dll (2021-03-04 17:26:38 UTC)
Binary Comparator 2.2
foo_burninate.dll (2011-02-26 09:00:52 UTC)
Audio CD Writer 3.0.3
foo_cdda.dll (2021-04-06 09:15:08 UTC)
CD Audio Decoder 1.6.5
foo_converter.dll (2021-04-06 09:15:14 UTC)
Converter 1.6.5
foo_cover_info.dll (2021-04-07 04:53:48 UTC)
Cover Info 0.1.0
foo_dbsearch.dll (2007-01-25 20:58:48 UTC)
Database Search 1.4
foo_discogs.dll (2020-04-11 05:21:32 UTC)
Discogs Tagger 2.23
foo_dsd_processor.dll (2017-11-14 08:46:24 UTC)
DSD Processor 1.0.2
foo_dsp_delta.dll (2008-10-24 15:57:16 UTC)
Noise Sharpening DSP 1.0.0
foo_dsp_effect.dll (2021-03-21 09:36:00 UTC)
Effect DSP 0.47
foo_dsp_eq.dll (2021-04-06 09:15:06 UTC)
Equalizer 1.2.2
foo_dsp_fsurround.dll (2012-07-08 08:20:57 UTC)
FreeSurround 0.9.0
foo_dsp_nogaps.dll (2017-04-22 08:30:04 UTC)
Gap Killer DSP 0.4
foo_dsp_replaygain.dll (2021-03-27 18:57:44 UTC)
ReplayGain DSP 0.2.6
foo_dsp_resampler.dll (2018-09-14 22:38:36 UTC)
SoX Resampler 0.8.4 beta 2
foo_dsp_resampler_mod.dll (2018-11-17 08:31:30 UTC)
SoX Resampler mod 0.8.4 mod
foo_dsp_src_resampler.dll (2021-02-20 11:50:06 UTC)
SRC Resampler 1.0.12
foo_dsp_std.dll (2021-04-06 09:15:06 UTC)
Standard DSP Array 1.6.5
foo_dsp_vocal_exciter.dll (2018-01-07 08:57:19 UTC)
Vocal Exciter 1.0.1
foo_dsp_xgeq.dll (2012-07-07 17:49:02 UTC)
Graphic Equalizer 0.3.7
foo_enhanced_playcount.dll (2021-03-20 22:33:38 UTC)
Enhanced Playback Statistics 4.3.3
foo_enhanced_spectrum_analyzer.dll (2018-05-26 09:34:03 UTC)
Enhanced Spectrum analyzer 0.9.4.2
foo_external_tags.dll (2020-09-20 15:53:32 UTC)
External Tags 1.5.11
foo_fileops.dll (2021-04-06 09:15:16 UTC)
File Operations 1.6.5
foo_freedb2.dll (2021-04-06 09:15:14 UTC)
Online Tagger 0.8
foo_httpcontrol.dll (2013-04-26 16:12:30 UTC)
HTTP Control 0.97.14-fb2kc
foo_input_dsdiff.dll (2018-01-24 21:59:23 UTC)
DSDIFF Decoder 1.6
foo_input_dts.dll (2019-02-21 08:16:56 UTC)
DTS decoder 0.6.8
foo_input_monkey.dll (2019-11-21 08:24:36 UTC)
Monkey's Audio Decoder 2.3.1
foo_input_sacd.dll (2018-01-24 10:56:10 UTC)
Super Audio CD Decoder 1.0.11
foo_input_std.dll (2021-04-06 09:15:36 UTC)
FFmpeg Decoders 4.3.1
Standard Input Array 1.6.5
foo_jesus.dll (2010-09-23 01:34:06 UTC)
Autosave & Autobackup 10
foo_jscript_panel.dll (2021-04-01 16:06:56 UTC)
JScript Panel 2.5.4
foo_lastfm_playcount_sync.dll (2020-02-08 22:29:20 UTC)
Last.fm Playcount Sync 1.0.1
foo_masstag.dll (2019-08-17 07:30:18 UTC)
Masstagger 1.8.5
foo_masstag_addons.dll (2009-02-10 22:54:08 UTC)
Masstagger Addons 0.3.5 (SSE)
foo_misc_addons.dll (2010-01-14 21:06:10 UTC)
Misc. Addons 1.1.6
foo_mouse_gesture.dll (2010-01-18 21:20:04 UTC)
Mouse Gesture Host 0.5.2
foo_musical_spectrum.dll (2015-10-03 18:38:25 UTC)
Musical Spectrum 0.9.1
foo_musicbrainz.dll (2020-05-17 02:05:44 UTC)
MusicBrainz Tagger 0.4.6
foo_onewaysync.dll (2020-04-20 23:19:28 UTC)
One Way Sync 0.7.0
foo_out_upnp.dll (2019-06-16 16:11:49 UTC)
UPnP MediaRenderer Output 1.3.2
foo_out_wasapi.dll (2020-12-30 13:08:46 UTC)
WASAPI output support 3.4
foo_playcount.dll (2020-07-01 22:00:50 UTC)
Playback Statistics 3.0.4
foo_playlist_attributes.dll (2019-02-03 07:54:06 UTC)
Playlist Attributes 0.5.5
foo_playlist_manager.dll (2007-01-22 13:05:12 UTC)
Playlist Manager 1.0.2
foo_queuecontents.dll (2015-10-04 08:39:16 UTC)
Queue Contents Editor 0.5.1
foo_quicksearch.dll (2015-10-15 16:15:54 UTC)
Quick Search Toolbar 3.6
foo_random_pools.dll (2017-05-01 19:40:40 UTC)
Random Pools 0.1.5
foo_rgscan.dll (2021-04-06 09:15:16 UTC)
ReplayGain Scanner 1.6.5
foo_run.dll (2018-03-22 17:25:48 UTC)
Run services 0.3.8
foo_run_group.dll (2017-07-03 20:12:33 UTC)
Run services per group 1.01
foo_runcmd.dll (2010-01-07 19:32:34 UTC)
Run Command 1.1
foo_sanitizer.dll (2021-02-15 14:49:24 UTC)
Tag Sanitizer 1.3
foo_skip.dll (2021-03-21 07:25:50 UTC)
Skip Track 1.33
foo_spider_monkey_panel.dll (2021-02-18 19:57:28 UTC)
Spider Monkey Panel 1.4.2-dev+ce39bb09
foo_spotify.dll (2021-02-18 18:14:12 UTC)
Spotify Integration 1.1.3
foo_texttools.dll (2010-09-12 17:33:56 UTC)
Text Tools 1.0.5
foo_tfsandbox.dll (2016-12-14 21:48:26 UTC)
Title Formatting Sandbox 1.0.3
foo_ui_columns.dll (2020-09-03 20:55:18 UTC)
Columns UI 1.6.0
foo_ui_std.dll (2021-04-06 09:15:20 UTC)
Default User Interface 1.6.5
foo_uie_console.dll (2020-04-11 11:10:10 UTC)
Console panel 1.0.1
foo_uie_elplaylist.dll (2010-10-30 21:51:16 UTC)
ELPlaylist 0.6.9.1.2(beta)
foo_uie_panel_splitter_mod.dll (2012-10-05 08:02:11 UTC)
Panel Stack Splitter 0.3.8.3(alpha)
foo_uie_playlists_dropdown.dll (2009-09-23 23:44:46 UTC)
Playlists Dropdown 0.7.6
foo_unpack.dll (2021-04-06 09:15:24 UTC)
ZIP/GZIP/RAR/7-Zip Reader 1.6.5
foo_utils.dll (2008-02-08 23:26:58 UTC)
Playlist Tools 0.6.2 beta 6
foo_verifier.dll (2020-07-02 11:34:34 UTC)
File Integrity Verifier 1.4
foo_vis_vumeter.dll (2016-10-26 17:10:21 UTC)
VU Meter 2013-02-16
foo_wave_minibar_mod.dll (2020-11-22 18:12:22 UTC)
Waveform Minibar (mod) 1.0.43
Recent events:
MusicBrainz Tagger: Musicbrainz query failed.
Machine specifications:
OS: Windows 10.0.19042 x64
CPU: Intel(R) Core(TM) i7-7567U CPU @ 3.50GHz, features: MMX SSE SSE2 SSE3 SSE4.1 SSE4.2
CPU threads: 4
