Please help with progress bar. When pause the playback, exit and restart boobar, it doesn't redraw the paused position. It also doesn't shows "playback stopped" when started in stopped state. Here is the code:
// Flags, used with GdiDrawText
// For more information, see: [url=http://msdn.microsoft.com/en-us/library/dd162498(VS.85).aspx]http://msdn.microsoft.com/en-us/library/dd162498(VS.85).aspx[/url]
var DT_TOP = 0x00000000;
var DT_LEFT = 0x00000000;
var DT_CENTER = 0x00000001;
var DT_RIGHT = 0x00000002;
var DT_VCENTER = 0x00000004;
var DT_BOTTOM = 0x00000008;
var DT_WORDBREAK = 0x00000010;
var DT_SINGLELINE = 0x00000020;
var DT_EXPANDTABS = 0x00000040;
var DT_TABSTOP = 0x00000080;
var DT_NOCLIP = 0x00000100;
var DT_EXTERNALLEADING = 0x00000200;
var DT_CALCRECT = 0x00000400;
var DT_NOPREFIX = 0x00000800;
var DT_INTERNAL = 0x00001000;
var DT_EDITCONTROL = 0x00002000;
var DT_PATH_ELLIPSIS = 0x00004000;
var DT_END_ELLIPSIS = 0x00008000;
var DT_MODIFYSTRING = 0x00010000;
var DT_RTLREADING = 0x00020000;
var DT_WORD_ELLIPSIS = 0x00040000;
var DT_NOFULLWIDTHCHARBREAK = 0x00080000;
var DT_HIDEPREFIX = 0x00100000;
var DT_PREFIXONLY = 0x00200000;
function RGB(r,g,b){ return (0xff000000|(r<<16)|(g<<8)|(b)); }
var g_font = gdi.Font("LCD", 18, 1);
var g_drag = 0;
var g_drag_seek = 0;
var tfo = fb.TitleFormat("POS: %playback_time%/%length% '('$max(0,$left($muldiv(%playback_time_seconds%,1000,%length_seconds%),$sub($len($muldiv(%playback_time_seconds%,1000,%length_seconds%)),1)))'.'$right($muldiv(%playback_time_seconds%,1000,%length_seconds%),1)'%)' REM: %playback_time_remaining%");
var txt = "";
function TimeFmt(t){
var zpad = function(n){
var str = n.toString();
return (str.length<2) ? "0"+str : str;
var h = Math.floor(t/3600); t-=h*3600;
var m = Math.floor(t/60); t-=m*60;
var s = Math.floor(t);
if(h>0) return h.toString()+":"+zpad(m)+":"+zpad(s);
return m.toString()+":"+zpad(s);
function on_paint(gr){
var pos =0;
if(fb.PlaybackLength > 0){
if(g_drag){
pos = window.Width * g_drag_seek;
txt = "Seek " + TimeFmt(g_drag_seek * fb.PlaybackLength) + " / " + TimeFmt(fb.PlaybackLength);
else{
pos = window.Width * (fb.PlaybackTime / fb.PlaybackLength);
txt = tfo.Eval();
gr.FillGradRect( 0, 0, pos, window.Height, 90, RGB(240,240,240), RGB(46,48,63));
gr.FillGradRect(pos, 0, window.Width-pos, window.Height, 90, RGB(240,240,240), RGB(190,190,190));
gr.GdiDrawText(txt, g_font, RGB(50,50,50), 0, 0, window.Width, window.Height, DT_CENTER | DT_VCENTER | DT_SINGLELINE);
gr.DrawRect(0,0, window.Width-1, window.Height-1, 1.0, RGB(150,150,150));
function on_mouse_lbtn_down(x,y){
g_drag = 1;
if(g_drag){
g_drag = 0;
g_drag_seek = x / window.Width;
g_drag_seek = (g_drag_seek<0) ? 0 : (g_drag_seek<1) ? g_drag_seek : 1;
fb.PlaybackTime = fb.PlaybackLength * g_drag_seek;
function on_mouse_move(x,y){
if(g_drag){
window.Repaint();
function on_playback_time(time){
window.Repaint();
function on_playback_stop(){
txt = "Playback Stopped";
window.Repaint();
function on_playback_starting(cmd, paused){
function on_playback_new_track(info){
window.Repaint();
//EOF
