Topic: Suggested for consideration: iTunes Plus vs. neroAacEnc vs. Lame 3.98  (Read 8638 times) previous topic - next topic
  • M
Now that Apple has finally enabled what appears to be Quicktime's highest quality encoding for the iTunes "Plus" preset, would it be worth conducting a listening test to determine the relative standings of the current contenders?
  • iTunes Plus @256kbps
  • iTunes (standard) @256kbps ABR (optional)
  • neroAacEnc @~256kbps VBR
  • neroAacEnc @256kbps CBR (optional)
  • Lame 3.98 @~256kbps VBR
  • Lame 3.98 @256kbps CBR (optional)
    - M.
  • shakey_snake
  • FB2K Moderator
I think, if previous listening tests are any sort of indication, it's very likely that they're all going to be transparent on non-problem samples.
So then what are you wanting to compare exactly? Average filesize?
  • Last Edit: 20 March, 2009, 09:16:55 PM by shakey_snake
elevatorladylevitateme
Go for it if you have the ears.  Otherwise you probably aren't going to hear any difference between all three encoders.  I would be curious to see how the iTunes Plus setting stacks up to Nero and Lame.  I would still never use such a high bitrate setting as Nero produces transparent results at -q0.45--q0.50 for me but that doesn't stop me form being curious.
I think that you might have difficulties matching up the bitrates though.  From my experience, the iTunes Plus setting tends to produce files at around 280kbps while -V 0 averages files at about 260kbps.  I never tested Nero at -q0.60 but -q0.50 produces file at around 190kbps for me.  I don't know if a 20-30kbps difference would drastically affect things but it might be something to think about.
  • Zarggg
Unless one of those encoders are horribly glitched, all my submissions would be 5.0
  • dbAmp
Are we certain that the iTunes Plus setting is using VBR and not VBR_Constrained?
  • Busemann
iTunes Plus is VBR_Constrained @ 256kbps using the highest quality setting of the encoder.
  • Donunus
Sorry for the ignorance... constrained meaning 256 minimum or 256 max?
  • ShowsOn
  • Members (Donating)
Well I wouldn't be able to participate in such a test because all these settings will be transparent for me.
I wouldn't mind a new 128 Kbps test featuring LAME 3.98.2, the latest Nero AAC encoder and the new CoreAudio AAC encoder in OSX 10.6.
  • Last Edit: 18 September, 2009, 07:52:20 AM by ShowsOn
