Topic: WSH Panel Mod (Read 823448 times) previous topic - next topic
WSH Panel Mod
Reply #750
^I knew the issue, it will be improved in the next beta, I'm considering whether to break the older version upward computability or not.
WSH Panel Mod
Reply #751
can someone post a code snippet on how to use fb.GetSelection?
WSH Panel Mod
Reply #752
After some playing around it works quite well, but it behaves a little bit strange: for example if ones skips a track on_selection_changed(metadb) is called twice (first with metadb = null and GetSelectionType() giving 0).
Anyway this is how I use it now:
var followplayback = false;
var cmetadb = fb.GetFocusItem(true);
var fileinfo = cmetadb.GetFileInfo();
window.WatchMetadb(cmetadb);
//callbacks
function on_selection_changed(metadb) {
    if (metadb && !(fb.GetSelectionType() == 4 && !followplayback)) {
        cmetadb = metadb;
        window.Repaint();
And then I have a button to switch between following now playing file or not:
function ButtonFollowPlayback(check) {
    if (arguments.length == 0) {
        return followplayback;
    } else {
        followplayback = check;
        if (check && fb.GetSelection()) {
            cmetadb = fb.GetSelection();
WSH Panel Mod
Reply #753
^i can't see the point of that at all? i think fb.GetSelection should only be used when you're forcing the use of the foobar display preferences without a panel preference (like tedgo asked for).
if you're going to provide your own toggle you might as well use the old methods...
//now playing. (use selected item when playback is stopped)
g_metadb = fb.IsPlaying ? fb.GetNowPlaying() : fb.GetFocusItem();
//selected item
g_metadb = fb.GetFocusItem();
WSH Panel Mod
Reply #754
I wrote it this way because it requires relatively little code and I wanted to be able to suppress it when I am editing a tag.
WSH Panel Mod
Reply #755
@TP Wang: Tahnks for the last version. I dont know if you did it on purpose but my scripts dont crash anymore on startup
Now i have another question about foobar startup.
This a part of the code i use
function reloadConf(inipath)
    skinpath = translatePath(utils.ReadINI(inipath, "SKIN", "imgpath", ""),true);
    ///progressbar
    var pbw = window.width - 135;
    var pbh = 12;
    var pbx = window.width/2 - pbw/2;
    var pby = window.height - pbh - 4;
    np_progbar = new ProgressBar(pbx, pby, pbw, pbh);
    ///rating
    np_rating = new Rating(window.width - pbx + 3, window.height -17, skinpath);
    //lovebutton
    np_lovebutton = new LoveButton( 3, window.height -22, skinpath);
    on_item_focus_change();
reloadConf(inipath);
My problem is that when foobar starts my objects np_lovebutton , np_rating  and np_progbar are not created. Then when i open the script config and click ok, the objects appear. May be you can help me figure out what i am doing wrong.
Thanks again for all your hard work.
WSH Panel Mod
Reply #756
@carmenm:
See Notes & Hints #6.
WSH Panel Mod
Reply #757
IMainMenuManager only accept main menu root menu items (File, Library, etc), no submenu items.
Is there any hope for submenu support to be added?  I'd really like to implement a playlist switcher drop-down menu, and using the "View > Switch to playlist" submenu is the only way I can think to implement it.  If there's another way, I've love some details.  Though, even if there is, I'd still love to see submenu support so I can add the foo_softplaylists menu commands to a panel.  Thanks!
WSH Panel Mod
Reply #759
@Hitchhiker427:
I recommend you to construct a menu that contains these commands by yourself, it could have supported technically though.
WSH Panel Mod
Reply #760
Oh well.  Is there a way to grab a list of all the playlist names?  The "switch to playlist" submenu automatically lists all playlists, but I'm not sure how I could go about programming this with the currently available WSH Panel commands.  Thanks.
WSH Panel Mod
Reply #761
When I try to use Br3tt's Xchange 3.6.0 with Foobar 1.0, I get this kind of script errors.
WSH Panel Mod (GUID: FE555B68-9973-4106-9569-0F56AA7E707A): initliased in 0.0000424 s
Error: WSH Panel Mod (GUID: FE555B68-9973-4106-9569-0F56AA7E707A): Microsoft JScript Runtime Error:
Object is needed.
Ln: 98, Col: 3
<source text only available in compile time>
WSH Panel Mod (GUID: D8C107F3-CD87-47B0-9268-B2A93F21DD6F): initliased in 0.0000104 s
WSH Panel Mod (GUID: 67DCFFEA-F20F-4925-B950-99FE234D6628): initliased in 0.0000034 s
Filter Panel - Genre: initialised in 0.001 s
Filter Panel - Artist: initialised in 0.001 s
Filter Panel - Album: initialised in 0.001 s
WSH Panel Mod (GUID: A4CEED06-F3D8-4464-AE8D-F2AC641A7484): initliased in 0.0000124 s
Error: WSH Panel Mod (GUID: A4CEED06-F3D8-4464-AE8D-F2AC641A7484): Microsoft JScript Runtime Error:
Object is needed.
Ln: 61, Col: 4
WSH Panel Mod (GUID: 9C80188A-367D-436B-86C9-F40D8BFBE4B7): initliased in 0.0000108 s
Error: WSH Panel Mod (GUID: 9C80188A-367D-436B-86C9-F40D8BFBE4B7): Microsoft JScript Runtime Error:
Object is needed.
Ln: 62, Col: 13
WSH Panel Mod (GUID: 305E4E48-FAA0-4D8C-9992-64751C8364C2): initliased in 0.0000078 s
WSH Panel Mod (GUID: 6DE51533-8626-4A22-827A-C4A5C7D89249): initliased in 0.0000039 s
WSH Panel Mod (GUID: CFD19F51-0140-444F-BA25-096381C4D8E1): initliased in 0.0000048 s
WSH Panel Mod (GUID: 56DF1127-3F17-4DD0-9A1C-28E68A692096): initliased in 0.0000057 s
WSH Panel Mod (GUID: F430759F-4E5C-4E96-8ADB-8F76B82AC9C2): initliased in 0.0000017 s
Error: WSH Panel Mod (GUID: F430759F-4E5C-4E96-8ADB-8F76B82AC9C2): Microsoft JScript Runtime Error:
Object is needed.
Ln: 19, Col: 3
WSH Panel Mod (GUID: 883C9342-A015-4930-ACA9-E6C01E062750): initliased in 0.0000042 s
WSH Panel Mod (GUID: 31C5D6E8-BAAA-4926-A524-462B0335E901): initliased in 0.0000069 s
Error: WSH Panel Mod (GUID: CFD19F51-0140-444F-BA25-096381C4D8E1): Microsoft JScript Runtime Error:
Procedure call or argument is not valid.
Ln: 290, Col: 3
Error: WSH Panel Mod (GUID: 305E4E48-FAA0-4D8C-9992-64751C8364C2): Microsoft JScript Runtime Error:
Ln: 64, Col: 1
Startup time : 0:02.943336
There was no problem with the previous WSH panel mod 1.2.1 and Xchange 3.5.2 with Foobar 0.9.6.9 under Windows XP sp3.
Could anyone help me?
WSH Panel Mod
Reply #762
@Hitchhiker427:
I may add some API to access them in the future.
@widerock:
This is not related to WSH Panel Mod it self, if you are already using the latest version.
BTW, from what the error location is, I assume that you don't have xhange files correctly installed.
WSH Panel Mod
Reply #763
@widerock:
Wow.. it's my mistake. I installed xchange in the wrong directory.
Thank you very much, T.P Wang.
WSH Panel Mod
Reply #765
WSH Panel 1.3.2 Beta 3 Uploaded:
Changelog delta:
- ADD: on_playlists_changed() callback.
- ADD: Properties fb.PlaylistCount, fb.ActivePlaylist and fb.PlayingPlaylist.
- ADD: Methods fb.GetPlaylistName(), fb.CreatePlaylist(), fb.RemovePlaylist(), fb.MovePlaylist() and fb.RenamePlaylist().
- ADD: Sample Themed Progress Bar.txt.
- FIX: Preserve current selection when panel get focus.
WSH Panel Mod
Reply #766
progressbar is very sweet
can this component make somehow possible two instances in CUI toolbar, or is that CUI toolbar limitation?
WSH Panel Mod
Reply #767
Changelog delta:
WoW, playlist Methods, very sweet
thank you!
WSH Panel Mod
Reply #768
Thank you!
WSH Panel Mod
Reply #769
Excuse me for my ignorance but the included box blur example throws the error everytime you restart foobar.
Error: WSH Panel Mod (GUID: 031CFC6C-B509-4E8B-9BA7-9825AFB21B4E): Microsoft JScript runtime error:
'img_to_blur' is null or not an object
Ln: 88, Col: 2
Can somebody tell me how can i fix this?
I'm trying to learn everyday little bit, but it's soooo hard
WSH Panel Mod
Reply #770
edit: ignore. i was thinking of a different sample.
WSH Panel Mod
Reply #771
@ExtremeHunter:
In callback on_size(), check window.Width and window.Height:
ww = window.Width;
hh = window.Height;
// Add this line
if (ww <= 0 || hh <= 0) return;
FYI: If you want to create glow/blur text, consider using IStyleTextRender interface instead.
WSH Panel Mod
Reply #772
Thanks T.P that fixed it
WSH Panel Mod
Reply #773
Sorry, but I'm having trouble switching the active playlist.  For some reason, the "View > Switch to playlist > [playlist name]" commands do not work.  Would it be possible to add a fb.SwitchPlaylist() command?  Thanks.
WSH Panel Mod
Reply #774
^fb.ActivePlaylist = id;
